Sponsored by: CARiD
Active Blind Spot Assist
Old Sep 1, 2025 | 06:29 AM
Jobba's Avatar
E 220 Wagon, 2012 mod.
Hi All !
I have replaced both rear radar sensors for Active Blind Sopt Assist, also replaced wiring loom as the connectors where corroded, in Xentry i am not able to get it initialized, Xentry states "Outside Permissible Range" any advise of how to proceed ?
Does it need programming, SW upload ?
Regards:
Jobba
Old Sep 1, 2025 | 02:32 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by Jobba
Hi All !
Regards:
Jobba
These numbers are way out there...
At least the harness and bumper modules are now working.
People have reported replacements with used modules being easy "plug-n-play".... yours are not.
You may not have direct matching unit that need to be SCN coded. A normal process for any new modules.
Old Sep 2, 2025 | 03:22 AM
Jobba's Avatar
Does that mean that i need to have it done at an official MB service point or could it be done with Vediamo or DTS ?
New to this....
Regards:
Jobba
Old Sep 2, 2025 | 04:21 AM
New to this....
Regards:
Jobba
Coding SCN module configuration is done with Xentry.
Forum sponsor & MB expert @BenzNinja
can easily do this remotely at a fraction of normal cost.
Old Sep 2, 2025 | 06:38 AM
Jobba's Avatar
From what i see, i will then need to order HW and get shipped to me, not just for him to log in and program...?
Jobba
Old Sep 2, 2025 | 01:24 PM
Jobba
Programming involves using a reliable PC setup to code the car without glitches.
I believe there's a "rental program" where the computer is on loan without a need to buy your own.
Old Sep 3, 2025 | 09:51 PM
Arrie's Avatar
Hi All !
Regards:
Jobba
where did you get the blind spot sensors from? You cannot just buy from eBay or something. The sensor needs to be the correct one for your car. I went thru this and got mine working after getting the sensor from the dealer ($$$).
There is no coding for this by BenzNinja. It is plug-and-play when the sensors are correct. Xentry (DAS) has nothing to do with these.
Old Sep 4, 2025 | 06:27 AM
Jobba's Avatar
Used sensors with matching HW & SW numbers, how did you determin what was correct sensors for your car ?
Jobba
Old Sep 7, 2025 | 12:36 PM
Arrie's Avatar
Jobba
If you bought a sensor with matching numbers it should work. Perhaps the used sensor is bad?
I got the working sensor from the MB dealer based on the car's VIN.
