Change keyfob battery frequently?!
These cars like brand new, 100% fully charged batteries. It seems hardly any use will drop their capacities just enough to cause the warning.
My car has shown "Change Key fob Battery" for almost a year, now.
Obviously use new fob batteries... I bet you knew that.
What drains both car and fob batteries is when the car keep polling it's security lock devices. To prevent that busy work: LOCK your car even at home.
> Drain fob battery has a root cause:
new battery every month is not a fix but a bandaid.
The next step requires to sanitize the unstable CAN-B Modules starting with:
- a full OBD scan
- reboot
- cleaning GND and
- soldering poor connections
Then your fob battery will last forever like 2, 3 or more years and doors/trunk will unlock reliably like any Japanese car.
Chinese Mercedes: a "C260 L" ... Long-base Compact !
Then theres a notice:
Doing the battery reset works for about one month, but after soldering the solderless pins I can't even remember when was the last time I had to replace the FOB batteries.
It's a very easy job, don't be intimidated by it.
Andre: now that you've seen how good a few simple steps can deliver chaos free operation - You realize our cars were engineered to deliver the Mercedes-Benz experience we've to expect.
Here is more simple-fun for the engine electronic control:
- REBOOT chassis (Sanitize SAM-CGW!)
- FLOAT main battery (minimize dropped voltage)
- ALT-LIN stable chassis voltage (coils...)
not to mention effective oiling with MOD-X.
The whole chassis is extremely sensitive to voltage variations. May be great only up to 3 days... then you begin wondering what's up with CGW that's bugging the ECU-TCU.
What we're dealing with are not single items but a system of interconnected CAN Modules.
When the Keyless is bugging CAN-B with slow retransmits it impacts more than what we think it should.
Bosch CAN is not a perfect world of isolated traffic packets. Reduced busy-work shows experimental improvements. So more free goodies available after soldering.
MB E200: 2L 4Cyl. - Perfect for Hong-Kong heat...
Post #17 has the instructions for the keyless go module.
Do install CR2032 instead of stock CR2025.
The coin cell seriously look like it was downgraded to be undersized. 2032 is still a great match.
- a full OBD scan
- reboot
- cleaning GND and
Once you have installed new keyfob coin cell there is a procedure to clear the "replace battery" error screen.
Search for that error message on youtube.
there's another procedure with key on/off press button to reset the display error message.
I know this procedure is extremely RETARDED... it should clear itself once everything is made ok,
yet it does not.
It makes absolutely no sense to me why Mercedes would create a system where the car appears to talk with the keyless go fob endlessly when there is no particular event happening with either the fob or the car itself. The car itself, parked, turned off, has no function that I know of that would require a check to the key fob. Certainly, the key fob itself would have no reason to attempt to interact with the car. So why the continuous conversations?? Is that what is really happening?
