cold start rattle
#51
Received 4,398 Likes
Joe,
When and if you are removing those injectors, may I suggest send it for testing and you get it cleaned and the piezo stack refresh while at it.
Read here : https://mbworld.org/forums/e-class-w...intenance.html
#52
Ok could use a quick sanity check here im confusing myself!
I got the car all apart last night no major issues
this morning I started putting in some new parts
i took out my old cam adjuster- this is right intake.
when I went to install the new one, its like the dowel pins for cam and timing mark are in a different spot than the original I took out?
here is a pic. I used white paint to mark timing mark on back.
timing mark at the bottom you can see cam alignment dowels aren’t in the same location. Is this normal to have to move cam? Am I over thinking it?
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_5205_801212780d79522abfede13f602f25fd2c3ad8d4.jpeg)
#54
2023 EQE 500 SUV electric and 2024 Jaguar F-PACE SVR 5.0L
https://a.co/d/8oazI6s
Darn good for an Intel Core i7 laptop.
#55
Received 3,374 Likes
MY'14 W212 M276 3.5NA @55kMi
This VVT gear should last given good working oil pressure.
#56
valves should not meet pistons
Timing is jumped when camshaft rotates forward. This is what good tensioners help prevent while VVT is unlocked.
#57
Think I have it now
Spent all day double checking my timing.
I believe, when I disconnected everything to change intake cam adjuster, the exhaust cam moved so I was out of time.
I followed the WIS for checking thru the hall sensor holes and knew I was off- confirmed my exhaust cam moved. So I took it back apart rigged up some tools to lock my cams in time using the lines on the back. Bolted it together and checking thru the holes looks good to me. Even had my wife double check she agreed they look centered.
#58
Nice team work! Aligning timing marks through sensor holes is ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
The last step is rotate crank manually to double-check for interferance.
#59
No you are not over thinking, you just don't seems to realize that this is VVT mechanism able to do approx 40 degrees variable degree.
Sold new the VVT would be in locked position, which if for my engine M276 3.0 Turbo and is only a few degrees different to M276.9 3.5NA.... mine is at +33 degrees
On M276.9 3.5NA the difference is only like 3 degrees to my engine.
So, what you have is a VVT not locking at its home base or zero position, and you are comparing it to a new one "parked" at its "zero" position.
Now that you have access to your camshaft, do check your tone wheel position. It can spin out of position.
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1183/shifted_camshaft_tone_ring_v1_873c89aebe842efa3c99e2b5e552b5b8337da2de.jpg)
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/1683x1144/tone_ring_ok_camshaft_v1_220ff18a841a39355c66f1c09cabd9c8f13e5d19.jpg)
This tone wheel being OFF can also create the DTC for out of spec timing between CAM and CRANK.
