2011 E63 Electric Trunk Closing Problem
If the trunk lid isn't completely all the way up and I hold it on that first part of the travel and then press the button it will retract and close normally which is what makes me think it isn't the motor, but I'm very much an amateur so I really don't know.
Thanks for any advice. I can probably get a video of it soon to demonstrate what is happening if that will help anyone.
I dont have the means to scan it than in depth I've only got a basic code reader. I may order a replacement motor as they aren't too expensive but I'm not quite sure how it disassembles. Its somewhat of an intermittent issue and from the sound of it sounds like its getting caught but I've checked all around the spring/hinge and everything seems fine.
Here's a short video the click can be heard right at the start. I tried to do it again but then of course it closed normally. Thats why I can't quite figure it out, I wouldnt suspect it to be the motor since it works some of the time.
Now you have fresh parts, let us help you how your unit failed so you can prevent the dame issues in replacement. It had to go bad, it did... hopefully not again twice.
Let get ypu inner pics...
Let get you inner pics...
amazin' dry trunk lid assist
More right here - The module enclosure is fairly easy to open up... some plastic gear may be broken beyond repair in you old unit else simple greasing lower internal frictions to pull heavy cables.
May be moot since you have the parts, and I'd honestly just go ahead and do the swap. Make sure everything you come in contact with along the way looks clean and healthy as you go.
Are there any codes hidden in any modules that might relate to this? Don't see that it's been asked.
I wish I had a friend or something close by with the Xentry thing so I could do a deep dive into the codes, I've only got a basic reader for clearing check engine lights. I wasn't sure whether there were any features that could be accessed in relation to setting the limits of the trunk closing or what not.
I read that after 08 things like this may be vin coded. May that mean I have to get it set through the STAR system?
Trunk gear pull needs to be configured for options and trained for limits.
> Next question...
Can this be done with 3rd party non-MB such as a LAUNCH scanner ??
> PLAN B...
The shortcut to unnecessary coding is to fix the original solderless unit.
Thanks for all the assistance chaps.
