Sponsored by: CARiD
E350 18inch to e63 19inch
Old Sep 21, 2025 | 05:38 AM
E350AMGREP's Avatar
Mercedes e350 bluetec w212
Hi I’m looking to go and buy a second hand set of e63 wheels to put on my e350 bluetec, I was just wondering would they just fit and have no rubbing? And also has anyone done this and have any idea how the fitment looks like once done?
Old Sep 21, 2025 | 09:11 AM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Here are your tire and wheel options. Bolt pattern is 5 x 112
Tire Rim Offset Range mm
OE245/45ZR17 95W
8Jx17 ET48 46 - 50
OE245/45ZR17 95W
8.5Jx17 ET48 46 - 50
245/40ZR18 97Y
265/35ZR18 97Y
8.5Jx18 ET48
9Jx18 ET54 46 - 5052 - 56
245/40ZR18 97
8.5Jx18 ET48 46 - 50
245/35ZR19 93Y
275/30ZR19 96Y
8.5Jx19 ET48
9.5Jx19 ET48
Old Sep 21, 2025 | 09:40 AM
E350AMGREP's Avatar
If it’s bigger like a 285 problem
Old Oct 13, 2025 | 01:17 PM
cyyzgnus's Avatar
2014 E350 wagon 81K miles
I have the exact rims and I know that 285 30 19 Rear fits with no rubbing. 255 35 19 front fits without rubbing.
I just lit a very large at night last week. Blow out my from driver's tire and bent the rim. The rims came with the 2014 E350 4matic wagon sport when I bought it used at 80K. My advice do not do it unless you want or alright with bent rim expensive tire replacement and less miles before replacement is required.
I am buying new rims and tires that are 18 and stickling to the factory specs. After reading what I just wrote, if you still want 19 AMG rims PM, I will you a great deal, but do not say I did not warn you about the rims you want o buy.
Old Oct 15, 2025 | 03:05 AM
BenzV12's Avatar
W212 FL
E 63 AMGs have bigger fenders from the factory so I also heard some rubbing issues for non AMG cars .
Old Oct 16, 2025 | 12:50 AM
ap10046's Avatar
CLS500 M113
I had the same dilemma.
They fit fine. Perfectly actually.
Even 222 19’s fit directly WITH the 255/40-19 in front and 275/35-19 in the back, that many said would never fit.
Stock 212 4 banger.
I just did it last night.
And we have horrific abysmal roads. I’m being conservative here. No touching rubbing just perfect.
Old Oct 16, 2025 | 01:22 AM
E350AMGREP's Avatar
I have put them on now, I have to admit on deep bumps where the spring is soft and the car dips I get a slight rub nothing to serious, but I am putting 25mm lowered stiffer springs to see how it feels any better or worse, any advice would be great, or I might just lower the rear not to sure
Old Oct 23, 2025 | 01:10 PM
cleanerPA's Avatar
2014 E550 4Matic
Stock E63 sized tires will fit on the stock E63 wheels on a "regular" W212 without any issues.
255/35R19 on 19x9" front
285/30R19 on 19x9.5" rear
BTDT. The CLS 63 wheels will also fit, but you will probably get a bit of rubbing on the wheel well liner with 295/30R19- you need the 10" wide CLS 63 wheels to fit 295s.
