Sponsored by: CARiD
2014 e350 updates
Old Dec 16, 2024 | 10:25 AM
ARTAARON's Avatar
Mercedes-benz e-class 4matic sedan 2014
2014 e350 updates
My fuse box under the hood, the fuse number 23 takes a 40 fuse but my car is rejecting it.
2. I want to install push to start .. is it possible
3. I want to install a remote to start kit
And suggestions please
Old Dec 16, 2024 | 11:54 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
3 - go to an installer. As for push start....you got a 14 with out it? How?
Old Dec 16, 2024 | 12:06 PM
ARTAARON's Avatar
I don't know about your question as to how I don't have it
But just don't however I'd like to
Old Dec 16, 2024 | 12:11 PM
ARTAARON's Avatar
W212 fuse box 23 slot fuse number 40 causes my car to smoke .. however my manual states I should use fuse 49 .. can use a lesser number like fuse 30 or 25 or 15
Old Dec 16, 2024 | 01:29 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
COOKING FUSE#23 - Start button....
it's very confusing but I understand your front fusebox is burning #23: a 40Amp.
> NO CHOICE:
The fuse rating is designed to protect the circuit it's feeding.
Don't upgrade or downgrade!
Use only the original size: no more no less
> WHY FUSE BURNING:
This can be a tough question to answer!
Something's causing the circuit to use too much power.
What circuit is protected by fuse #23...?
Search for failed modules, devices or shorted wiring.
> Electronic START option :
It will be easier to add a "remote start" than retrofit a missing KeylessGo option.
Mercedes W212 computers are not plug and play... it requires programming CGW and a few more undisclosed modules.
Old Dec 16, 2024 | 01:45 PM
Bah! Just wrap a 60amp in some aluminum foil and go for a drive.......
Old Dec 16, 2024 | 07:30 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
You may need this long term
https://fuse-box.info/mercedes-benz/...uses-and-relay
Now, for #23
Have you scanned the vehicle to see which module is shorted to ground
Old Dec 16, 2024 | 07:59 PM
gas engine:
... this 20A fuse aiming towards the ECU circuitry
- Not a 40Amp protection.
Old Dec 16, 2024 | 08:38 PM
JCM_MB's Avatar
If there was a 40A, you bet something is fried by now
Old Dec 16, 2024 | 09:52 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
does your car have a keyfob like this that you insert into a hole in the dash and turn ? If so, you're missing the push-to-start button that fits in that same hole, .
this button can be had for liek $25 on fleabay, it fits all 2014-2016 (at least) Mercedes. Note however, your keyfob has to have a good battery to use this. it will start the car in the hole manually without a battery.
Old Dec 17, 2024 | 12:10 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Run your VIN through www.lastvin.com to see if you have the keyless go option.
Go from there.
Old Dec 17, 2024 | 12:25 AM
JCM_MB's Avatar
Go from there.
and look for option 889
