Sponsored by: CARiD
Intake port measurements for walnut blast adapter.
Old Sep 7, 2021 | 12:13 PM
bhpplease's Avatar
2010 E350 CGI S212 // 2004 SL500 R230
Hello everybody,
I need to get my E350 CGI walnut blasted. I have everything except the little adapter that sits into the port and accepts the blaster nozzle and vacuum.
Does anybody know where I might get some measurements for the intake port on the M272.985 engine please?
If I can get them, I should be able to adapt one of the freely available designs for BMW engines.
On the other hand, maybe I just print one of the BMW ones with an oversized port side and shave it down to fit?
What have people done?
Old Sep 7, 2021 | 04:09 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
M272 with multi-port injection, no? Usually intake deposits are more problematic on direct injected engines... do you suspect excessive build-up? Replacing both engine oil separators is common maintenance as the cars hit 100k miles. Usually the cam driven separator cover will start leaking... leading to early replacement. Its located on the passenger side bank, rear of engine. The other is on the drivers side, front of engine, looks like a black box on the cam cover with a rubber line to the TB.
Using a quality synthetic engine oil, top brand fuel (premium additives) and occasional fuel injector cleaner should be enough.
Old Sep 7, 2021 | 04:43 PM
bhpplease's Avatar
Hi @bmwpowere36m3
I have been lead to believe that you are correct for the regular M272 engine.
I have the CGI which is slightly different, and I believe it suffers from this problem. I can't find any material that specifies the types of fuel injection in each variant. I must check WIS but it's on the other computer.
Old Sep 7, 2021 | 04:50 PM
bhpplease's Avatar
I forgot to mention that I have replaced the PCV and other part of PCV already.
Old Sep 7, 2021 | 04:51 PM
I believe your correct, those weren't available in the US.
Old Sep 7, 2021 | 04:52 PM
bhpplease's Avatar
Oh really?
Damn, I thought the CGI was a big one in the US.
I guess there aren't many then, as Europe is more Diesel focused. Arrgh. lol.
Old Sep 7, 2021 | 09:30 PM
It wasn't till the M276 and M278, did we see direct injection.... diesels, might as well be unicorns.
Old Sep 9, 2021 | 03:14 PM
bhpplease's Avatar
According to Wikipedia
The E35 is a 3.5 L (3,498 cc) version. Bore and stroke dimension is 92.9 mm × 86 mm (3.66 in × 3.39 in). Output is 272 PS (200 kW; 268 bhp) at 6000 rpm with 350 N⋅m (258 lb⋅ft) of torque at 3500 rpm. A direct injected variant debuted in 2006 under the name Stratified-Charged Gasoline Injection (CGI).​​​​​​
Ref: https://en.wikipedia.org/wiki/Merced...272_engine#E35
Old Sep 10, 2021 | 03:29 AM
Senecat's Avatar
1983 Nissan Shltbox
Print it and put it on thingiverse.
Old Dec 2, 2022 | 10:51 AM
bhpplease's Avatar
I would do. In fact, if I want one. I might need to do that.. I can't seem to find anywhere.
Old Dec 3, 2022 | 04:45 AM
S-Prihadi's Avatar
Buy the seal #105 for intermediate flange, you need it anyway and use it as a template. That seal would be probably maximum 3-4mm bigger all around than actual port opening on the engine.
Go to my link below and you will know what I mean, yes my engine is the M276.820 3.0 Turbo and not 3.5 NA.
https://mbworld.org/forums/e-class-w...eaning-p2.html
Item 105 : https://www.fcpeuro.com/products/mer...ing-2761410080
See the traces where my equivalent seal #105 was sitting on the intake manifold.
Below : Guesstimate where the seal #105 was seating at
This is the equivalent of my seal of #105 if it were for your engine
Close up
Wide angle
Good luck..............
