Sponsored by: CARiD
Coding Vediamo 4.2.2 ECO button to "Last mode"
Old May 30, 2025 | 07:20 AM
FLASHBACK's Avatar
2013 E250CDI BlueEfficiency 4Matic
Question Coding Vediamo 4.2.2 ECO button to "Last mode"
When in CRD3 which is supposed to be my ECU i send 27 0B and are supposed to get an answer of 4 hex but i only get 3, instead of 1A 2B 3C 4D i get 1A 2B 3C and that seed is not sufficient to generate a 67C message for me.
Am i doing something wrong here?
Old May 30, 2025 | 09:25 AM
W205C43PFL's Avatar
Admittedly I am not that knowledgeable with Vediamo so I do apologise for that, that said, do you want to consider using a scanner instead? https://mbworld.org/forums/e-class-w...-reader-2.html
Old May 30, 2025 | 09:27 AM
W205C43PFL's Avatar
You can also set a different parameter which allows you to change it to set as last state: https://mbworld.org/forums/w213-amg/...top-start.html
Old May 30, 2025 | 04:26 PM
trigital's Avatar
W213 All-terrain
I would try "Entrigelung" from Function first,
Anyway, CRD3 has Login Request with 27 01 and Send the Seed with 27 02 and after succesfully login you can unlock Variant Coding with request 27 0B
Remember all Seed for old model is free on Developer Github - no matter what leachers promise that they had "better" ...https://unlockecu.sn.sg/
Old May 30, 2025 | 05:11 PM
trigital's Avatar
W213 All-terrain
No one would want to use cloned of the clone Chinese tools that has absolutely no logic other then sending to "Chinese online database" all the information from the car if Vediamo is already successfully installed. Vediamo is MB engineering tool - for old models - and beyond any Chines tool has the many giga powerful functions like "save" or ability to correctly recognize the real version of the ECU.
Like on any phone or laptop, there is various versions of Hardware with much more version of Software and only Vediamo/DTS/Xentry has the ability to recognize the real "Diag Version".
Old May 30, 2025 | 05:16 PM
W205C43PFL's Avatar
I was just mentioning it as an option, that said, forum members reported it works and I am sharing my findings. I mean obviously no one has to use it. They also used it without connecting to wifi so it is not sending anything anywhere. Thanks for your reply.
Old May 30, 2025 | 05:18 PM
W205C43PFL's Avatar
Thanks for the information.
Old May 30, 2025 | 05:23 PM
trigital's Avatar
W213 All-terrain
there is no free meal, or lifetime support...it's just scams, bots, etc,
From where do you think those cheap and "user friendly" tools has the knowledge if not from the logs created and uploaded when user "update" over internet....or from the new shiny ones that has "Mercedes Online" s..it.
Daimler do the same...over Hermes logs....but they had user tick
Old May 30, 2025 | 09:11 PM
W205C43PFL's Avatar
I mean it does work and they buy it to use without connecting to the internet, works in that particular case as reported by them
Old May 30, 2025 | 11:02 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
SIMPLICITY OR AGGRAVATION
Basic SCANNER steps take 5mn for free.
noooo
Chinese spyware...
github crack...
Russian bootleg...
keygen nothing...
What's wrong with simplicity ??
> ONE MN SHORTCUT:
Unplugging battery sensor disables ECO + YOYO.
Test and report findings.
Old May 31, 2025 | 01:30 PM
FLASHBACK's Avatar
Cali, the decision have been made, i will try out the "ALT LIN disconnect" and i promise i will report back
Old May 31, 2025 | 01:56 PM
W205C43PFL's Avatar
noooo
Chinese spyware...
github crack...
Russian bootleg...
keygen nothing...
> ONE MN SHORTCUT:
Oh boy you would love that one, problem is it will also be disabled until you plug it back in and not like how you want it "last state mode"
Old May 31, 2025 | 01:57 PM
W205C43PFL's Avatar
https://mbworld.org/forums/mercedes-...s-voltage.html
Old May 31, 2025 | 03:34 PM
CHAOS FREE MODE
Follow the steps... don't skip float!
Chassis is voltage(*) sensitive...
It thrives on stability to disable chaos.
(*) actually current sensitive because there's built-in inline voltage drop. More current cause less voltage...
Old May 31, 2025 | 03:36 PM
W205C43PFL's Avatar
Chassis is voltage sensitive...
Yes go with the flow (flow current) (float) : ) https://mbworld.org/forums/e-class-w...eboot-how.html
Old May 31, 2025 | 03:53 PM
trigital's Avatar
W213 All-terrain
It worth mentioning that the "voltage instability" is in fact the very complex "Energy Management", a high level concept that differentiate Mercedes over competitors.
Refusing to educate yourself about those concepts, is almost dangerous for anyone to follow.
Tesla claims that they discovered how to charge battery when braking, MB do that 20 year before and with a much more advanced algorithms.
Disconnecting the Alt Lin transform your lovely Mercedes into an ugly, smelly Ford.
And of course, Ford use Energy Management as well, but so unpopular in the EU as is very common to send the client to Ford when is not capable to enjoy a MB.
Without Lin, it's like using Autel instead of Xentry. Simple....but expensive and charging the battery with 14.4V on full throttle.... that's not MB, never. But is simple and no need to read how to use seed key, indeed.
With all my respect, I ask administrator to move Alt Lin discussions on Ford forum.
Old May 31, 2025 | 04:28 PM
old chow
It's not directly clear how much ignorance or stupidity are purposely laced...
It's Bosch that pioneered this design, Mercedes licensed it. They hardly have anything to do with it, certainly not improving it.
ONE THING CLEAR: WHEN MODULES ARE ACTING UP FOR NO REASON and busy specialist "can not reproduce"... these tips may be an answer.
The normal variable voltage swing is jacked up by yoyo "drain by driving" below 11.xV.
Ford, GM, Toyota, Honda.... all use variable voltage and perhaps make it work well with their own chassis.
I am sure Japanese chassis tolerante well Bosch/Denso normal swing [12.6 to 14.9V] - I like the idea of 12.6V chassis float voltage a lot, except the W212 computers are hardly compliant.
Experimental ALT-LIN cancels:
Stock Voltage Swings 12.6/14.9V
Buggy "Yo-Yo" drain /limp-mode 11.xV
ECO aka. "heatsoak on demand"
Old May 31, 2025 | 04:49 PM
trigital's Avatar
W213 All-terrain
Being smart as you are is not related with being educated as I am. You will be amazed how paradigm will change after some readings.
I was in your shows long time ago, when I was the most beautiful and smartest person in the room, till someone else came and ...
Old May 31, 2025 | 06:14 PM
help us welcomed
thank you for helping us by sharing your knowledge in the many places we keep falling short.
