E550 Suspension lower on right side
I checked for leaks and didn't find any and when the car sits for days at a time the suspension does not sag, it just stays 5cm lower.
Should I be concerned about this?
Start maintaining your air suspension system is not a bad idea. Let your wallet have the final say
When the air circuit is sealed there is no new additional moisture being introduced and accumulating. So it boils down to: you don't want to ignore leaks to prevent rusting carbon steel valves.
The usual suspects include compressor, valves, lines, sensors and bags.
There are many mbworld specialists who know every bits of this system maintenance - I don't
You will need a mid range scanner or better a Xentry to troubleshoot properly.
I don't know if iCarsoft MB v3.0 can read airmatic or not. This is the lowest cost MB ready scanner but no true bidirectional capability I think.
Being a 2013 model year, now near 9 years up is where $$ starts to flow out of your wallet when you own airmatic. It is given, super comfort has a price to pay. Even our regular dampers will go kapoot.
Rubber spring will tear or leak, system will have some rust from wet compressed air and etc etc.
It is part of wear and tear.
