Sponsored by: CARiD
Cold Blooded
Old Jan 23, 2025 | 08:57 AM
spectre6000's Avatar
Cold Blooded
I have a 2011 W550. I live in the canyons above Denver. It. Is. Cold. Right now.
An issue I have driving down to the flats each morning (and this condition existed prior to the cold snap) is that with all the oil and coolant in the engine and the miles and miles of down hill before any meaningful load is put on the engine, it takes forever to warm up. As in, I can take my daughter to school, and then get most of the way home before it gets up to temp, if it does at all. On the one hand, as previously mentioned, lots of fluids to warm up. On the other hand, that would typically be a sign of a stuck thermostat. On the other other hand, if the thermostat were stuck, I'm fairly certain it would throw a check engine light.
Is there anyone in a similar situation, or just generally in the know, that could weigh in on whether what I'm experiencing here is expected? Thanks.
Old Jan 23, 2025 | 09:01 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Being as it is the 5.5, have you bypassed the oil solenoid system?
Old Jan 23, 2025 | 09:02 AM
As far as I know, everything is rock stock save a carbon fiber spoiler on the trunk lid courtesy of PO that I haven't removed yet (and may not, it's sort of growing on me...). Still under extended warranty.
Old Jan 23, 2025 | 09:04 AM
https://mbworld.org/forums/w212-amg/...solenoids.html
Old Jan 23, 2025 | 09:09 AM
Thanks for the heads up, but that's not what I'm after here. I'm still under warranty, and if the engine gets roached due to something like that, I get a free engine. I have other cars to replace this one in the daily rotation if that needs to happen. I'll check in for things like that in a year or so as the warranty approaches EOL if I haven't already sold the car on.
Anyone have any insight on the extended warm up time?
Old Jan 23, 2025 | 10:44 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Yes, these vehicles can take some time to warm up with no load. The suggestion of the oil solenoid was because that has been found to not only protect the engine and its bores, but help with warming of the oil. It sets a soft code, because mb says it’s nothing to worry about, and most importantly could be plugged right back in before any service. Without getting into it you get better, oiling pressure from the start, thereby warming the oil more quickly, plus a host of other positives.
The best suggestion here might be to put some load on your engine by manually downshifting a gear or two from your normal driving gear. A lower gear with better load/ higher rpm will also help with low speed pre-ignition events.
Old Jan 23, 2025 | 11:40 AM
DFWdude's Avatar
2016 E350 Sport
My 2016 E350 blows warm air within 1/4 mile from cold at home in the garage.
Old Jan 23, 2025 | 11:46 AM
As does my E350 (3.5). The 5.5 in the AMG takes a bit longer, not much. The 4.6 in our GLS is bit faster than the 63,
Old Jan 23, 2025 | 11:54 AM
W205C43PFL's Avatar
Yes and if you don't want a soft code, just plug in a dummy solenoid from outside the engine.
Old Jan 23, 2025 | 12:29 PM
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
I believe my E550 actually takes _longer_ to warm up after disabling the OPR solenoid.
And while it warms up super fast when it's not negative temperatures outside, it also takes quite a while to get to temp when very cold. I don't have any downhill driving, which would make it a lot worse, but I can let the engine warm for 3-4 minutes, then drive between 1k and 1.5k until the needle starts reading on the gauge, keep it below 2k on the interstate while it continues warming up, and arrive at my destination 15 minutes later and still not be fully at temp.
It's crazy when you think about how much heat these engines generate, but there is a ton of oil and coolant, as well as a very large engine block to get to temp as well.
Old Jan 23, 2025 | 01:20 PM
W205C43PFL's Avatar
Hmmm interesting, I guess it depends on the engine, thank you for mentioning it so OP doesn't do this mod if it doesn't benefit them. For my case, for example the M276 (V6) engine the oil pump solenoid mod significantly reduced engine oil heating up time for me. Your mileage may vary.
Old Jan 23, 2025 | 02:19 PM
Baltistyle's Avatar
It’s a winter thing with all of the coolers and circuits. This has been the case for me each winter over the past six years regardless of oil used or solenoid mod. This is why some winter climate countries cars get auto flaps in front of their radiators similar to a trucker using cardboard or the equivalent in front to help the truck heat up in frigid temperatures. M157
Old Jan 23, 2025 | 02:29 PM
W205C43PFL's Avatar
I understand but I monitor the temperature, I have it unplugged for almost a year and the temperatures raise quicker in the summer and winter again, this is different engine to yours, M276, so YMMV for sure.
Old Jan 23, 2025 | 02:50 PM
Whose winter? Where I am now people are going nutty and buying all the milk and eggs because it snowed 200 miles north of us and we might, maybe just maybe get down to 32F out......when I was in Chicago, three weeks of -5F was the norm....
Old Jan 23, 2025 | 02:55 PM
W205C43PFL's Avatar
Sorry, should had clarified, the M276 in my car raise temperatures quicker in both winter and summer after unplugging the oil pump solenoid, this is comparing 30c and -10c.
Old Jan 23, 2025 | 02:59 PM
JettaRed's Avatar
Veteran: Army
Originally Posted by spectre6000
... if it does at all. On the one hand, as previously mentioned, lots of fluids to warm up. On the other hand, that would typically be a sign of a stuck thermostat. On the other other hand, if the thermostat were stuck, I'm fairly certain it would throw a check engine light.
Just curious. How many hands do you have? I have two, I think.
Old Jan 23, 2025 | 05:18 PM
ChuangTzu's Avatar
Mechanistically, I believe disabling the OPR solenoid should reduce the engine oil heating time. But by the same mechanism, the coolant should take a bit longer to heat.
The engine temp gauge probe is measuring the coolant temp, right?
Old Jan 23, 2025 | 05:20 PM
ChuangTzu's Avatar
On my side, I watched the heating times on this car pre-OPR solenoid disable at temps from about 25F/-4C to 94F/35C and post-OPR solenoid disable, probably between -15F/-26C to about 55F/13C. But I don't have actual logged data unfortunately.
Old Jan 23, 2025 | 05:21 PM
ChuangTzu's Avatar
Are the other other hand and the one hand the same hand?
Old Jan 23, 2025 | 07:52 PM
W205C43PFL's Avatar
How much wood would a woodchuck chuck if a woodchuck could chuck wood?
Old Jan 23, 2025 | 07:55 PM
W205C43PFL's Avatar
Interesting, that said, the coolant gauge is doctored though.
Old Jan 23, 2025 | 08:32 PM
JettaRed's Avatar
Veteran: Army
It is. The mechanical gauge is only to make the driver feel good. But my coolant is at "operating" temperature long before the oil is at 80°C/176°F. Also, the coolant temp in the AMG display is not the same if you measure with a scan tool. I think I found it was 10°-15°F difference. It may be doctored, as well. Most people aren't like us and would freak out if they saw what was really happening.
Old Jan 23, 2025 | 08:55 PM
ChuangTzu's Avatar
Yeah, I'm aware of that. However, when sweeping up from below normal temp to normal temp, it will first go into the normal temp position at the same temperature (when it crosses the minimum temp for the normal temp range).
Old Jan 23, 2025 | 08:58 PM
ChuangTzu's Avatar
Which is weird, because I freaked out when I first learned it's fake, and I'm still not happy about it.
Old Jan 23, 2025 | 09:19 PM
W205C43PFL's Avatar
Yes, I remembered you mentioned that before.
