Advise needed for glove box pipe that do a cooling inside
Old 01-25-2022, 12:16 PM
Mindaugas's Avatar
Mercedes W212
Hello guys i putted back after some crazy workers my dashboard back, problem can you tell me how to get or how looks like the plastic pipe that connects to glove box top and there is a turn inside of glove box that do hot or cold inside of it.
many thanks
p.s as mine i ordered seems uk side or maybe im so dumb dont understand how to put.
Old 01-25-2022, 01:05 PM
konigstiger's Avatar
Received 4,435 Likes on 3,152 Posts
'71 Pinto
@ 2:06...
pierrejoliat (01-25-2022)
Old 01-25-2022, 01:17 PM
Mindaugas's Avatar
Mercedes W212
my friend i need to see how pipe is connected with plastic tube on that place on this video 0 to see
Old 01-25-2022, 02:57 PM
CaliBenzDriver's Avatar
Received 3,448 Likes on 2,297 Posts
MY'14 W212 M276 3.5NA @60kMi
Dashboard rattles...
This is a fantastic video to work on dashboard rattles.
It shows how to remove all the subcomponents attached to the dash.
​​​​​​To try helping you, Pls show us a picture of the glove box vent pipe .... try sliding pipe over the glove box nipple.
Old 01-25-2022, 04:34 PM
DeTh's Avatar
W212 E350
Are there any common places to check for dashboard rattles? Or a thread that has some solutions?
Old 01-25-2022, 04:49 PM
rattle squad...
not that I know of personally. I am sure you're not the first Benz owner chassing a rattle, right?
Try to process by elimination to locate rattle:
top vs. bottom - then Left vs. Right so you have a location identified.
Once that look at what components are in there and how you can keep 'em from RUBBING AGAINST EACH OTHER.
MB uses sticky felt strips between parts so they slide more easily...
I guess you can remove all the trims and unecessary items to gain better access (glovebox, central comand, display...) eliminate every things until the answer becomes obvious.
While you have things out... resolder loose pins along the way! Many-many modules around dashboard need TLC.
pierrejoliat (01-26-2022)
Old 01-26-2022, 12:08 AM
Mindaugas's Avatar
Mercedes W212
Please look at here guys i need to see how to install parts 290.
Old 01-26-2022, 12:15 AM
air duct....
Does your pipe 290 not fit with glovebox nipple ??
Can you press it on or what is the problem ?
It is low aire stream pressure, no need for any clamp.
Old 01-26-2022, 12:19 AM
Mindaugas's Avatar
Mercedes W212
this parts ordered new on photo it go angle to right mine to left how i install it?
Old 01-26-2022, 12:51 AM
pick one ...
It's either one of these...:
  • the wrong part
  • pipe is turned around
  • installed up side down
based on the fact it's a part you ordered for replacement, the problem may be a part mismatch or as described above.
Old 01-26-2022, 12:56 AM
Mindaugas's Avatar
Mercedes W212
funny thing with part codes and ebay listing showing same item i got. so i need any help how to install?
Old 01-26-2022, 08:59 AM
pierrejoliat's Avatar
Received 1,128 Likes on 754 Posts
12 E350 4Matic 13 E350 4Matic AMG Sport
They may make two, one for right hand drive, one for left.
Old 01-26-2022, 09:04 AM
Mindaugas's Avatar
Mercedes W212
so how to know code for europe side?
Old 01-26-2022, 09:21 AM
Does your replacement part match the picture above? Exactly? Or is it reversed, if it's reversed, it's likely for right hand drive car.
Old 01-26-2022, 09:28 AM
Mindaugas's Avatar
Mercedes W212
the nose that go forward must be into screen side its like uk side. i dont understand can you help with part number or right photo how that installs.
Old 01-26-2022, 09:40 AM
Ok, let's start over, where are you located and which side of the car is the steering wheel on?
CaliBenzDriver (01-26-2022)
Old 01-26-2022, 09:44 AM
Mindaugas's Avatar
Mercedes W212
europe sir and Left side car is in europe not like uk.
Old 01-26-2022, 09:46 AM
Talking
Ok, then your part should look exactly like the one in the schematic above. If it doesn't you have the right hand drive part.
Old 01-26-2022, 10:04 AM
Mindaugas's Avatar
Mercedes W212
yes im thinking the same but i need also any help how to install it
Old 01-26-2022, 10:15 AM
it just attaches to the HVAC box and pops into the hole in the top of the glovebox, So maybe attach to HVAC box, put glove box in place loosely, then reach up behind glove box to insert tube into glovebox hole?
Old 01-26-2022, 10:24 AM
Mindaugas's Avatar
Mercedes W212
angle does not match like from photo i googled and all they like that
Old 01-26-2022, 10:55 AM
KEY08's Avatar
Received 1,622 Likes on 1,191 Posts
2014 E550-sold 😩
Lots of discussion regarding getting that new part in the hole. Shouldn’t be this difficult, unless you have a right handed part by error. I think everything has been covered to help out. Now you are back on your own. Good luck
The following 2 users liked this post by KEY08:
CaliBenzDriver (01-26-2022), pierrejoliat (01-27-2022)
Old 01-26-2022, 12:28 PM
This may help.
Old 01-27-2022, 12:19 AM
Mindaugas's Avatar
Mercedes W212
look at here guy this is the item and look at diagram its totally different angle and the codes same.
A2128310145
Old 01-27-2022, 12:42 AM
A2128310145
​​​​​​... so you got the wrong part/number
Quick Reply: Advise needed for glove box pipe that do a cooling inside
