Sponsored by: CARiD
E200 2011 parktronic fault!
Old May 12, 2025 | 04:42 AM
TruongNguyen's Avatar
C250 W204
Hi guys! First of all, I'm sorry for my English!
I just bought an E200 model 2011 a week ago, and I recognize that Parktronic doesn't work. After that, I used Xentry to read the faults, and I got a fault at N62-Parkingsystem(PTS)
Fault: D12B00 - Communication with front PARKTRONIC warning element 1 has a malfunction
When I insert the key and ignition, the parking sensor light doesn't light up, and I hear a long beep sound
So what should I do to fix that?
Old May 12, 2025 | 08:10 AM
S-Prihadi's Avatar
Check bad connetor or wire to bumper for these sensors.
A is at the bumper, right side.
B is at the car.
These two have s-e-x together
Make sure no water entry and no green crusty and no female pin overly open/expanded.
Use contact cleaner and clean these two, insert-remove-insert, while wetting out with contact cleaner. Engine OFF Ignition OFF.
Contact Cleaner :
Amazon Amazon
and / or
Amazon Amazon
Inspect all 6 sensors at the bumper.
And do this to test first before you check connector at bumper and car.
good luck...
Old May 12, 2025 | 10:19 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
clean the sensor faces, sometimes they get shut down by car wax, also if you have stuff in front of them at start up they get confused
Old May 12, 2025 | 11:18 AM
C250 W204
B is at the car.
Contact Cleaner : https://www.amazon.com/WD-40-Special...77&sr=8-5&th=1
and / or
https://www.amazon.com/CRC-05103-Ele...7050913&sr=8-1
https://youtu.be/NK8uRVH5d04
good luck...
Oh, thanks for your detailed information! I'll follow your guide tomorrow and let you know.
Old May 12, 2025 | 11:19 AM
C250 W204
Thanks for your trick... I'll try to do that tomorrow and let you know
Old May 19, 2025 | 11:26 AM
C250 W204
UPDATE!
The parktronic issue was fixed! The problem was with the last owner who plugged the wrong cable for the front parktronic LED warning!. I took out the center cover and recognized that the problem came from a mistake.
Old May 19, 2025 | 06:44 PM
W205C43PFL's Avatar
Originally Posted by TruongNguyen
UPDATE!
Glad to hear it!
Old May 20, 2025 | 12:12 AM
S-Prihadi's Avatar
UPDATE!
U mean the black long display on top of the dashboard right ?
Old May 20, 2025 | 09:17 AM
W205C43PFL's Avatar
Oh that? I thought that only displays and not part of the sensor, it is like a light strip but why unplug it? They were trying to replace the speaker?
