Sponsored by: CARiD
Disc rotor wear
Old Jul 15, 2023 | 05:19 PM
- Mover -'s Avatar
E550
Disc rotor wear
I've had disc wear patterns on other cars I've owned in the past, but this is one I haven't come across before.
I switched from Brembo ceramic pads to semi metallic pads because I wasn't happy with the bite and fade braking from high speed.
No disc wear pattern problems with the ceramic pads, however, this has shown up after almost 2 yrs of semi metallic pads.
I know semi metallic pads really chew down the entire rotor fast from previous experience. These ones squeal like crazy at slow speeds during the 2nd year. No noticeable squeal the first year or very minor.
Has anyone seen this wear pattern on their front discs ? The outter lip is worn down more than the rest of the surface on the disc.
https://drive.google.com/file/d/1AS_...usp=drive_link
https://drive.google.com/file/d/1AYW...usp=drive_link
By the way, the calipers are 4 piston Brembos with pins holding the pads in place.
Old Jul 15, 2023 | 07:21 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
The picture doesn't show how uneven is the surface.
Evidently the holes show different wear.
Pull the wheel, find straight piece of steel, stick it to the rotor surface and estimate the groves depth.
Marking looks even around the rotor, so no immediate worry.
Old Jul 16, 2023 | 02:09 AM
S-Prihadi's Avatar
The wear pattern is common for drilled rotor, at least that is what happened on mine.
If you want longer rotor life when from new, clean often those holes. I clean mine often. Compressed air only . Wheel removed.
Old Jul 16, 2023 | 12:28 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
deep wear
lips on disc edges
The wear pattern on your drilled rotors looks really smooth. I'd renew the discs when pads are history.
Keep the same setup as that combination proves to be working well.
Old Jul 16, 2023 | 01:17 PM
kajtek1's Avatar
Word of caution. Even asbestos is no longer used on brake pads, the dust is harmful to human lungs.
Use brake cleaner, not compressed air.
Last time the holes in my rotors had baked stuff in them and I had to use drill to clean them.
The lips on the ends of rotors develop at about 50% of rotor wear. I just grind them.
Old Jul 16, 2023 | 04:46 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Mine look similar on my sport, I have semi-metallic pads on that, my luxury has the ceramics, they don't stop nearly as well, I actually have to watch if I go from car to car in a day, it's that different in stopping force and distance.
Old Jul 17, 2023 | 05:08 AM
ygmn's Avatar
2015 E400 Sedan
Per some brake pad sites and rock auto links they describe pros and cons of pad material
Below from Rock Auto which they pretty much show on every pad's info page.
From Rock Auto Brake Pad info page
S-Prihadi's Avatar
I wear my N95 covid mask when doing working around brakes
But I plan to buy 3M full face respirator 6800, because I do not like fumes of solvents like Brake Clean.
However this respirator is not for one wearing eye-glass, if we want 100% seal. The eye-glass kit is crazy expensive for simple plastic and steel rod.
Old Jul 17, 2023 | 05:49 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
yup I can do that to a rotor after a few months of driving.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jul 17, 2023 | 11:02 AM
kajtek1's Avatar
I don't think this is accurate. OE pads on MB are organic and they are famous for very good braking power, while providing decent life. Big dust is correct.
I did not log that many miles on W212 to wear the pads, but I did on W210, where I switched to Akebono, where ceramic should offer lower brake power.
I could "stand the car on its nose" with either pads, but Akebono after 120k miles on them, did show 30% of wear.
I could never tell the difference between braking power, but other member did some test and ceramic pads took longer to stop the car, than OE organic.
Old Jul 18, 2023 | 12:05 AM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
I thought the stock pads were semi metallic?
Anyhow mine looked like that with the grooves and what not, big lips on the edges. This is in front fyi not rear. The holes in mine were completely clogged. Anyhow replaced them with brembo disks and akebono ceramic pads and stopping is much better and smoother. Ive only had them on for 600miles and week and a half. My original pads were at end of life about 1/8" left. Pretty even wear little thicker on outer pad.
The rear disk were very flat and even wearing, think about 1/4" wear left.
Old Jul 18, 2023 | 01:50 AM
semi-mets
I too believe original mount are semi-mets.
The only way to get organic pads these days is the $10 special free lifetime replacement at some parts-store.
"OEM recommended mounts".... on FIAT's
W212 comes with semi-mets for sharp stops and help turn the soft-discs into rim dust.
Again best Japanese parts are allowed to stand ahead of the German managed quality:
Akebono, Denso, ​​​​​NGK, Mitsubishi, ...👍👍👍
Old Jul 18, 2023 | 09:31 AM
well my '12 luxury came with ceramics, at 30k miles currently, they are still more than half left, my sport came with semi-metallic, I clean brown dust from the '12 and not much, I clean black dust from the '13, considerably more.
Old Jul 18, 2023 | 11:40 AM
kajtek1's Avatar
I never check what kind of pads come on W212 and might be semi-metalic as I don't see much dust, but older models OE pads are organic for sure.
If you pay attention on parking lot, the 20 yo Mercedes do have dust-covered wheels and that was common problem when I drove W210
Old Jul 19, 2023 | 06:27 AM
ygmn's Avatar
2015 E400 Sedan
I Am sure someone makes a combo pad
aka semi-metallic + organic + ceramic so you get either best of all worlds or the worst?
I have seen other lists like rock autos where they add Brake fade, noise and other measurables and non-measurables
