Sponsored by: CARiD
Oil Leak Under My W212 E250 CDI – What Is It and Should I Worry?
Old Jun 15, 2025 | 02:32 PM
Spruze's Avatar
Mercedes E250 W212 Diesel- OM651
Hi everyone,
I noticed an oil stain under my 2014 Mercedes E250 CDI (Diesel, W212) rear when I recently went under the car to inspect. I’m not very mechanically knowledgeable, so I wanted to ask for your help in identifying what this leak might be, and whether it’s serious or something I can monitor for now.
I’ve attached a few pictures below:
From what I can tell, the leak seems to be coming from the rear area, possibly near the differential or driveshaft. There’s some oil staining on the exhaust pipe and surrounding metal, but nothing seems to be dripping actively. I don’t notice any performance issues or noises while driving.
My questions:
  • What part is leaking here? Is it the differential or something else?
  • Is this a serious issue or just a minor leak I can keep an eye on?
  • What kind of oil is leaking? Engine oil, gear oil, or something else?
  • What would be the best way to fix this, and is it something urgent?
  • Should I be checking fluid levels, and if so, how?
Any advice is appreciated — I’d like to be informed before taking it to a mechanic, and I want to understand the situation a bit better. Thanks in advance!
Old Jun 15, 2025 | 04:16 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
FORBIDDEN BEARINGS GLITTER
this is your dif pinion shaft seal leaking.
The problem is not the dirty seal, it's the input shaft bearings have too much freeplay.
Dont spend $8,000 to get this rebuilt. This is a standard failure, no need to open everything for estimate.
Caused by tranny mount, inter shaft bearing + destroyed dif. roller bearings not serviced.
Uses only 1Qt of 75w90 gear oil: not much to leak out.
Old Jun 16, 2025 | 12:01 AM
Spruze's Avatar
Thanks a lot for the detailed reply — I really appreciate it.
  1. Honestly, I have no idea how long this leak has been happening. I just noticed the stain recently when I looked under the car.
  2. Am I cooked already, or do I still have some time before it becomes a major issue?
  3. Based on what you said, is my differential already damaged, or is it still savable if I act now?
  4. Would you recommend checking the gear oil level and topping up, or is that just a band-aid if the bearings are already gone?
  5. Also, is there any way to confirm bearing play or damage without opening up the whole diff?
I’m trying to avoid a massive repair bill, so I’d really value your thoughts on the next best step. I’m just a regular owner, so I’m learning as I go — thanks again for sharing your experience.
Old Jun 16, 2025 | 12:51 AM
PURPOSE BUILT DIFS
this is more than cosmetic! At this stage you're likely running on less than 1/2.Qt. of oil.
By the time you see the amount of glitter that come out of the drain plug you'll understand the emergency. Simple oil service was missed long ago.
This may lock up wile driving. Get this worked on.
These difs. are built without a magnet... steel particles circulate non-stop into bearings and gears...
By the time the bearings is gone the shaft has too much play that input seal can not handle without dumping oil.
Next time... add a magnetic drain bolt to disable self-destruction.
Old Jun 16, 2025 | 10:03 AM
S-Prihadi's Avatar
Just bring the DIFF back to its normal oil level.
Clean all old residue/dirt and start monitoring leak rate.
If leak is very small, perhaps you may end up topping off every 6 months or so.
True to what Cali said, it could be from vibration that the main input shaft went dancing-shakey-shakey and cause shaft seal to leak.
It could be a dynamic leak, meaning only when shaft spin and leak then occur.
So u must check both rubber dampers ( flex coupling ) of the propeller shaft and the middle bearing.
Flex coupling
https://www.fcpeuro.com/products/mer...i-0004110600kt
Middle bearing ( propeller shaft), read here : https://mbworld.org/forums/e-class-w...ml#post8822118
The DIFF strip down, but I did not remove the mains shaft, I only replace the big gears with ATB unit, like a Limited Slip device, but no clutch.
Below : original
Below, your leaking seal is behind that small gear.
ABT unit, below
You need this oil for the DIFF
Do not buy wrong and ended up with LSD type DIFF oil.
Hoping u only have super minor leak.
Old Jun 16, 2025 | 03:52 PM
loose input bearing
The leak serves as witness of input shaft freeplay...
input pinion gear: shaft bearings + seal
Diesel Mercedes still require maintenance to go high mileage.
The input shaft bearing being loose it's busy eating the gear into additional glitter - I hope I am wrong saying this is just "a leak": check the shaft freeplay!
Old Jun 18, 2025 | 01:46 AM
Spruze's Avatar
Thanks CaliBenzDriver, I will get it checked ASAP. This sounds serious!
Old Jun 18, 2025 | 01:49 AM
Spruze's Avatar
Thankyou S-Prihadi for explaining this in so much detail. As a layman I could understand some of the things and will be getting it checked from my mechanic. Could you please tell me about the exact differential oil my car will use or is it the same which you have mentioned? I mean aren’t there any different differential oils for different cars. Seems like you have a very deep knowledge. Thanks again!
Flex coupling
Below : original
ABT unit, below
Old Jun 18, 2025 | 10:20 AM
S-Prihadi's Avatar
The DIFF oil I shown is the one for regular non AMG LSD DIFF, that is us regular DIFFERENTIAL.
Sometimes MB add extra 2 digit on newer parts. Like above the extra digit is 09.
I got the one with 2 extra last digit being 12. The core part number number is A001 989 33 03
List of approved DIFF oil, our kind of DIFF
Old Jun 19, 2025 | 03:52 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
warning, this job SUCKS.
if you just want to fix the leak, driveshafts gonna have to come out, you have to pull the flange then you'll see the seal... I just use a flathead and i try to lift it out. I would 100% pay for this job to be done. The liability of doing it yourself is a bit high but it's possible. You'll need a puller tool for the flange. As for the bearings, if you don't notice any grinding noises you're probably ok. Wet means it's still being lubricated and if you don't hear gear noise youre probably alright.
https://mbparts.mbusa.com/oem-parts/...ring-169975146
Being a 2013 I don't think a horrid amount of damage has been done. I think the car has 150k miles on it, it should get a transmission mount service as well as check/inspect the flex disc and center support bearing. You can often be ok.. check and inspect. The transmission mount is 100% toast by this mileage.. but I've seen much, much worse being who I am and what I do. You can probably top off and keep driving for a while.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jun 26, 2025 | 12:23 AM
Spruze's Avatar
Thanks again S-Prihadi!
Old Jun 26, 2025 | 12:27 AM
Spruze's Avatar
I will get it checked by my mechanic, no way I can do it by myself as I don’t have much knowledge. But there are so much knowledgeable people here like you, S-Prihadi and CaliBenz have made it easy for me to understand a bit as a layman so I know what my mechanic is doing. Thanks to you all!
