Sponsored by: CARiD
Auto Dim for Passenger? W212
Old Oct 15, 2025 | 03:18 AM
zain.arsh.04's Avatar
2010 e350
Hey guys,
So a few days ago, I managed to hit something, and my mirror has shattered for my car. I know that my car has auto-dim for driver (right) and rearview mirror, but unsure if my passenger (left) has auto dim. I have searched the VIN and has come up with the following:
249 - IINTERIOR AND EXTERIOR MIRROR, AUTOMATICALLY DIMMING
For reference, my car is an Australian model, not sure if that makes any difference.
The part number of the current mirror is A2128102121, but, does not come with auto dim
Any help is appreciated,
Thanks,
zain.arsh.04
Old Oct 15, 2025 | 02:58 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
SHATTERED OUTSIDE MIRROR
Originally Posted by zain.arsh.04
Hey guys,
Thanks,
zain.arsh.04
Mate... great job figuring that one out
The passenger side mirror does not dim.
While in there, you may be interested to unplug the mirror HEATER that I understand is always active.
Goo'Day
Old Oct 15, 2025 | 11:03 PM
butala's Avatar
W212 facelift
Goo'Day
Hi CaliBenz,
Yes the mirror heater is always active but very small current and depend on the outside temp. So can unplug or not if you want.But I'm very interested in how to make the side mirror auto-dimming. I tried to look in the coding section of the passenger side mirror control module, it can activate the auto-dimming feature. However, I could not find the wiring diagram for the dimming-line out from control module to test. If you have the wiring diagram of the door control module, please show me the location of the auto-dimming supply so I can test and report back.
Old Oct 15, 2025 | 11:37 PM
Arrie's Avatar
Originally Posted by butala
Hi CaliBenz,
Where does this information come from that the mirror heater is always ON? In my car it works with the rear window defrost.
Old Oct 16, 2025 | 12:16 AM
mirror heaters
I picked that up by combing through the CAN-B DCU settings.
How did you come up with the concept mirrors are controlled by the rear windows defrost?
It sounds like a good idea to have mirror heaters not always ON.
Old Oct 16, 2025 | 01:13 AM
CUSTOM MIRROR DIMMING
Hi CaliBenz,
You're a wise Aussi... I thought of doing the same extension once I realized both L & R DCU modules are identical. Besides the passenger side glass has NO ARRAY to dim light.
There may be ways to...
-- purchase a dimmable US driver side mirror to use as your Australian passenger side
-- AND wire it to the DCU module comparing with the other side.
-- AND custom code the DCU function to enable passenger-side dimming.
Old Oct 16, 2025 | 06:59 AM
ap10046's Avatar
CLS500 M113
I was wondering about this too.
Why would they do this? The glare from the passenger mirror is awful.
Old Oct 16, 2025 | 10:26 AM
Arrie's Avatar
Every car I have driven so far has had mirror heaters working with rear defroster. And I have driven lots of different make rental cars in Canadian and up state winter conditions to find this out.
If my own MB has it ON at all times the power is extremely low as it does not do anything before I press the rear defrost.
Old Oct 16, 2025 | 02:11 PM
AUTO DEFROST FEATURES
It makes sense the mirrors being linked with the rear window defrost.
I haven't bothered too much documenting these DCU settings as I seldom defrost in mild California weather. There's something of interest in these settings (JR).
Have you seen how our WINDSHIELD glass features a built-in wipers defrost heater ?
I have seen it on my US car but don't know too much about its circuit activation: Auto or manual?
Old Oct 16, 2025 | 02:24 PM
I've wondered the exact same things about non-dimming passenger side...
it's easy to recognize a dimming mirror vs. non-dimming by looking at the glass for built-in pattern all around near the edges.
I've also wondered why Mercedes 2014 mirrors don't AUTO FOLD ... I rationalize the harness should last longer.
Old Oct 16, 2025 | 07:41 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
The manual explains it no better.
Old Oct 16, 2025 | 07:48 PM
Baltistyle's Avatar
Since auto folding was available in other countries, why not code it in?
Old Oct 16, 2025 | 08:40 PM
the control module supports it but I think the whole mirror needs to be upgraded to have built-in actuators. So many cars have it.
I shied away from fancy mirrors after having issues with convenience tilt colomn and sunroof plastics.
So far my basic mirrors can still reverse-tilt ok after visiting them for initial grease inspection.
Old Oct 16, 2025 | 11:24 PM
Arrie's Avatar
For me it says that the mirrors heaters come ON when the rear window defrost if activated AND it is cold enough temperature. It does not say how cold it needs to be but the heaters work from the button that activates the rear defrost.
Old Oct 17, 2025 | 06:39 AM
Baltistyle's Avatar
That is what it says in the picture I posted. The silly part is is it’s basically telling us that if you press the button for the defroster when it’s cold (doesn’t matter what the temperature is), it will turn on, and then is saying if you push the button generally, it will turn on, meaning regardless of temperature outside. It’s almost as if they’re reinforcing that you have to push the button to get the mirrors to defrost..
This is the way it’s always worked for me on any Mercedes. However, the old LX I drive as well has independent buttons for all of these features we’re talking about… I’m allowed to defrost the rear independently from the side mirrors :-)
Old Oct 17, 2025 | 09:20 PM
LOST IN TRANSLATION...
I took the time to revisit the DCU now knowing that it's controlled by "Rear Defrost" button.
Look what I saw...
PERMANENT is default value
The setting PERMANENT (default) threw me off
It should read "UNLIMITED" or "Rear-Defrost"... since we know mirror defrost is not actually permanently powered ON.
DCU can shut off heater after time out
MIRROR HEATER TEMPS
MIRROR HEATER TEMPS
Temps optional settings
Icant make sense of this setting besides Temp3 = (Temp1 + Temp2)
driver-side active options
There are available options to time out mirrors independently of the rear-defrost control.
mirror heater mode... PWM: YES.
mirror heater mode... PWM: YES. (DE translated EN)
Top level menu: modules selection
DCU Menu : Variant Coding
Variant menu:
Variant menu: "Ext mirror"...
personalized options saved ... All set!
Old Oct 19, 2025 | 07:43 AM
Antoniio's Avatar
w212 e350 CDI BLUETEC 4 MATIC STATE
What diagnostic machine did you use to code it? Thank you.
Old Oct 19, 2025 | 01:15 PM
CUSTOM CODED OPTIONS
I did this using the LAUNCH cReader MB Elite
acailable around $125 or so.
Both SAM's, NTG, IC-Display... modules can be Variant coded.
Be sure to backup your own module before trying new settings. Every car use slightly different config.
