Sponsored by: CARiD
1/4 Million Km 2015 E250 Maintenance time!
Old May 6, 2025 | 10:49 AM
mfab's Avatar
E250 GLE300d
My 2015 E250 4Matic is sitting at 167,000 miles.
I am the original owner and I'm trying to do a good job maintaining the car: 28 oil changes, multiple air filters, fuel filters, cabin filters, etc. I changed the transmission fluid at 75K. Getting ready to do that again now.
I just changed the rear differential fluid (first time - oversight). Fluid was very dirty and the plugs were just about rusted out.
I've got the serpentine belt on order. I plan to change it and check the tensioner and pulleys and water pump. Coolant is original. I suspect I should have just bought all of it, but I figured I'd spin 'em first. I inspected this a couple of years ago and it was all running like new then.
New brake calipers, brake pads (Akebonos are awesome!) and fluid. New tires.
I feel the front end wander a little under braking. I replaced the sway bar link (bushings shot). I assume I'll need to replace the front control arms too to get the car driving like new again.
What else do contemplate for pro-active maintenance on a high mileage car? I'd like this car to go another 5 years and ~50K miles. Thoughts???
Thanks,
Mike
Old May 6, 2025 | 02:06 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Thanks,
Mike
Congrats on your maintenance and knowledge of MB wear items
The couple things I would add are
  1. DENSO radiator
  2. Tstat
  3. ALT OE brush Module
  4. seal electric connectors at front/rear end
  5. Any camshaft CPS on 300D??
  6. glow plugs + control module
  7. rear sway bar links
  8. adjust wheel bearings free play
  9. clear roof drains from overflowing
I dunno 4M besides passenger front shaft is coming...
Old May 6, 2025 | 02:58 PM
mfab's Avatar
E250 GLE300d
  1. DENSO radiator
  2. Tstat
Appreciate your comments, that gives me some stuff to research. What do you mean by #4? Grounds, or something else?
Thanks!
Old May 6, 2025 | 03:01 PM
W205C43PFL's Avatar
  1. DENSO radiator
  2. Tstat
I would normally add transfer case as well but they share the same fluid as the transmission in this car right? Add front differential fluid as well.
Old May 6, 2025 | 03:02 PM
W205C43PFL's Avatar
not quite maintenance related but: https://www.mbusa.com/content/dam/mb...pplication.pdf
Old May 6, 2025 | 03:03 PM
W205C43PFL's Avatar
Thanks!
Think sealing them to prevent water intrusion and corrosion.
Old May 6, 2025 | 04:44 PM
the electric connectors are nicely sealed until the seals SHRINK then water enter by capilarity around the wires (forget about hosing off engine!!)
This is particularly important for bumper sensors/RADARS
-- Low hanging exposed connectors:
- A/C compressor: clutch + valve
- ISM Module connector.
Old May 6, 2025 | 06:20 PM
mfab's Avatar
E250 GLE300d
I had no idea the front differential was even possible...good one:
Old May 6, 2025 | 06:28 PM
mfab's Avatar
E250 GLE300d
Thanks. I already received my high mileage award. Mercedes does a good job with these - they are very impressive. The problem is there's nowhere to mount it on a modern W212 with the sport look. I'll have to try to figure that out...
For now it sits in my glovebox.
Old May 6, 2025 | 06:39 PM
W205C43PFL's Avatar
Keep it at home : ) safe and sound, no point mounting on the grille and potentially losing it.
Old May 6, 2025 | 06:41 PM
W205C43PFL's Avatar
https://www.youtube.com/watch?v=L1s5-AMb7A4
It is important too, MB doesn't have an official interval for the front differential (for some reason) but I have been reading them failing on the forums lately when the fluid is neglected.
Old May 6, 2025 | 06:44 PM
W205C43PFL's Avatar
Think about it, the weight of the engine, all the steering and weight of the rack, plus various other drivetrain component is carried by this little differential, it goes through lots of stress.
Here are some stories of it failing because of not changing fluid:
https://mbworld.org/forums/glc-class...placement.html
https://mbworld.org/forums/gls-class...ferential.html
Old May 7, 2025 | 01:47 AM
S-Prihadi's Avatar
At that mileage these will need to be renewed if you want tight like new feel back on the car :
01. All engine mounts
02. Tranny mount
03. All for dampers/shock absorber and the top mount plate/bushings and the bump stop foam/rubber.
04. Front suspension control arms and the L shape ball joint if it does use it.
05. Tie rod end the short one and the long one, this is the steering system.
06. 2 of bushings at the rear wheel carrier / knuckle
07. Rear spring arm bushing at the rear subframe
08. The propeller shaft ( main drive shaft ) middle bearing and boot.
09. 4 of rear subframe mounts , if it already sunk too much and differential bushings at rear (2) while at it and differential mount at front (1).
10. Rear suspension arms, 4 of them ( spring arm no need ), you need to inspect . 4 wheel alignment as in rear camber reading can help to figure it out.
11. Wheel alignment can show the camber and caster value of front 2 suspension arms geometry.
12. The rear tire wear pattern so far ( perhaps 3 - 4 sets of tires consumed already ? ) will be a good database.
13. 4matic shaft out of the rear of the G7 tranny, there is a yoke there which will wear out. Inspect.
14. Inspect rear & front spring condition, if you have reference ride height when new, you can use it as reference for today's condition, how much sagging is occuring.
15. Measure thickness of front and rear rotor. Their useful life is only like 2mm, that is it. Actually brake calipers are serviceable when the repair kit is available, no need new one.
16. All of your cooling and oiling system hoses or plastics/rubber hose or pipe, inspect them well and best to replace them all.
17. Test and calibrate all of your fuel injectors.
18. Inspect vacuum pump, make sure it still can produce negative pressure and how fast it can achieve the maximum negative pressure.
19. All plastic and rubber fuel hoses from tank to engine, replace them all. I wonder if diesel version W212, is the fuel tank output to engine using the blue plastic hose ? Gasoline one uses that blue plastic hose.
Now you wonder, is it worth all above for 50,000 miles and 5 years more of use ?
Old May 7, 2025 | 02:42 AM
W205C43PFL's Avatar
02. Tranny mount
Old May 7, 2025 | 03:01 AM
BenzV12's Avatar
W212 FL
I appreciate you share all the details with us . Normally, dealers should have already replaced the coolant by now but it looks like you service your own car . Probably a proper spec coolant replacement might need it , I don't know
Happy Driving
Old May 7, 2025 | 08:06 AM
mfab's Avatar
E250 GLE300d
Happy Driving
Yes I service my own cars.
Coolant and water pump (!) are still original to the car. I installed a new serpentine belt last night (took less than 10 minutes) and everything in there is spinning nicely. So for now the water pump and coolant stay.
I need to pick my spots and prioritize. As you can see there's a long list!
The problem with the water pump is a failure leaves you on the side of the road.
Old May 7, 2025 | 09:26 AM
mfab's Avatar
E250 GLE300d
02. Tranny mount
That's a long list! And a good one.
I'll go through it. Thank you.
Some of those items don't apply to the diesel obviously, but most do.
My car is still driving great - but, you are correct that it probably doesn't make sense to do all of that!
Old May 7, 2025 | 09:41 AM
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
Mfab, I also have a 14 E 250 original owner at 125,000 miles. I appreciate the info you and others provided. Have you done engine mounts? Like you I do pretty much all my own work. Happy to hear the belt was an easy change. Did you put on an OE belt? BTW mine is just 2wd
Old May 7, 2025 | 09:56 AM
mfab's Avatar
E250 GLE300d
GREAT LIST. THANKS SOME COMMENTS BELOW IN CAPS:
THIS IS A HARD JOB ON AN E250 4M. NO ROOM ON PASSENGER SIDE. Might be end of life for the car (for my ownership).
02. Tranny mount
MUCH EASIER DIY THAN THE ENGINE MOUNTS.
ABOUT TO DO THIS TO ADDRESS SOME VAGUENESS UNDER HEAVY BRAKING
4th SET OF TIRES. RUNNING MICHELIN 4S. OUTSTANDING TIRE! I DITCHED THE RUN FLATS.
ROTORS ARE NEW. Calipers are original and they're fine.
Old May 8, 2025 | 11:28 AM
mfab's Avatar
E250 GLE300d
I haven't done the engine mounts. It looks like a difficult DIY on Bluetech 4M. I think it's easier for 2wd. Transmission mount looks much easier. I think they're both inevitable.
I ended up installing a Continental belt. I've used them on multiple cars and they are good quality. The belt change is simple (15 minutes) and inexpensive ($25). When you're in there inspect/spin the tensioner, pulleys, water pump and alternator. A belt change is a good way to do a health check on those systems. Put the old belt in your trunk in case of emergency.
I'm going to spend some money now to refresh the suspension: front control arms (both), rear tie rod link (the support rod), and probably front struts.
From there I'm going to see how it goes. I'm not an expert, just trying to figure it out as I go!
Good luck.
Old May 8, 2025 | 01:35 PM
W205C43PFL's Avatar
Good luck.
Yup the 4MATIC makes it difficult, if the vehicle has a turbo that makes it even harder with the heatshield in the way.
Old May 9, 2025 | 09:02 AM
SEC1939's Avatar
Thanks for the input. I just took a peek at my set up. Drivers side is easy. Passenger side has exhaust in the way but since only 2WD that should be it. I have the passive mounts no electronics
Old May 9, 2025 | 10:15 AM
W205C43PFL's Avatar
Think you are all set to do the work.
Old Sep 8, 2025 | 04:54 PM
mfab's Avatar
E250 GLE300d
Update:
- Motor Mounts (I had the dealer do this). It's a hard job on the E250 4Matic. They split the subframe when they did it.
- Rear Subframe replaced under warranty. Rust. There is an extended factory warranty on the rear sub-frame for rust! Get yours inspected.
- Transmission mount (relatively easy job for me).
- Front differential, rear differential, center transfer case fluids all changed.
- I also replaced one of exhaust sensors and used my Foxwell 530 to force a DPF filter regeneration. No check engine lights.
Car drives great now. Very happy. I don't know the exact mileage off-hand, but it's in the neighborhood of 170K.
Up next is regular oil and transmission fluid change.
Old Sep 9, 2025 | 12:21 AM
BenzV12's Avatar
W212 FL
That's good to know
Happy Driving
