Backup camera works but...
First issue is location of bus bar, and the other is identifying if low speed or high speed CAN bus.
I put scope on both at Backup cam module, but no issues found, not even when open close door, turn car on off, start car, change gear selections nothing shows.
I cannot tap Ignition With Module without removing Steering column, and that process would pollute testing by moving wiring and further prevent intermittent failure, or total failure, still hiding fault location and wire.
Any help or debate is welcome.
BTW the backup camera never fails to operate normally, always turns on in screen in reverse except when COMAND unit is turned off.
I think we may have a fair chance to solve this excellent pickle!
We are working like blind ants trying to feel our way through with our limited intelligence.
My car has had this issue since the first week of service. Since then I have had to learn more than I wish I knew about this.
So far from my vantage, I can see the following.... :
The modern CAN RFK is actually correct about its faults (there has been many prior incarnation of rear cams).
These modules are acting up more so than RFK itself at the end of its long unshielded differential CAN lines.
Your time would be really well spent if ... you'd resolder the SCM and EIS but there's more to as well.
MB did a fantastic job in spinning this snowball.
What is the bus shared by RFK, SCM, EIS and COMAND... CAN-B or which is it??
These state of the art modules are in dire need of help for repair!!
So much much so both SCM + EIS help delay the TCU shift timings ("in affected cars") - Tranny SHIFT performance from poor shift to limp-mode is MB fare.
If you solve these RFK FAULTS you'll have a great Mercedes working like few... no part needed!
My current Assumption :
Something is causing CAN traffic jams near F-SAM that's affecting the VIP: ECU/TCU.
RFK is simply witnessing this chaos for us. Let's see where it leads us.
(Juan: remember how I say my COMAND boots super fast? My radio plays while the unit display still show splash star logo. I noticed because that was unusual)
So far, I have reworked painted GND and solderless pins, yoyo-ALT... next is try shielding noise out of CAN twisted pairs - My criterias:
- VIP Lines (SAM, ECU, TCU, ESP, ...)
- Long Lines (front to back to front)
- High-Speed bus lines (CAN-C, ...)
I think this amazing struggle game is organized around POOR TRANSMISSION leading to packet loss.
Great inputs very welcomed...
U016887 Communication with the electronic ignition lock has a malfunction. The message is missing STORED,
U014287 Communication with the rear signal acquisition and actuation module has a malfunction. The message is missing STORED,
U014787 Communication with the control unit "Head unit" has a malfunction. The message is missing. STORED
Xentry does show the number of instances of the U016887 of 246 times, the U014787 for 72 times, no code in Xentry is showing up for U014287. But I see no faults for the ECU, TCU, EIS, or steering. Just the RFK codes.
Benzninja did look at it from the Xentry point of view, and he did update the software in the RFK. But outside of that no physical issues outside of these codes have shown.
The car actually performs perfectly, and no issues outside of these codes. We drive it 5 hours interstate to a doctor out of state every month and she is a dream to drive, I get 34 mpg on the highway, plenty of power. I could live without the RFK if it did quit, as I never really use it, but my OCD wouldn't let me.
Furthermore I had the power to RFK cut from R-SAM for couple month without any improvement related to this issue.
That is to say RFK does not cause the other chaos experienced with MY'14.
In fact, RFK actually helps us witness what is really happening quietly under-wrap.
Surprisingly other modules dealing with the same module pairs do not report faults... EIS/SCM are built to be marginal an RFK tags them as questionable but other modules are trained to ignore the errors caused by loose pins issues.
Are you saying you had this issue, were you seeing any failures with other systems. If so what did you observe, what should I look out for. I will remove RFK and check solder joints as you recommended. Possibly reflow while I'm there anyway. You mentioned SCM, Are you referring to the control module or the switch module?
I reread your message in my mailbox, for some reason made more sense. I'm not sure which CAN line I'm checking as the schematics I have are vague, and The page I have doesn't show everything on that buss. I miss having Alldata.
If I understand, you are suggesting reflowing solder in all the modules, correct? I'm all about "No parts required"
Last edited by Rickman30; May 29, 2023 at 08:39 PM. Reason: Reread message in mail.
Right then, for me the big deal the tranny begun to shift in snaps (not chewing gum or bangs) at perfect timings.
Get busy read my signature. You will get well soon.
Like I said, car performs admirably. only issues are codes, no issues would be present if I'd not scanned system.
If I don't find anything with bus bar, I will look into broken solder joints in RFK module. If I don't find anything there I will check between RFK to camera connections and wiring, if nothing then, I can check the Keyless Go Module, the shifter switch, and the SCM, when I can get a breathing spot to remove the steering column, to see if mine may have looming issues with solder joints as your car.
My RFK has been reporting 2 and sometimes 3 faults since factory new.... meaning RFK does not need aging to become defective.
The only upside with this module is it doesn't seem to hurt nor help other computer troubles centered around the F-SAM.
While driving 5Hr long distance, you may want to display the battery sensor vitals on your dashboard.
Main Batt sensor: (+12.1V; -40Amps)
Few of these excellent cars have an issue whereby the ECU deep drains the MAIN + AUX batteries uncontrollably to 11Volts, no DTC!
This takes place during the "12.6V Float stage" on long drives, roughly after 45 to 60 minutes.
The whole car voltage then uncontrollably swings below 12.0 Volts while driving:
12.6V, 12.3V, 12.1V, 12.0V, 11.8V, 11.3V...
This defect comes straight from factory 0-Miles and has no effective fix that I am aware of.
The workarounds are to restart the car during a roadside emergency or to simply disconnect the ALT-LIN to allow perfect self-control.
As far as loose pins, this all began with environmental concerns, problem is the solution has created problems where none existed before. Lead free solder takes higher temp to apply and remove, leaded solder is far stronger and is more resilient to vibrations. In auto, many ECU failures were due to broken solder joints, problem since the 90s. Guitar tube amps and electronics, vibrations from high volumes and zealous musicians coupled with lead free solder is a recipe of "Guaranteed employment" for repair techs.
As long as the module can be opened without damaging board, a good magnifying lens or camera (one used in electronics repair) sometimes just using a meter can help find faults. Take leaded solder apply to broken solder, then with solder wick remove all the solder, flux apply leaded solder and chances of repeat failure has been greatly reduced. Learn this on Jeep PCMs. Except they use to fill the computer with a sealer you had to remove before repair.
I would rather have loose pins than green crusties, as cleaning those connections are hit and miss, even with Stabilant 22. as most are so tiny and fragile and easy to damage by loosening proper pin drag on connector.
Any voltage reading between 14.9V and 12.6V is perfectly good. Current shoukd go from 8Amp towards 1Amp: perfectly good!
If impacted everything looks great then turn into chaos after 45mn when the hot ECU goes unstable... hopefully not !
My battery is 4 years old CCA tested @ 58% of rated. I charged with smart charger starting amps much lower and goes into computer control much faster.
Spoke to a long time Mercedes Master Tech, said if no actual concerns, i.e. if car is not acting up in any way nothing to worry about, they can set codes as car ages, and only need to investigate when hard faults are set. I'm seeing soft faults, meaning computer will see variance outside set parameters, hard faults when something stops working as intended. He also said this car has seen those soft faults for 3 years ago and dealer found no issues during paid diagnosis. That was great information to have.
You report on voltage seems pretty good. The 10 Amps say that the battery is actively charging up. It's not high enough to suspect you have "drained by driving" issue.
You've figured turning the headlights ON does request a fixed 13.5V car voltage.
A well charged battery will see very little charge current from 1Amp down to 0A after full charge... PERFECT!
Can you let me know the module ID too and not just the name, more accurate that way if this module has sister models.
These 3 DTC's are regularly issued by "RFK": the rear Backup Camera with integrated CAN controller. Failed from factory, not a high mileage condition.
> Camera face-lift :
- On W212 prior to face-lift used a separate module hosted near rear seat to control both voltage and CAN lines.
- On face-lifts these functions are all integrated inside the camera itself. This is is what we are dealing with here.
> Fixing RFK faults...:
I have this issue so I have looked into this a bit. I think it is of minor importance but interesting to figure out. I had RFK power cut-off at R-SAM, this did not seem to help other module chaos.
The modules involved here (EIS, R-SAM, COMAND) are pretty important to keep humming. Poor COMS cause high-retransmit, that consumes bandwidth, that creates bottleneck, that cause poor performance and snowball issues and luxurious chaos.... I like none of this lemonade.
We all like great shortcuts, unfortunately here a Firmware update does NOT help this!
The way the RFK module logic fails like clockwork but camera appears to work well, makes me think the issue may be .... :
- long noisy twisted-pair of CAN lines or
- wicked CAN levels with poor GND or
- unfiltered noisy 12V power supply
Right now my favorite is #1: the noisy twisted CAN lines!
MB went to great length to exploit the noise generated by 3-Phase LPFP.
They use extra long Power/GND lines mixed within low signal lines. I've already added a local GND and separated harness cable by types (power, twisted, signals) near rear right passenger seat towards front/back.
My plan is to upgrade twisted-pairs to shielded cable:
- the main CAN lines from F-SAM to bus-bar.
- the bridge line between L+R bus-bars.
- the long RFK lines to bus-bar.
- Low speed CAN-B
- high speed CAN-C!!
This should bring a lot of peace between F-SAM /R-SAM to tame the Voltage-Yoyo and the soft-crashing "F-SAM/CGW" module that stays awake.
By looks of both files wiring diagram, the CAN BUS has nothing to do with video feed.
Perhaps CAN BUS B for diagnostic or some image layering instruction like the guided ruler/lines to N66/? module ?
- Video feed is analog through a quality shielded coaxial cable to COMAND/Display...
- RFK uses CAN-B for control and gather steering angle data from SCM or CGW.
- Knowing RFK complains about poor EIS COMS is chilling because these are important modules.
The codes are "STORED" because the condition happen intermittently.... that's consistent with noise, marginally low starting voltage
MB CAN BUS wiring topology has baffled me, because it is very much like a STAR, which most CAN BUS engineers would not agree to.
The drop line or stub or wire set from X30/30 distributor block to the N66/2 RFK module is I believe the longest wire run in the entire car. Perhaps 2-3 meters.
This goes against most advice, which do not use an X30/30 distributor block , but instead uses main bus line (wire ) routed as close to the device/node and hence the drop line becomes shorter.
Remember once I measured one of the distributor block and it has a built-in resistor for all connections ? That is another fact I don't understand because most CAN bus 101 will want
resistors of 120 ohms ONLY at each ending wire of main bus line or at both ending nodes if they have resistor built in.
I am attaching 3 documents. You know data transmission better than me. Its ur cup of tea
See what you can gather from those documents.
Noise. I remember having to reroute wires on board ship due to noise, or induced voltage from adjacent wires. I read what you said about the coaxial cable.
On guitar amps this is something we do to fix noise. With one caveat. The grounding shield of the coaxial wire can only be grounded on one end to shield inner wire from induced A/C voltage. The best way to see the noise and if the shielding is effective or not is with a scope. I’m inclined to lean towards noise, as the frequency of the fault seen in the ESMi such a high rate with just one startup after clearing. I’ve yet to see it an active fault it’s so intermittent.
I fear the best way is to drop steering column to access ESM to see fault on scope.better for wiggle check wires too.
Anyway all is on back burner for now, seems with old age other ailments like chronic pneumonia has put me on a Nebulizer along with much bed rest. I had planned on snatching modules and rework solder joints, but my wife told doc, and he gave a “Oh, HELL NO” speech.
I still need to do my trans service, I call a few shops including dealer, and no one does it correctly, they only do a partial service, only 6 liters of fluid, they don’t drain converter or cooler. The dealer here says it’s not required despite manufacture procedures says otherwise. So I will need to do myself to get it done right.
