Sponsored by: CARiD
Help !!! Screen Not Working
Old May 13, 2022 | 05:21 PM
Evolutions's Avatar
2010 Mercedes Benz E-350 Sport
So I have been having this issues with my 2010 Mercedes Benz E350 Sport Screen NOT turning on, I have checked the Fuse (#11 - 7.5 Brown Fuse) it was blown ,so I replaced it with New one, Still nothing. I then went ahead and purchased a new Screen ,and installed it, Still nothing ,I've check to see if there was power in the wire, There is Power. So at this point I am stuck. Any idea as to what could possibly be? Any help is appreciated ,Thank you in Advance.
Old May 13, 2022 | 07:26 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
quiet screen display...
Your old display blew up its fuse, the replacement still does not work despite good power.
I bet it needs coding to match car VIN. Does your scanner list the "central display" module, can you get into it or just plain missing?
What blew fuse open:
Overheated power supply capacitors went short or missing... The way this module is built with fins you can yell it's a hotty
Blower for Comand & display has a FILTER
Did you see a vent duct blowing air through your screen heatsink.... there is a small blower with a tiny filter directly to the right: check its condition: time for service?
Old May 13, 2022 | 07:41 PM
Evolutions's Avatar
what is the picture location? where do I find that?
Old May 13, 2022 | 07:54 PM
dedicated blower
this blower is located to the right of Comand along left side of the glovebox. You'll need to drop the glovebox out to access this assembly (inbound/outbound ducts, rubber mount insulators)
I think it is hooked up & controlled directly by Comand unit. I remember seeing "Fan: auto" options in the "engineering menus"
Old May 13, 2022 | 08:59 PM
Evolutions's Avatar
Thank you I will check it out
Old May 14, 2022 | 03:12 AM
S-Prihadi's Avatar
Cali, which nook and cranny at the dashboard you have not ventured to ?
Old May 14, 2022 | 03:48 AM
A to Z : front to back...
Surya you know there are a few modules I've not visited yet, like:
-- SRS main controller located under Comand
-- front bumper 3x radar modules
-- "ESP Premium" (ABS) on driver side
-- Integrated modules (/tranny /steering /ECU).
-- Gearbox selector driver
-- LED Headlights
I can see water has puddled inside my HVAC inlet DUCT, over my blower "resistor"... so I am going to go visit cowl and LIN wiper to grease it and waterproof. I'd hate to waste my electronics with a standard leak. Did you find a missing seal between the firewall and plastic air inlet... right?
Old May 14, 2022 | 04:01 AM
S-Prihadi's Avatar
I have not venture much at the HVAC/blower , except sending camera to the evap and once cleaning it with chemical from Honda.
I have to inspect it again soon now that we are discussing it. I need to see the filter state of cleanliness which by now is like 10,000KM older.
I know better about the hole near the front sam which I believe it is there for manual clutch if car is manual.
I use that hole to send thermocouple wires from engine bay into the interior.
Hhmm, blowing air to push possible dirt from the evap condensation hoses is a good idea Cali, thanks.
Please take lots of photo when you visit wiper system. I see there is a sealant on the windshield towards the plastic assy/cowl hiding the wipers.
I hate sealant or re-sealing
Old May 14, 2022 | 04:22 AM
resistor shower ...
PWM Blower controller heatsink
Next time you go in to replace your cabin filter (and dust-off tiny Display/Comand filter) drop out the blower "resistor" to check for white aluminum oxidation of the heatsink by rain egress.
Old May 14, 2022 | 04:23 AM
S-Prihadi's Avatar
Yes Sir ! Arigato
