Sponsored by: CARiD
Misfire Cylinder #1, brand new coils and spark plugs. Please help!
Old Oct 3, 2024 | 05:09 PM
GOPHIMBO's Avatar
2011 E350
Hey guys, my 2011 E350 got 140k miles and it's been giving me misfires on several cylinders. Given, the high mileage, I decided to just replaced all 6 cylinders with new Delphi coils and Bosch OE plugs. Now I'm only getting misfire #1 and the engine idles rough on start up with code P0301. What else could it be? Any help is greatly appreciated.
Old Oct 3, 2024 | 05:20 PM
JettaRed's Avatar
Veteran: Army
Did you also replace the spark plug boots with the coils? You have the M272 engine, right? Two other things to check would be the compression on cylinder 1 and the fuel injector on cylinder 1. The good news is that if it's a leaky injector, they are relatively cheap in comparison to a GDI injector.
Is the P0301 code the only code? What about fuel trims for cylinder 1?
Old Oct 3, 2024 | 05:33 PM
GOPHIMBO's Avatar
2011 E350
wait, don't the coils come with new boots? I didn't reuse the boots.
yes, M272 engine.
How do I check the compression and fuel injector and fuel trims for cylinder 1.
P0301 is the only code.
Old Oct 3, 2024 | 07:07 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
yes, M272 engine.
swap coils first, and see if the misfire follows and if not check that plug and move it and see if it follows. this will rule out of bad new part.
Old Oct 3, 2024 | 07:18 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
first swap current parts between positions, and avoid introducing new variables in the diagnostic. Even when swapping you may fix (poor contact), or damage/disturb working parts. Always minimize number of variables. New parts does not mean good parts.
Old Oct 3, 2024 | 08:21 PM
JettaRed's Avatar
Veteran: Army
yes, M272 engine.
There are a couple of ways to check compression. One way is a comparative compression test with XENTRY. XENTRY sets the engine to not start while you crank it and then measures and compares the speed of each cylinder. If they are all relatively close in rpm of each other and at around 200 rpm, then compression is good. If cylinder 1 spins much faster, say 50 rpm faster, that means there is less resistance, and the cylinder is not sealing well. You have low compression on that cylinder, which will cause a misfire.
The other way is to get a physical or mechanical compression test kit. There are lots of YouTube videos showing how to do it. Cylinder compression should be around 150 psi +/-25 psi, but all cylinders should be close to each other.
Testing the fuel injector is easiest done by moving it to another cylinder. I said easiest, not easy. Still, you are working with a traditional, non-GDI fuel system, so replacing all the fuel injectors with matched and balance injectors is an option. Did that on my 2004 SL500 and the car actually ran better with better gas mileage.
Lastly, you will need a scan tool that will show your LTFT overall. (It's an OBD standard so you may be able to do it with a generic scanner, but generic scanners are usually a waste of money on a Mercedes.) If Bank 1, where cylinder 1 resides, is significantly different from Bank 2, then you know you may have a bad injector. If the trims are a negative value greater than 10%, you have a problem. If the trims are within +/-10%, you're probably OK.
All the other recommendations are good first steps in trying to isolate the problem.
Old Oct 4, 2024 | 04:34 AM
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 coupe
As mentioned above, new doesn’t mean without fault. I had one faulty new plug out of 8, brand new in Bosch box. I bought another new plug and solved that mystery. I also believe we sometimes wiggle/reseat a wire connection and resolve issues.
Old Oct 4, 2024 | 09:32 AM
JettaRed's Avatar
Veteran: Army
Originally Posted by tepelena
It sounds like the issue might extend beyond the coils and spark plugs you’ve already replaced. Possible causes for a persistent misfire in cylinder #1 could include a leaking or faulty fuel injector, a vacuum leak around that cylinder, or even an issue with the compression such as worn piston rings or valve seats given the high mileage. Additionally, wiring problems or a malfunctioning ignition control module specific to cylinder #1 could be contributing to the rough idle and persistent misfire. I recommend scanning the vehicle for fault codes using the engine control unit (ECU) as well as other related modules like the fuel injector control module and the ignition control module. There should be fault codes stored in one or more of these control modules related to your issue. You might need to take it to a mechanic, but if you want to figure this out yourself, getting a full system scanner like youcanic’s full system scanner is ideal for diagnosing all systems comprehensively. Just be careful to use a full system scanner, or if you use a generic fault scanner such as the Innova 3100, you might not see all fault codes. Have you already checked the fuel pressure and injector operation for cylinder #1?
You're pretty much repeating what has already been said. However, what is a "vacuum leak around that cylinder" mean? Can you provide clarification? Also, what is a "malfunctioning ignition control module specific to cylinder #1"? I was unaware of such a device. What is the control module designation? I'd like to look it up in XENTRY to see if there is a test for it.
Old Oct 4, 2024 | 09:46 AM
JCM_MB's Avatar
@JettaRed , I could only guess he is referring to the ECU controller for the specific injector, say -> the pin at the ECU connector is not sending the correct signal because of something internal.
I have seen that the injection controller is damaged on the internal side of ECU on other brands.
Old Oct 4, 2024 | 02:45 PM
GOPHIMBO's Avatar
2011 E350
I picked the best looking plug from the old set and swap out that new one. Idling much better, no CEL and no misfires. I'm gonna drive it for a few days to be sure. So far it look promising! Quality control issues from Bosch i guess.
Old Oct 4, 2024 | 02:46 PM
GOPHIMBO's Avatar
2011 E350
I think you might be right on this one. I picked the best looking plug from the old set and swap out that new one. Idling much better, no CEL and no misfires. I'm gonna drive it for a few days to be sure. So far it look promising! Quality control issues from Bosch i guess.Thanks man!!
Old Oct 4, 2024 | 04:06 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
NEEDLE IN A HAY STACK....
Nothing's simple when tons of details matter.
Sorting out what may be wrong is non trivial to guess corrective actions.
Improving Bosch's best systems is a near miracle. Team MS! rocks.
Old Oct 6, 2024 | 01:48 PM
Arrie's Avatar
Happened with my Durango with the 3.6L V6 engine just a month ago:
I got the misfire on cylinder #2 with rough idle. Clearing the code it ran just a few hours fine, but problem returned.
- Replaced the spark plug but no help.
- Moved the cam shaft adjustor magnets between the banks with no help.
Did a little research and found out about the VVT solenoid problem. This engine has this solenoid for each bank and after replacing it on the bank for cylinder #2 the problem went away.
So, as the VVT solenoid is for the whole bank of cylinders and the error code was only misfire on cylinder #2 it could be that this code does not mean only cylinder #2 just because this VVT solenoid works all the cylinders in the same bank.
So, in this MB case perhaps the problem is with the camshaft adjustor magnets especially is the problem comes back.
I don't know if MB engines have that VVT solenoid...?
Old Oct 6, 2024 | 02:25 PM
JettaRed's Avatar
Veteran: Army
Yep.
Old Oct 6, 2024 | 02:28 PM
Yeah, your Dodge is using a slightly different version of the same Bosch system. Perhaps more robust with less parts.
the M276/8 use 4x independent VVT Gears positioned by 4x oil solenoids and 4x Camshaft sensors.
The variable camshat timing works based on available oil pressure... so clean + cooled oil is essential to reliably position camshafts based on pre-learned maps.
Does your Durango feature a variable oil pump as well?
Old Oct 6, 2024 | 05:52 PM
Arrie's Avatar
Yep.
h
These are not cam shaft solenoids what I am talking about. These are cam shaft adjustor magnets that the MB engine has as well as the Dodge engine, but the Dodge engine also has VVT cam shaft solenoid that looks like picture below. That is what was broken in my Dodge causing cylinder #2 misfire. As the same cam shaft works valves for all cylinders in the same bank the misfire could have been in any of the three cylinders, but it calls it only for cylinder #2, which is the first one in front on driver side.
I have seen several posts in different forums about this Dodge engine and they all have it as cylinder #2 misfire. I just cannot believe that if the culprit for this problem is this VVT solenoid it causes misfire only in Cylinder #2 when all three cylinders have the same cam shaft that this solenoid adjusts somehow.
I do not know if MB engine has solenoid that does this function.
Old Oct 6, 2024 | 05:59 PM
Arrie's Avatar
I don't exactly know how our VVT system works but I do know that each bank has only one cam shaft for intake and exhaust. These shafts work for all 3/4 cylinders in the bank. Any adjustment of the cam shaft works for all cylinders in the bank simultaneously.
I do not know if the Dodge has variable oil pump.
Old Oct 6, 2024 | 06:20 PM
MISLEADING... FAULT CODES
we understand your point about Durango ECU Misfire code for one cylinder when in fact its not one cylinder but the whole cylinder bank that is affected.
-- You are right about fault codes being MISLEADING... this is so often that one may begin to think "purposely misleading".
Existing codes are misleading and missing codes as well. Some faults are concealed under wrap to be left ignored.
-- Recently I mentioned the "CAN traffic jams" caused by carefully located marginal connections. It detunes no less than both engine + tranny timings.
-- Oil pressure sensor is missing all together, no fault there either.
-- Voltage yoyo is another sweet chaos in charge of X-Mas trees. No warning: all good!
-- Recently we were looking at tranmy module codes saying "solenoid valve fault" when in fact it's bad gearbox K3 clutch controlled by solenoid.
Once you know, you troubleshoot systems before anything else.
Old Oct 6, 2024 | 06:57 PM
JCM_MB's Avatar
h
@Arrie , perhaps you are referring to this one
Those go in the center of the VVT. Perhaps others can explain how the "camshaft timing solenoid adjusters" interact with the "camshafts timing solenoid pressure valve"
Old Oct 6, 2024 | 07:55 PM
these parts are the oil valve that the VVT Solenoid are pressing against to drive oil pressure into VVT Gear to rotate its Camshaft position FWD/RWD.
The standard rattle wear items are
-1- the VVT Gear lock pin that suffers from low oil pressure
-2- the chain tensioners that become limp from abnormal oil pressure
-3- when rattle is ignored the camshaft has a loose ring that cause its failure.
-4- CPS sensors quietly leak oil into harness for $10k repair.
Better oiling is thought to prevent these unnecessary failures related to limited oil pressure.
Old Oct 6, 2024 | 11:37 PM
Arrie's Avatar
Could be.
In the Durango engine fix was easy. Part was little over $100 from AutoZone, job was about 30 min that required removing the air filter housing to get to this solenoid.
If the problem is with the other bank solenoid (passenger side) the job is a bit bigger as the intake manifold has to be removed to get to it. It seems still much less than if these need to be changed out in the MB engine, but I do not know for sure. Hopefully never comes up and the most serious issue will be the cam shaft magnets...
Old Oct 7, 2024 | 11:13 AM
GOPHIMBO's Avatar
2011 E350
So it was a false positive. CEL and multiple misfires returned. cylinder #1, 3, and 5 now. There's low idle and car doesn't seem to want to accelerate from stop. Time to check the fuel injectors? or maybe oxygen sensors?
All ignition coils and spark plugs are new btw.
Old Oct 7, 2024 | 11:31 AM
JettaRed's Avatar
Veteran: Army
What DTCs is the car reporting? Are you using XENTRY? Have you done a compression test?
Old Oct 7, 2024 | 12:18 PM
GOPHIMBO's Avatar
2011 E350
So far the DTCs are P0301 303 305 with my generic ODB scanner.
is Xentry a Mercedes specific scanner? Never heard of it before.
I haven't done compression, you posted a kit from Amazon earlier. do you recommend that or just get the Xentry scanner? Thanks for the help!
Old Oct 7, 2024 | 12:45 PM
JettaRed's Avatar
Veteran: Army
XENTRY is the official diagnostic tool used by Mercedes dealers. It not only does a deep scan of your car, it also has built-in diagnostic procedures. It is also used to do some configurations, resets, recalibration of certain functions. However, you limit what you do with it unless you are certain what you are doing. Doing a search of XENTRY will return lots of results. It is actually the software portion of the Star Diagnostic System comprised of a Windows 10 laptop, a C4 multiplexer with DoIP, and XENTRY. The multiplexers are usually Chinese clones, so you have to be careful what you get. The best place to acquire the components is to join the BenzNinja Club and get recommendations from @BenzNinja . Otherwise, you can search this forum for recommendations of a Mercedes-specific scanner.
