Sponsored by: CARiD
Warm start timing chain rattle-2914 M276 E400
Old Apr 20, 2025 | 09:25 PM
DIGGER11's Avatar
ML400 2014 W166
Hi,
Been trying to resolve this for a while but progress.
Its not the camshaft timing adapters as I have had 2 of them fail before and it is a different sound to that (plus camshaft adjusters were loudest on cold start)
I have replaced both timing chain tensioners, upped the oil from 5w-30 to 5w-40 (synthetic and still within mercedes warm climate specs) , but the 2 to 3 second loud rattle remains on warm startup only.
Chatgpt says don’t worry about it ? But is a really bad sound. Car has done 160,000kns but hasn’t missed a 10,000km oil change
This isn’t my car, but is the identical rattle
https://youtube.com/shorts/CWxR-tPzj3g?feature=shared
Only on warm startup. Dead smooth when cold
Any ideas ?
cheers
Digger
Old Apr 20, 2025 | 10:10 PM
S-Prihadi's Avatar
Your VVT unit is already bad.
VVT = cam phaser or cam adjuster sprocket and its oil control valve to be replaced both.
You have 4 +4 of these, usually two will go bad first.
VVT looks like this : https://www.fcpeuro.com/products/mer...mer-2760503200
Oil control valve looks like this : https://www.fcpeuro.com/products/mer...des-2760500278
This VVT has a service life and not a lifetime component like crankshaft.
The noise comes from the VVT adjustable parts hitting its left and right or clockwise and counterclockwise end stop and also from the lock mechanism pin failing to lock.
Watch below :
Old Apr 20, 2025 | 11:48 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
RATTLING CAME BACK... no surprise!
The genius who decided to run 5W-30 oil for 10k.Km in warm climate increased the service cost of your engine.
You'll want to have all 4x VVT gears diagnosed for having loose locks.
> FURTHERMORE....
"5W-40 Euro" is not huge viscosity... it's bare bone oiling to help save gas from less oil friction.
You could get you intake valves inspected/cleaned up from the burnt 5w-30 carbon deposit.
Any engine codes related to camshafts timing correlation mismatch (reluctor shifted) ??
Don't be surprised when your unbalanced engine condition lands in the ballpark of misfirings and vibrations regardless of all new ignition components, totally normal.
Old Apr 21, 2025 | 01:46 AM
DIGGER11's Avatar
ML400 2014 W166
Thanks for the ideas,
I had 2 cam adjusters replaced last year due to severe rattling on cold startup.
This is a different sound, exactly same as in the YouTube video.
Car runs perfectly (is a 2014 not 2914 !) and no codes .
Only issue is after parking for 15+ minutes I get the bad rattle for a few seconds.
Maybe I should try some expensive 10w-50 ?
Or Lucas oil stabilizer ?
thanks again. any ideas appreciated.
Old Apr 21, 2025 | 01:51 AM
S-Prihadi's Avatar
Which bank and EX or IN was/were the replaced cam adjuster VVT last year ? genuine one or aftermarket ?
Yes I know that sound. The utube video u linked is also a VVT sound.
Old Apr 21, 2025 | 02:59 AM
DIGGER11's Avatar
ML400 2014 W166
Deleted
Old Apr 21, 2025 | 03:00 AM
DIGGER11's Avatar
ML400 2014 W166
Genuine Merc parts,, had an independent shop do it. I think they said intake.
Old Apr 21, 2025 | 03:03 AM
DIGGER11's Avatar
ML400 2014 W166
Can adjust sound was more rattle and worse at cold start.
Current some start is perfect. No rattling at all.
Old Apr 21, 2025 | 05:59 AM
S-Prihadi's Avatar
Go back to that shop, get them to use Xentry VVT logging to read the angles of all 4 VVT during start up.
With that sound, you will have a whacky reading of at least -10 to +10 degrees OFF from target.
Make sure their Xentry is a fast one of at least 4-5 readings per second. Or else logged values can be misleading aka wrong.
Read here : https://mbworld.org/forums/e-class-w...rt-idling.html
Simple Summary.
INTAKE VVT does not move during cold start. It is not commanded to move by ECM. OFF below in pink means my engine is OFF.
I logged from dead engine>>> to crank to start >>> to running engine. 120 seconds only is the log by default.
Your INTAKE VVT last year, had a failed locking pin, thus it MOVES a lot and make rattle. You replaced it already, so its good now.
Exhaust VVT moves during engine start, be it warm or cold.
From its parking position of -23 or -25 degrees it will immediately go to -5 degrees.
This time..... your EXHAUST VVT wants some love, they are jelous of the new intake VVTs ....thus EXHAUST NOW had the noise because it overshoot too much.
These 4 VVTs share similar work load, thus they wear out almost equally....sort of.
This is my educated guess and I am sure it is what is going on.
Test with the xentry and get the log like in my post , you post it here and I will help you analyze it.
Good luck....
Old Apr 21, 2025 | 08:47 PM
DIGGER11's Avatar
ML400 2014 W166
Thanks S-Prihadi,
I reckon you might be on the money.
I'll get the Xentry Log done if it gets any worse or at the next service.
I have a good independent mechanic I use in Melbourne who has Xentry, but he still isn't particularly cheap as labor In Australia is at ridiculous levels.
As an example, when I had the intake cam adjusters replaced, the cost came to just under AUD10,000 (about USD 6,000). This would nearly exceed the value of the car if I had to do it again - so I doubt I would do it.
thanks again
Digger11
Old Apr 21, 2025 | 09:51 PM
> You have ... :
  • 2x new intake VVT gears
  • 2x new tensioners
That should take care of all rattles.
It does not...
Then what gives?
  • 2x intake VVT gears again
  • 2x exhaust VVT gears now
  • or thin old oil can rattle all new parts.
Old Apr 23, 2025 | 06:18 PM
DIGGER11's Avatar
ML400 2014 W166
I replaced the 5w 30 with 5w 40 and it made no difference, so I agree must be the exhaust cam adjusters. I wish the mechanic replaced them when he replaced the intake.
Old Apr 23, 2025 | 07:30 PM
It may be your exhaust VVT lock are worned out by 5W-30 extra low pressure: lock unlock lock unlock all day long!
you can use a scanner to read fault codes and live correction factors.
Old Apr 24, 2025 | 12:32 AM
S-Prihadi's Avatar
Thanks S-Prihadi,
thanks again
Digger11
I feel you...I know...
Thus DIY it makes more sense
