Sponsored by: CARiD
Command Knob NOT the usual issue
Old Apr 18, 2025 | 05:15 PM
Mikemb87's Avatar
W212, h247, w246
My command knob module, including:
the knob
The C button
The arrow button
has stopped working. All actions are dead
is it a fuse? Anyone know which one?
Also, dones C button and arrow button illuminate in Orange? I dont remember and it would help to know if the module has no power for a broken fuse
This model
This model
Old Apr 18, 2025 | 06:30 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
two birds, one stone...
This is an electronic module built with marginal connections.
Either replace or resolder loose pins if it was not liquid soaked
rotary dial + tranny selector module
rotary dial + tranny E/S selector module
Nearby tranny button is the same way: solderless module.
Old Apr 22, 2025 | 07:06 AM
Mikemb87's Avatar
W212, h247, w246
Is the module protected by a fuse?
Old Apr 22, 2025 | 03:21 PM
I am sure it gets powered somehow from a fused circuit.
This is a 250mA low power circuit.
There's 0.1% chance you're dealing with a "fuse" issue...
Choices are replace module or repair poor connections. Cost less than $1,500.
Old Apr 22, 2025 | 03:24 PM
Mikemb87's Avatar
W212, h247, w246
I think there's 0.1% chance you're dealing with a fuse issue here...
thanks. What do you think it could be?
Old Apr 22, 2025 | 03:29 PM
disabling gremlins
-- These LIN modules are built with poor connections that oxidize.
-- Sometimes drinks get spilled...
You can SIMPLY DO A FAULT-RESET that will last sometime until poor networking condition is flagged again.
I have pics of the inside of these units... I got the whole chassis surveyed for gremlins nest
solderless connections
OPTO-COPLER + loose pins
OPTICAL SENSOR + loose pins
The optical sensor is sensitive to dusty contamination.
Same thing inside EIS Module as well.
Repair is either replace $$$$ or a 5mn quick 4x solder job... As mentioned: free reset also effective.
Old Apr 24, 2025 | 11:29 AM
Carcheologist's Avatar
2010 ML350 Bluetec, Alfa Romeo GTV6
Does anybody know if the command knob / switch needs to be coded if it's replaced?
I picked up a used one from a wrecking yard and was wondering if I can do the shaft swap on it, then just swap with the one in the car.
Thanks,
Ian
Old Apr 24, 2025 | 01:42 PM
LIKELY POSSIBLE
Thanks,
Ian
yes, you can try directly without coding it: high chance "no coding" necessary for these non-essential modules -
Unplugging modules will record faults
Clear the stored codes afterwards
Do use a scanner even though it could work without one... pays for itself!! 🤞
Old Apr 24, 2025 | 02:20 PM
x-post
