Sponsored by: CARiD
W212 Purchase Advise
Old Nov 29, 2024 | 02:29 PM
pierno80's Avatar
S560
Hi everyone,
I am currently in the market for a 2015-2018 E350 / E400 Wagon for cargo space and daily driving. I desire mileage between 65K and 80K, which is a bit challenging in California based on the average 12K annual drive. What are the major mechanical failures I should be aware of before purchase? In comparison between the E350 and E400, which engine is more reliable? I heard that W212 Wagons are generally more reliable than W213 Wagons. Is this true? Thanks in advance for your comments.
Old Nov 29, 2024 | 09:26 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
EVERYTHING'S OPTIONAL
Originally Posted by pierno80
Hi everyone,
there is generally no major mechanical failure unless 4-Cyl turbos are involved.
Instead the W212/S212 cars are built around a set of system options that each disfunction on their own schedule.
The theme is basic options require cheaper maintenance than the more advanced ones that require premium service by specialists.
The same dealer hourly charge is applicable to all vehicles meaning 80kMi maintenance is undiscounted premium rate.
212 Engines range from Diesel to turbo V8
Suspensions from steel springs to AirMatics
Transmission from RWD to 4Matic
Sunroof or Pano-roof
Seats from vinyl to dynamic bolsters
Cruise control or radar based DistronicPlus
Rear Blind spots integrated with self-steering
Autonomous breaking or not.
Brakes are either basic rotors/floating calipers or advanced drilled rotors with multipistons calipers.
No camera, rear camera or 360° cameras.
Whatever options your chassis has is what you got. Systems are built not be "plug-n-play" upgraded.
The classic M276/8 nagging is centered around cold engine rattling from worned timing components.
What ever model you purchase will look good in sport or comfort trim.
Old Nov 30, 2024 | 02:35 AM
BenzV12's Avatar
W212 FL
Those are solid cars but some Mercedes-Benz common replacements may need : low pressure pump (if you notice a fuel smell when the engine is cold ) , engine & tranny mounts .
Old Dec 6, 2024 | 02:20 AM
Jack McCarty's Avatar
2011 E350 4MATIC Estate Wagon
Advice on acquiring a 212 Wagon
If vibrations enter the cabin because of leaking oil mount bags & the solid rubber transmission mount, replace them on W212.
Vinyl interior called MB-Tex is inferior to earlier
vinyl seats & commonly split in driver's seat.
My upholstery shop ordered an OEM seat cushion & installed at a cost of $600.
i then ordered 2 sheepskin covers @$550 each.
The wood trim didn't have the sunscreen component in the wood varnish which caused the wood to fade badly. I bought $1300 replacement
pieces & had all wood replaced.
A recent court order forced MB to offer restitution
to owners / see dealer for details.
Old Dec 6, 2024 | 11:22 AM
JettaRed's Avatar
Veteran: Army
On the east coast, but give you an idea of what's available.
This is a 2019 with 75k miles, but it is also an E450, which has the superior M276 engine.
https://www.cargurus.com/Cars/invent...4/NONE/DEFAULT
Old Dec 7, 2024 | 05:48 PM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
Hi everyone,
Please read my Comprehensive Guide for W212's
Can be found in my Profile > Thread
Old Jan 11, 2025 | 08:05 PM
tobybul's Avatar
85 300D, 84 300D, 96 C220
I'm trying to look for your Comprehensive Guide for W212's but can't find it. Can share a link or pm me the link please?
Old Jan 11, 2025 | 08:27 PM
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
Few things to remember buying a used car
1)- Once you narrow down the vehicle you are interested in, do your research and find out the trouble spots on that particular model
2)- Research further and find out what those troubling issues are, how that happens (age, use etc) and the cost to fix it?
3)- You don't buy a used car, you buy the owner! If he's responsive and answers your concerns, you are good or else move on.
4)- Buy a well maintained car with records
5)- Focus on dry and avoid salt belt states
6)- Invest in a PPI and have the shop focus more on the troubling spots you have read.
7)- Pay attention to Oil changes, tires, brakes, suspension and any oil leaks
8)- Always see the car in person regardless who's selling it as few hundred dollars spent earlier could save you thousands and lots of headache later.
9)- Lots of cars, even desired ones on the market have close to 100K miles if not over, so be careful considering one of those. It would be hard to sell a car once it crosses the 100k so be careful
10)- Spend money upfront and buy a nice car or save money and buy a cheaper car and spend thousands later to fix all the neglected issues
Hope that helps
Old Jan 12, 2025 | 02:28 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
https://mbworld.org/forums/e-class-w...uide-w212.html
Old Jan 12, 2025 | 02:30 PM
We got our 2016 E350 4matic wagon in late 2020 from a dealer in Santa Fe (we're on the left coast). The car was a CPO with only 24000 miles, we bought it entirely over the phone and email, sight unseen. The car has been perfect, had zero problems to date, we're around 68000 miles now.
