Sponsored by: CARiD
Cam solenoid/ cam magnet and spark plugs
Old Jun 18, 2021 | 11:46 AM
cleanerPA's Avatar
2014 E550 4Matic
So I had an issue with an oil leak at the cam sensor. I replaced all 4, had one that was leaking oil, wet electrical connector on both sides, didn't seem to wick too much oil into the harness yet, so I think I caught it in time.
However, I don't see how I can replace the cam solenoids/ cam magnets. The ones on the passenger side (left side if you're looking straight at the front of the car) look accessible, but the ones on the driver's side have very little access- two A/C hard lines are in the way. Any tips on how to access the bolts? Also, there's no room for a ratchet and e-torx socket. I ordered e-torx gearwrenches for this job.
Second, where are the spark plugs? There is a big rubber insulator over the valve covers and removing it, I can see the fuel rail, but I don't see anything that looks like an ignition coil or plugs. Are the plugs above or below the fuel rail?
Old Jun 18, 2021 | 01:07 PM
chassis's Avatar
2017 GLE350 4MATIC
Which engine do you have? V6 or V8? Spark plug replacement for both engines is covered many times on this site, Benz world and YouTube.
Old Jun 18, 2021 | 02:21 PM
cleanerPA's Avatar
2014 E550 4Matic
E550, M278. I could find nothing on this site for cam solenoid replacement videos, write-ups, etc.
Old Jun 18, 2021 | 03:14 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
when you say that... you're essentially saying you are beeing miss lead.
In order to be successful you have to gather information by searching it.
Someone took the time to help you, don't be foolish. Poke around a bit.
Old Jun 18, 2021 | 04:19 PM
cleanerPA's Avatar
2014 E550 4Matic
Did you even read what I posted? I searched on here for a write up and found nothing. There are plenty of posts on the cam sensors and magnets leaking oil but I didn’t find anything showing how they were replaced. Both of you are just being obnoxious.
I’m not an idiot- I searched before I posted. Furthermore, I never thought I’d find so many unhelpful people in a forum geared toward DIYers. Two of two.
When the previous poster said there are plenty of videos on YouTube, that’s not true. There are videos showing the W221 S-Class but nothing for a W212. I was concerned that not everything would be the same as they are different chassis. I wouldn’t look for a GL550 video and think it’s going to be identical.
Old Jun 18, 2021 | 04:29 PM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
I am fresh on them, I can help if you want set up video meeting. One question, do you have thin hands?
Old Jun 18, 2021 | 04:30 PM
I am sorry, I am on the 3.5V6, I wish I had your answer.
Are you going to go ahead and fill the gap with a post detailing all your findings for everyone? Apparently that's what's missing for V8, right?
Old Jun 18, 2021 | 04:37 PM
cleanerPA's Avatar
2014 E550 4Matic
the cam magnets? I’ll send you a PM- thanks.
Old Jun 19, 2021 | 11:09 AM
S-Prihadi's Avatar
Usually I use ebay engine sales as a visualizer tool to see how my engine are, if out of the engine bay.
It is much better than looking at WIS/EPC and it can help to visualize how are we going to remove X,Y,Z component.
This is M278
https://www.ebay.com/itm/193868806149
Old Jun 19, 2021 | 05:53 PM
cetialpha5's Avatar
The 2014 E-550 was a pretty rare car. If you find other videos featuring the M278 engine, things should be about the same. At one point I changed my steering angle sensor by watching a video on how it was done on an ML. MB shares parts across many platforms. There's lots of videos on how the plugs are changed on the M276, I think MB just tends to graft two extra cylinders onto a engine so it might be similar, but those V8 engines are much rarer than the V6. They probably use the same indexing that the V6 uses so make sure you get the plugs from MB, Bosch makes the plugs but the aftermarket ones don't seem to index right like the MB ones. You can play around with copper washers to index them right or just get the plugs from an MB dealer.
Old Jun 19, 2021 | 08:36 PM
Blkvip's Avatar
12' E559
the M278 spark plug job is the same for every model so if you find a video or write up on a different class just use it.
plugs are easy to do given you have the tools....swivels and extensions are key tho the 2 cynilders near the firewall are very close to the engine.
pull the air box off to the side, pull the large rubber pad off and youll see the coils.
Old Jun 21, 2021 | 03:26 AM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
in general, a Mercedes engine is exactly the same on different classes/models IF its the same sub-version. like, my e350 4matic has engine 276.952... this is on the data card, its the first 6 digits of the engine's major assembly number.
Old Jun 21, 2021 | 03:47 PM
cleanerPA's Avatar
2014 E550 4Matic
The cam magnets on the passenger side were much easier- one is completely exposed, very easy to do. The "inner" one is a fair bit harder- you have to:
Remove the engine cover
Loosen the clamps between the airbox and the charge pipe
Remove the bolt holding down the charge pipe
Pull the charge pipe forward (toward the front bumper) to make space
The driver's side is very difficult. The outer one I was able to do, but the bottom bolt is very tight clearance, as is the top left. The inner one I could not figure out how to do- the top bolts I can get to but the bottom bolt, there simply isn't any clearance to even get a Gearwrench ratcheting wrench into there.
I saw this video on youtube:
This makes it look easy, but the A/C hard lines are right next to the oil filter housing. The top of the oil filter I can remove and that helps quite a bit, but there's nothing I can do about those A/C hard lines. In the video referenced above, the guy doesn't seem to have any difficulty getting around the A/C lines, but that might be because he has a CLS rather than an E- maybe things are less cramped in the CLS because it's a little bigger?
The cam adjuster magnets are much harder to do than the cam position sensors. I haven't gotten to the plugs yet- still learning about indexing them properly and it sounds like the Bosch branded plugs don't index correctly, which would be a big problem. I think I'm going to return the Bosch plugs and buy MBZ branded plugs for the replacement.
Old Jun 21, 2021 | 04:39 PM
S. Madman's Avatar
https://www.youtube.com/watch?v=l7SVMeAiHhM
I did not remove any parts other than the plastic cloth intakes. I did not even have to remove the charge pipes.
Old Jun 21, 2021 | 07:48 PM
chassis's Avatar
2017 GLE350 4MATIC
@cleanerPA Indexing the plugs requires no thinking whatsoever. Not a facetious comment. Buy spark plugs from the dealer, and install them with a torque wrench. 23Nm is the torque spec. Done.
There are many posts on this site talking marking electrodes and going through drama to be sure the plugs are indexed. Using the MB OEM plugs purchased from a dealer, with the MB torque spec results in indexed plugs.
Old Jun 21, 2021 | 08:35 PM
cleanerPA's Avatar
2014 E550 4Matic
I wonder what changed between 2012 and 2014- I can take some photos, but there are two A/C hard lines, the oil filter housing and the charge pipe in the way in my car.
Old Jun 21, 2021 | 08:36 PM
cleanerPA's Avatar
2014 E550 4Matic
Thanks- I'm going to buy plugs from a dealer and do exactly that. If it's that simple, then it shouldn't be that bad. Only thing I need to get is the tool to remove the boots off the plugs- from what I gather, it's easy to damage them when removing them.
Old Jun 21, 2021 | 09:03 PM
S. Madman's Avatar
Do take a pic it was tight, but not impossible.
Old Jun 21, 2021 | 11:20 PM
chassis's Avatar
2017 GLE350 4MATIC
User @39039 has videos on YouTube, user Senior Leigh, for the M276 engine. Look at his tools, the curved jaw pliers are used to pull the coil boots off. It's still a hard job because the boots adhere to the spark plugs. I posted photos all of my tools for spark plug change on my GLE350 4MATIC Ownership Report thread in the GLE W166 section.
Old Jun 24, 2021 | 09:58 AM
cleanerPA's Avatar
2014 E550 4Matic
So the cam adjuster solenoid is the black piece buried in there. When people say it’s easy, I don’t know what they’re looking at.
Old Jun 24, 2021 | 02:42 PM
Fliplegend's Avatar
S212 E350 Estate
Man that is tight. My e350 with the V6 has oil seeping from that exact location and I am planning on resealing the whole timing cover which involves removing all those blue headed bolts. I too have some hard lines in front of the driver side but nothing like that! Good luck and subscribed!
Old Jun 24, 2021 | 04:41 PM
chassis's Avatar
2017 GLE350 4MATIC
Keep looking at it. If you pull back the wiring harness and remove the oil filter, you will open up more space.
The only screw you can't easily access is the lower/bottom one, correct? If the oil filter is removed, will you have access for a wrench? Another option is to remove the front cylinder head cover with the magnets, as an assembly. Replace and reseal the assembly, then reinstall.
The hard pipe with a black hose is a water pipe. If you remove the rubber, then see if you can remove the metal portion, this will give more space.
Old Jun 24, 2021 | 05:06 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 25, 2021 | 05:31 PM
mercerized's Avatar
2020 E450 4matic wagon
Thank you Konigstiger!
Old Jun 25, 2021 | 06:05 PM
S. Madman's Avatar
DONT PULL ON ANYTHING!! Send me a PM.
