Sponsored by: CARiD
Battery warning on dashboard
Old Nov 13, 2024 | 03:17 AM
kolion's Avatar
1996/7 E230 Mercedes Benz
Hey, i got this warning whilst driving, soon the stereo switched off and eventually power steering was a bit hard. My instinct was that its the battery since i have not changed since i bought the car in 2015. So i changed the battery, but the warning is still coming and power steering is hard. What could this be?
Old Nov 13, 2024 | 06:45 AM
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 coupe
What model and year is this car? Does it have Aux battery too?
Old Nov 13, 2024 | 07:59 AM
trigital's Avatar
W213 All-terrain
Could be the Alternator and/or ESP module.
Old Nov 13, 2024 | 08:11 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
from the photo, the clock tells me it's a pre-facelift 212, did you reset the codes? the battery change should have rebooted the chassis, if you didn't delete the codes, it should go away after driving a bit, if you did, you may have an alternator or voltage regulator issue, this is not the warning for low auxiliary battery in the left side of dash for your car.check battery voltage running and off.
Old Nov 13, 2024 | 08:25 AM
JettaRed's Avatar
Veteran: Army
Get a Mercedes specific scanner and scan for codes. Make note of them and then clear them. See which ones come back.
As @trigital mentioned, it could be the alternator. When either a battery or alternator goes bad, it puts an extra strain on the electrical system. Mercedes are particularly sensitive to voltages. If your 10-year-old batter was failing, that could damage the alternator, which supplies regulated voltage to the car once running. You may want to get some tools if you want to DIY. You should get both. Be sure to apply coupons. They will cost you less than a trip to the dealer to tell you that you need to replace the alternator.
If you are still having problems, I recommend reaching out to BenzNinja for professional support using XENTRY.
Old Nov 13, 2024 | 08:29 AM
trigital's Avatar
W213 All-terrain
For checking the alternator a multimeter is enough, easy fix and relatively cheap. With the ESP could be more complicated.
Old Nov 13, 2024 | 01:05 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
1996 low voltage
This is a 1996 model... things are going to be a little different than our tricky W212.
A positive step would be to look in the matching chassis forum.
It's always a bad idea to use the car alternator to charge a drained battery. It puts out way too much current. ALT only regulates voltage, not current that's unlimited under 100Amps... a battery killer!
OP may be dealing with the aftermath of that or bad regulator brushes, toasted diodes rectifier...
Voltmeter showing above 13V would be nice. Oxidized single main GND strap is always good to deal with a secondary strap.
Old Nov 13, 2024 | 02:53 PM
My 2002 0r W210 had this dash
