Sponsored by: CARiD
Coolant sensor issue on my W212 E350?
Old Jun 13, 2022 | 05:27 PM
Andryuha's Avatar
'11 E350
Last year, I had an issue with the coolant temp needle rapidly shooting up, followed by the warning light. The issue went away after restart. It happened again afterwards and I noticed a leak from the thermostat housing. I replaced it, along with the upper coolant hose. Fast forward to last week - it happened again. However, after I shut down the car, it wouldn't restart. After sitting for half an hour it fired back up and drove fine since. I picked up a Foxwell scanner and it pulled a faulty coolant sensor code. I ordered a sensor, but I can't figure out how to get the old one out. Is there a good DIY for this? Seems like a complete PITA and a ridiculous design.
Old Jun 13, 2022 | 06:30 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
is that the sensor with no thread ?
smooth surprise
Old Jun 14, 2022 | 03:07 AM
S-Prihadi's Avatar
I do not know your E350 engine type, but if M276 3.5L, coolant sensor is very hard to access. It is near the very rear end of the engine.
The thermostat at the front, that wire there is a Heater, not coolant temperature sensor
Old Jun 14, 2022 | 08:20 AM
Andryuha's Avatar
'11 E350
smooth surprise
That's the one. I have an M272 engine.
Old Jun 14, 2022 | 08:21 AM
Andryuha's Avatar
'11 E350
Old Jun 14, 2022 | 08:31 AM
S-Prihadi's Avatar
About the same location with M276, but I believe by photo I have, M276 is slightly lower than M272.
M272 coolant sensor location
https://mbworld.org/forums/m-class-w...-location.html
https://www.pelicanparts.com/techart...eplacement.htm
Old Jun 26, 2022 | 09:52 PM
Andryuha's Avatar
'11 E350
Thanks guys! I replaced the sensor. The code has not re-appeared and I've also noticed that my A/C is working properly again. Pelican article is OK, but it omitted a bunch of steps. The MAF sensor and intake elbow need to be removed to allow sufficient access. Also, the crank position sensor must be disconnected. It's a pretty idiotic design because then the coolant temp sensor is removed, you will spill a bunch of coolant inside the CPS connection. I used compressed air to dry it out after the coolant temp sensor was replaced. Oh and there was also lots of cursing and painful cuts. My hands aren't exactly tiny.
Old Jun 27, 2022 | 01:46 AM
Good job!
Every cut is worth $500
