Serpentine (V-ribbet) belt Lenght M272
What is the exact Serpentine (V-ribbet) belt lenght in mm for engine M272 - 2011year - 268hp?
My VIN is: WDDHF8HB1BA484379
I've ordered a kit with the V-belt (Gates), 2 drive pulleys (INA) and belt tensioner but after 1 day of driving I got the engine light on the dashboard (no other signs of something wrong). Still have that little noise and It seems that that the V-belt is not running very tight even on the 10th sec of the video it losses like 100rpm for a moment.
You can see who the belt is moving on the pulleys.
https://streamable.com/323k1l
I still didn't get the error code but I think the belt is not the proper one. Forgot to measure the belts before changing it so I don't know who much the original and the new one are.
The car is on 100'000miles and never had any problems before.
I will order the new one and see what happens. Thank you bmwpowere36m3.
See (Q/A section) . For MER-0039937296, the length is reported as 2404 mm, 14mm difference
Others can pitch in if that is normal for the M272 (I doubt it, and I do not have the W211-M272 close by to check), but if I were you I would be certain to know where the wobble comes from before putting another part into the mix. I do not think the belt system is meant to have lateral motion, robust to it perhaps but not by design.
My 2c
PS: On the belt dressing, I would not use it at all unless I am going on a date and I do not want to arrive with a squeaky vehicle
Your tensioner and idlers look good.
Imagine that your belt can not wabble that much over every pulley...
,I could agree that it could be an optical effect when looking at the tensioner pulley where the belt markings meet the pulley; however, if you look at the tensioner pulley with respect to its base, i.e. the stationary part, there might be another optical effect with the lighting and the motion of the pulley surface.
I would love to see it in person to know.
I think you're right about this wicked belt. It's not just optical, something's off here. We can see it walk around from side to side.
Is any of these pulleys wobbling ?
, after the RearSam soldering, the new AUX battery, and the grounds maintenance ( I did something similar to the W211 while searching for an empty tank
). I still have to do the seat module you posted recently (and lubricate both screws), but I am not doing the fuel pump wiring, nor messing with the cluster. I will end up with too many broken plastics.
The OP mentioned there is a noise still. Perhaps it is time for a pipe, broom, hose, or stethoscope to the pulley on the water pump? My sister's W166 has some noise coming from the belt system, but it seems the tensioner is adjusting too often and I do not see that motion in the OP's video
here is the link when he is replacing the pulleys on the M272
https://eeuroparts.com/product/gates/K060947
This site lists the same part number for multiple brands, and guess -> Multiple lengths.
https://www.onlinecarparts.co.uk/oen...039937296.html
