Sponsored by: CARiD
My ghost codes p0171 and p0174
Old Mar 25, 2024 | 04:42 AM
Andreas B's Avatar
W212 E350, W208 CLK320
Hello.
I've had some "ghost codes" in my car for a while now. It is p0171 and p0174. The car runs just fine, idles fine and seems to be in allright condition. It may surge a little when driving speeds of 110-130 kmh.
These codes can come and sometimes go away without me interfering. Last time I got the codes was maybe 4-5 months ago and they went away 1-2 days later. Yesterday they were back again. The codes seems to appear when the car is idling, reversing or driving at veeeery low speeds. I had some problems with my oil cooler and was losing oil and coolant. That is fixed (probably not related to the codes at all). I have had a smoke test and the engine is sealed. Spark plugs are changed, oil and filter is new.
What can I do now? I want to first take a test of my MAF and 02 sensors to see if everything is ok without just replacing the parts if they are working just fine. Is this possible? Any suggestions.
Hope some of you guys can help me
Old Mar 25, 2024 | 05:49 AM
streborx's Avatar
Top Answer: 1
G550
A quick lookup on these codes indicate possible oxygen sensor malfunctions. Are you getting a CEL indication on your dash?
Old Mar 25, 2024 | 06:21 AM
Andreas B's Avatar
Yes, yellow non flashing CEL.
Old Mar 25, 2024 | 06:34 AM
streborx's Avatar
Top Answer: 1
G550
My guess is the O2 sensors -- they eventually fail. Probably not much more cost to replace than to have tested.
Old Mar 25, 2024 | 06:41 AM
Andreas B's Avatar
Ok I see. I have four of them on my car. Replace all or just the two upstream sensors first?
Old Mar 25, 2024 | 07:01 AM
streborx's Avatar
Top Answer: 1
G550
Now you're asking questions above my pay grade (lol)! You can certainly start with the 2 upstream sensors and see if they solve the problem.
Old Mar 25, 2024 | 03:05 PM
Andreas B's Avatar
Thanks. Will have it checked out!
Old Mar 25, 2024 | 03:13 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
low fuel pressure
Hello.
These two separate codes are screaming about the same thing: TOO LEAN.
check your fuel pressure... tired pump/filter.
Old Mar 26, 2024 | 05:13 AM
Andreas B's Avatar
Thanks for your reply! Going to get my gearbox serviced next week and told my mechanic to also check the condition of the o2 sensors. I can also ask him to check the fuel pressure. If something is not right, is it an easy fix?
Can it have something to do with the high pressure fuel pump, it has always been noisy according to a friend of mine. Also, can the fuel pressure result in surging? Is the MAF to be suspected too?
Old Mar 26, 2024 | 04:27 PM
PRESSURE READOUT
Exactly, these are all good questions to answer with the process of troubleshooting.
One thing is causing this right now. Not 25 different parts for no results.
My money is on fuel tank supply pump pressure us limited by dirty filter.
Lambda and MAF low down the list.
You're going to find RICH TRIMS asking for fuel.
Take 5mn to read out FUEL PRESSURES LOW + HIGH with your handy $150 scanner.
cake walk?
Old Mar 28, 2024 | 05:05 AM
Andreas B's Avatar
cake walk?
Thank you! Will definitely look into it!
Old Mar 29, 2024 | 06:56 AM
Andreas B's Avatar
cake walk?
These reading are probably too high?
Old Mar 29, 2024 | 03:51 PM
Yes, exactly!
High LTFT confirms my previous post.
Now read your fuel pressure.
Note fuel trims are unbalanced.... so something additional may be involved.
Old Mar 30, 2024 | 04:03 AM
Andreas B's Avatar
Highly appreciate it! I was in a bit of a hurry when looking at the readings, but I could not find the fuel pressure data (cheap ODB Bluetooth) . You can only speculate, but what is the most likely part(S) to cause this? My car is going to the shop April 4th, will keep you updated on what the verdict is.,
Old Mar 30, 2024 | 03:03 PM
Highly appreciate it! I was in a bit of a hurry when looking at the readings, but I could not find the fuel pressure data (cheap ODB Bluetooth).
Your high LTFT say the engine is not getting enough gasoline or too much air.
That clearly means your ignition is good and your lambda are working.
Diagnose/repair the fuel delivery first then see what happens to the imbalanced value. I think these are two distinct issues.
I am guessing fuel pump filter is packed shut.
Old Apr 8, 2024 | 03:00 AM
Andreas B's Avatar
My mechanic told me the fuel pressure was fine. He told my to come back later to get a thoroughly check of the car. Will post here when I know more.
Old Apr 8, 2024 | 03:59 AM
Ok if fuel pressure is good and you've got high positive trim on a lean engine then you've got an intake air leak.
It's time to use a smoke machine to look for leaks.
Old Apr 8, 2024 | 05:15 AM
S-Prihadi's Avatar
01. What is the pressure he got and did he test it at 1st and 2nd gear maximum RPM pull too ?
02. The pressure is from a scanner ( at fuel filter pressure sensor ) or using another mechanical gauge at the engine bay fuel fitting Tee ?
Old Apr 10, 2024 | 01:04 PM
Andreas B's Avatar
Thanks for the answers. He did a smoke test a couple of months ago and did not find any leaks. Not sure how he tested the fuel pressure though. Will ask for the readings next time
Old Apr 14, 2024 | 08:52 AM
Andreas B's Avatar
I have suspected the PCV and the cam plugs for a long time. My engine has had the tendency to drink a lot of oil, but without visible signs of leaks. I park in my garage so I would see something on the floor if that was the case. I also understand that it's not uncommon for these parts to fail on the M272 engine, which also can cause P0171 and P0172 codes,
Maybe it's unrelated, but I randomly checked emission status and got a FAIL on the catalyst.
Old Apr 14, 2024 | 01:05 PM
confirm fuel pressure yourself
You have lean faults and you reported your mechanic tested fuel pressure and intake leaks.
In addition you're getting catalytic monitor incomplete.
You're now suspecting PCV or plastic cam plugs.
At this point... I would take 5mn to read your fuel pressure for yourself before considering PCV replacement job.
Use your scanner to check fuel pressure both at base idle and also under engine demand to validate filter is not saturated by tank particulate.
You can ignore catalytic status because engine management is unable to run normally. After faults are fixed cats will get a chance to burn off contaminants better.
Old Apr 14, 2024 | 02:21 PM
Andreas B's Avatar
I can't find the fuel pressure levels on my bluetooth scanner. I would like to see how the readings look because I want to solve this problem now. However, I got interested in the PCV because that can throw a P0171, P0172 code in addition to my oil loss. It is very rare, but sometimes when driving in higher speeds at longer distances I can smell a little sulphur/egg probably from the cat. Is this because there is too much oil getting burned, and the cat is unable to properly take care of it?
Old Apr 14, 2024 | 05:19 PM
You can replace the PCV and the cats but
I don't think it will directly help your two lean fault codes.
The non-turbo W212 V6 gasoline engines use a simplistic PCV system that burns quartz of oil through the intake. This is a commonly known issue caused by high blow-by.
You may want to use an "MB Approved" 5W40 oil instead of a less viscous 0W40.
Old Apr 15, 2024 | 12:42 PM
Andreas B's Avatar
I understand. Maybe I will change the oil. Will the 5w40 be ok in the winter as well as in the summer? I live i Norway and it can get very cold here in the sintere.
Old Apr 15, 2024 | 01:42 PM
0/5W-40
I live i Norway and it can get very cold here in the winter.
I am sure you have specific products in your region to handle harsh winter climates. Oil, tires, wipers, gasoline are formulated to match loval needs.
Look at your owners manual for oil specifications.
Your local MB specialist knows what works best, right?
