Safe to drive in rain without skidplate?
Hey all,
Apologies if this is a stupid question but I wanted to be sure.
So I had to do some front end work and didn’t have time to put back the skidplate for the front.
Since it’s raining today and tomorrow morning, would I be ok driving in the rain without the fromt skidplate under the radiator for the time being?
Received 3,651 Likes
MY'14 W212 M276 3.5NA @60kMi
grumblings
You're doing what you have to do, right?
The W212 engine electricals have partial protection against water intrusion.
Eventually your chassis mat develop faults you can then read with a scanner.
Alternator is mounted right at the bottom.
MB4429 (03-07-2024)
2014 Cummins, 2014 E250 Bluetec
Probably the least time intrusive part of working on front end and ya left it off? Hate to say but will probably act like a tunnel for the rest of the under carriage as well which some parts are barely if at all rust resistant.
MB4429 (03-07-2024)
Received 1,793 Likes
What about the parts made from chocolate and cotton candy? Won't they melt?
While the undercarriage shields offer protection from the road, I think they are also provided to reduce road noise and improve the aerodynamics of the car for better mileage. I doubt anything will melt.
Just took mine off after being attached for past 6 months. lots of granules, smaller than pebbles, larger than sand. If you park in the same parking spot, you might use the opportunity to place a material under the 'open' engine areas to see if you have an undetected leak. the panels may contain small leaks. You can clean them if necessary. Use common sense for where you drive and how long off.
@CaliBenzDriver On my model, do you know what other electrical/critical components might be positioned low in addition to alternator? I want to wipe, then carefully hand spray bottom with de-greaser/de-oil without damaging any components. Hunting for a leak. TIA.
our car feature its most important connection: the main GND strap.
You need this to be as clean or better than battery connections - It is located, near tranny flywell and cats under the car.
The following 2 users liked this post by CaliBenzDriver:
ColonelKlink (03-07-2024),
juanmor40 (03-07-2024)
You're right. Maybe it's just me but I always struggle to put this piece back on.
CaliBenzDriver (03-07-2024)
Received 1,673 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 (W212 @100K), 2015 ML350 (W166 @96K)
So what else besides the alternator? AC compressor and electrical steering if you have it.
In the meantime, avoid water puddle at medium speeds since the splash from below may short an active electrical component. Regardless of how much water-proofing the connectors have, the wire is coming through so can the water.
The following 2 users liked this post by juanmor40:
CaliBenzDriver (03-07-2024),
Yeah, I pretty confident that the engine compartment paneling is just to help with weather proofing the engine bay. For a short time it's likely that it won't cause issues but I wouldn't keep them off for long since it will expose a lot of components to a harsher environment them they were designed for.
I don't think the US spec has the undershields installed (code 481). It's a standard in countries with bad roads (like mine) and it's a big and heavy metal plate covering the botton of the engine.
