Metal in Oil at 27,800 miles '12 E-350
Diesel or gasoline?
A lot of people are in the same boat unknowingly. You just happen to have uncommon information.
The car maintenance you get done is what helps your car stay in good shape longer.
You should get the oil analysed to figure what engine element is falling apart.
Already you can use a magnet to test magnetic properties of your oil sample (steel vs.light alloy).
If particles were stuck at the bottom of your oil pan instead of trapped in the oil filter, it may be heavier steel pieces such as the soft VVT lock pins getting ready to call you attention.
Use MB recommended oil or better grade, changed often or around 7.5kMi.
CaliBenzDriver has a point at his last paragraph . I still wish there's nothing serious with your engine unless you see enormous clouds of smoke when you drive it or excessive "oil burning"
Don Parrish
In my opinion, the M272 engines of the last generation (post-balance shaft mess) are bulletproof engines if properly maintained. They have issues like any device, but their issues have been summarized in the forum.
Don Parrish
A comment on the service. Based on mileage this car would have had at maximum 3 services: A @10K, B @20K, and A@30K. Not many at all. Based on age, it should have had at least 10 services, basically oil, oil filters, and brake fluid.
I have no knowledge of service to this car prior to my purchase. It was a car coming off a lease.
From your service dates, and mileage the car has been sitting for a long time, not GOOD. For example 14K/5year = 3K/year (hopefully real miles). Hopefully, it was serviced before delivery in 2017. After that 20K service, it has been serviced 3 times in 5 years. As far as I understand, cars that sit for too long between starts need pre-emptive help to prevent rust to scratch surfaces when starting. It is not clear if the car was warmed up occasionally between the occasional driving, or sat for 2 years and then driven 1K miles.
Have you got a diagnosis from an MB specialist (not just a professional mechanic) familiar with these engines? Sister's 2012 W166 M276/9 is also within the range specified in the service bulletin; however, it is serviced every 5K (on the clock) and it has reached 120K+ w/o any engine issue (but a CPS @110K).
Fingers crossed it is a consequence of the chain tensioners rattle, and you can get away with a major engine repair, but not engine replacement. You need an specialist to look carefully on this engine for you. Definitely long-term damaged has been done, but who knows how much can be saved?
You have shown no photos of Blackstone report, and no qualified mechanic diagnosis or service invoice. What information are you using for your assessment?
Again, bummer if this is happening, but you have provided scant information.
Get a second opinion you can trust before making any decision.
Engine oil is fairly cleaned by the (8um) OEM filter cartridge. The issue has more to do with burnt oil not lubricating.
Engine oil is one thing but now transmission oil and brake system need timely service before they develop their own attention getters.
I have seen the photographic evidence of what's in the oil filter. There is no reason to think these are like the dirty air cleaner supposedly remove from your car at the quick lube shop. Having a good bit of experience with oil/metal problems from several thousand hours in turbine aircraft, what I see is bad.
If that is not good enough, anyone listening to the car now would certainly agree it must be bad, very bad.
To refine the "noise" progression: (Although not driven a great many miles over the last few years, the car was driven on a regular basis, short trips but always up to operating temperature.) Beginning probably about 500 to 700 miles back there was what I could only describe as a tick at start-up. After driving and coming to full temp, the tick was still there. Could not be heard in the car. Perhaps my first mistake, I should have stopped then. Over time it became a bit worse and I began to hear the noise inside the car. In the last 50 miles or less, the problem was much more pronounced, and I began talking to the first "opinion". I made note of sounds now and can report at start-up it is more than a tick, at 1000 rpm it is much more noticeable. Car in Park, advancing the rpm from there it becomes more like an engine wanting to come apart. At one time the sound seemed to reduce significantly above 2500 rpm' not now. The car can be moved around a bit at idle rpm but advancing the throttle seems to be asking for it to come apart.
My second opinion service center was aware of "L105.10-P-056435" but due to the tick or rattling noise never dissipating after sufficient oil pressure, that was not the problem. Arguable point? Perhaps, but not from me.
Bottom line today. Retired, not wealthy but comfortable. Already have two cars, a truck (and a '67 Corvette), don't need the MB. May have to admit that perhaps some of all this is my fault. I can do that and I can afford to say that. That's not being arrogant, I worked hard to get here. My choice today is an expensive repair (no doubt, it is an MB) or install a used engine also not inexpensive. Either of those choices cost near or above $10K and in the end the car is still a 2012 worth what (?) and waiting for the next shoe to drop. So...the MB will go. Make me an offer.
Thanks again to all for your input,
Don Parrish Phoenix
Don Parrish Phoenix
very sad. For your information, one of the most active members in MBWorld (if not the most), @konigstiger is located in North Scottsdale, AZ.
I just had this weird noise coming from my S550 278 engine. See link below.
I have not seen video or other recording what kind of a noise OP has but mine sounded like metal is rattling somewhere and was given the hint of it coming from the high pressure fuel pump. I replaced both pumps and the "roller" lifters and sound is gone. I think it was really one of the lifters that had worn extra clearance, but I changed everything as I was there...
Could it be this same issue...?
https://mbworld.org/forums/s-class-w...ine-noise.html
It is very common to discuss them as the same engine except where they differ of course.
A recording, if you think the engine will tolerate more running time, will give some in the forum a chance to give you a more informed comment. The W212 group is one of the most active groups in MBWorld, and will honestly try to pitch informed comments.
I will admit here my inability to post the recording I have which is 1:16. Made with my iPhone but not able to move to an email form for posting.
Suffice it to say, the pronounced knocking at 2000-2500 and beyond is loud and severe.
Don
I also must tell you your car is worth twice to three times it's whole value in parts, yes, it sits for a while, but this happened to me with my '03 S500, insurance offered 8K, got more than 16K in parts, yes, most I removed myself, but the engine and tranny brought 4k all by themselves. Sad to think, but Im retired also, so time is less of an issue, hard to watch the pieces leave however, but with that mileage the pieces have real value.
