Sponsored by: CARiD
Has anyone set their LED Parkers to come on automatically?
Old Jul 17, 2022 | 03:59 AM
Aussie_E350_Wag's Avatar
2013 E350 Facelift (Japan Import) 2007 E350 Elegance Wagon, 2014 E350 Wagon facelift model Jap Model
Hey guys,
Just wondering if anyone has worked out how to set their front headlights the just show the LED lights when ignition on his honour the car is running without actually having it turn the light dial so that they do come on as per my picture below? Basically I just want the LED stripes to show in the headlights not the LED lights themselves when the car is running and then the lights would come on automatically at night time of course has anyone managed to work out how to do that my car only seems to show the LED stripes when you press the button on the dash or turn the dial to just the parkers only?
Old Jul 17, 2022 | 04:28 AM
S-Prihadi's Avatar
That twin lines of LED is the Daylight "bulb".
Use the instrument cluster menu for DAYLIGHT activation and when ignition is ON, these LED will be active too.
To avoid confusion :
Headlight ILS LED assy consist of : ( ignore the USA side yellow lights ), see this link https://mbworld.org/forums/e-class-w...ol-itself.html
Old Jul 17, 2022 | 04:37 AM
S-Prihadi's Avatar
Parking light = daylight too
There is a zip file in this post for your headlight, https://mbworld.org/forums/e-class-w...leshooter.html
You can see how many LED modules are in our headlights 641
Old Jul 17, 2022 | 05:28 AM
As mine is a Japanese import when you make that selection the twin ILS lights also come on, so I'm guessing this must be a special setting for the JDM delivery cars as I can see many Aussie cars have the towing stripes only during the day...might be another job for BenzNinja to sort out?
Old Jul 17, 2022 | 05:33 AM
S-Prihadi's Avatar
Is the rotary light switch on A ( auto ) ?
Daylight only activation for my car is when rotary light switch is at A (auto) and Ignition ON is the activation.
Next clockwise setting at the rotary switch = Daylight and the 2 big LEDs will be on as that is MANUAL mode for Low Beam and Parking Light.
Parking Light is Daylight, same unit, just different application for different circumstances
Old Jul 17, 2022 | 06:03 AM
S-Prihadi's Avatar
My rotary light switch is this one : There is no OFF ( zero )
Old Jul 17, 2022 | 06:30 AM
On Auto with the light feature enabled then all the lights are on and the only way to get the LED stripes active is to turn the dial to the left so only Parkers are selected and active, it's looking like another weird Jap only feature.
Old Jul 17, 2022 | 06:33 AM
S-Prihadi's Avatar
I see
Old Jul 17, 2022 | 06:46 AM
Basically my lights are all Off or all On unless you turn left to select parkers...then the other pain in the **** is you need to turn them off when you switch off the engine as they will stay on.
Old Jul 17, 2022 | 06:58 AM
Old Jul 17, 2022 | 08:04 AM
RA72825's Avatar
My US car with full LED lighting and in auto mode will illuminate only the LED arrows during the daytime. They are the daytime running lights here. Yes, your car is set up differently and I assume can be reprogrammed.
Old Jul 19, 2022 | 04:00 AM
Sir_Mwangi's Avatar
W204 C63, W212 E350
@ Aussie_E350_Wag I also have JDM spec W212 Facelift that had a similar issue. I took it to a mate with the Star diagnostic tool and he was able to code the daytime running lights properly.
Prior to this, when you switch on the DRLs the lights would all be on and the most frustrating bit the tail lights would also come on. When I would switch on the parkers they would not be as bright as other similar cars and the tail light parkers would also be on.
After coding, only the LED strips come on when you switch on the DRL on the cluster and the tail light parkers do not come on.
I think the JDM spec has a different DRL code.
Old Jul 22, 2022 | 07:54 PM
Thanks very much that's exactly the issue I'm having, I've got a C4 now so I'll ask Benzninja to work his magic on them 👍🏻👍🏻
Old Jul 23, 2022 | 04:29 AM
Which country are you from?
