Would you buy this 2011 E350?
I'm looking at this 2011 E350. Would you buy it given the below information?
The car is not local to me so I got a inspection service to check it out. The inspector said the car drove fine in the test drive. There were signs of repairs as paint thickness is not consistent but the inspector said structurally it is not problem.
Car history report is attached. Here's the link to online condition report.
Below is the summary of the service history.
I don't know what type of driving happened in the past (e.g. long trip, short trip etc...)
In short, the inspector said he would give a thumb up for the purchase.
Asking price is $30,000 AUD.
It's rare to see this model with less 60,000 KM on the market. The options come with the car are good (AMG styling package, AMG wheels, all the necessary amenities).
My concerns are the car not getting driven much & services are behind the recommended time by a lot.
Thanks for your help!
You should also review the car's configuration from the factory by entering the VIN at www.lastvin.com. Here's a link directly to the car: 2011 MERCEDES-BENZ E 350 (212.056) - WDD2120562A408169 (lastvin.com)
I added the pics of service book in my original post. Looks like the oil was changed at servicing with 229.5 oil.
I don't like the fact that the engine oil interval was so irregular, but to be honest, since this is a NA engine you should be fine.
There are a bunch of stored failure codes but the vast majority are related to low voltage. So I guess the car had its battery used until it died and no one cleared the faults after it was replaced.
The best place to get what you need is from @BenzNinja (www.benzninja.com). He not only has the most stable and reliable versions of the software, but he can also run diagnostics, code, configure, and update your car's software remotely. He can also provide links to reliable hardware you will need.
When you say transmission service, it means a full flush & fluid change, right?
Thanks for your tips on the Xentry, WIS & EPC, I will look for ones if going ahead with this purchase.
I prefer the angular quad headlight & classic grill over the softer post face lift look. There are good kitted post facelift that I would love like this one too though. Just a different price range.
Ideally I would love a 2012 pre-facelift with the M276 instead of M272 for more juice. I'm coming from 2013 Mazda 6 with 138KW/185hp (98kw/tons) to M272 200kw/286hp (120kw/tons) so it's still an improvement.
From the VIN spec sheet, it has all the things I know that I need. MultiContour & heated & cooled seats would be nice too but I can live without them.
I've been looking for one online semi-regularly (once a week) since start of the year. Pre-facelift one with low mileage, has the right color, AMG styling package... is actually pretty rare. All pre-facelift is most likely well above 100K kms. I know mileage may not be that big of a deal if it's a well-maintained but I'm a newbie so it's just safer to look for a low km ones.
Do you guys have any concerns of plastic parts degrading & cracking when buying an old car? If it's an inevitable, how much should I set aside roughly for those?
Also I read somewhere along my forum scouring that the USB port is not powerful enough to charge phone. Can anyone advise on this?
Thanks everyone!
https://www.carsales.com.au/
You do not want to take the car to a shop that is going to force a flush under pressure through the transmission. Transmissions with the A89 option code use ATF-134FE (blue) fluid. If an independent shop does the service, make sure they know that. The older red fluid and newer blue fluid are NOT compatible.
Here's a link to the FCP kit: Mercedes 722.9 Transmission Service Kit - Fuchs 7229LATE | FCP Euro
Thanks for the help and advice. Finally got the car in hand last week.
What a beauty! Looking even better in real life.
I had the transmission serviced ($660 AUD at an indi instead of $900+ at a dealer).
Also got the brake and rotor replaced as well.
The Bluetooth was not working properly (connected but audio streaming keeps skipping) so I bought this INVERY bluetooth unit and that solved it.
Haven’t done any “spirited” drivinng yet but loving the comfort, quite and premium feel it brings. The smooth acceleration & the way it absorbs bump 👌 HOLD function is so handy.
I was thinking of adding spacers for a cooler stance but the wheels are already pretty close to flush already.
Probably will get a quote for the wheels. If it’s a bit much then I may wait a bit until I get it fixed. It feels like just the clear coat coming off, not clear scratch or rash so not super noticeable from afar.
Enjoy your new car!
Enjoy your new car!
Enjoy the new ride.
EDIT: Ugh! Never mind. I see that is Andre's car, not the OP's. Yep, the 7-spoke wheels are NICE!
Yes Andre`s and yours are the same and I have the same exact rims on my E350, the ones OP has, I`ve never seen them in U.S., too bad because I really like them as well.
Edit: Ha ha haa I think we keep misunderstanding each other, I see what you mean now lol. My bad, read your message too fast. But one thing thou, if I had those 7 spokes and Andre`s color pewter/gun metal combination, that would be a killer.
Tried to mark 7 spokes with yellow
