Before I have my wagon towed to the dealer…. Need help!
Current symptoms:
- Persistent check engine light, with a P0304 (cylinder 4 misfire).
- ABS and transmission stuck in Park—no gear shift possible.
- Various CAN bus communication faults: N73 (EZS) and ISM control unit errors (codes 475300, 475A00, 631E00,
Even after the NO SHIFT warning appeared, the vehicle starts up just fine, and the steering wheel turns as well, but I can’t shift. I have replaced all the spark plugs and ignition coil on cylinder four and also swapped newer with a known good one, but still the issue of misfire persist. I was told by an MB technician that he thought my in intake manifold plunger had failed, so I’m thinking that maybe the reason for the misfire, but I’m not sure
I know this is a lot to digest.I need directions on what to check next would be greatly appreciated.
AUTOZONE OBDII SCAN
AUTOZONE OBDII SCAN
AUTOZONE OBDII SCAN
Swapped these relays in front fuse box
https://www.fcpeuro.com/products/mer...ierburg-516475
I’m really praying that this is a wiring or ground issue as the EIS and ISM both started throwing codes around the same time so either I’m very unlucky or something else besides those units is the culprit.
As for the rebuild kit for the top end - I have heard from more than one person that it is just easier to buy the new one. A guy I know (very good mechanic) got frustrated with rebuilding his (on and off a few times) and finally - seriously threw it across the garage and got the unit as a whole (as in the link). There are a few cheaper sites...but the FCP is complete....(I have to put one of those onto one of my cars).
Was your transmission issue due to the ISM or DSM? I may end up just having it towed to the dealer since Mercedes will pay for the tow and I have connections there from when I was a service advisor.
autozone chassis scan - Status data missing
ECU: the engine No4 missfire does not appear to be the top issue today.
EIS/EZS: keyslot module appear to be seriously disrupted, that's all. Check ESL activity also.
ISM: tranny PRND shifter can stay put for this time.
Chassis voltage appears reasonable at 14Volts.
> Fault SCANNER Consideration...
You've pulled relays and fuses that may have STORED new faults in a number of good modules.
An ACTIVE status is required for fault consideration (some stored faults are really live transients)
Not having a scanner is going to require use of local professional services.
As a former MB Sce Adviser you can already write your service slip.
You car really need to be diagnosed first, specially the misfires. Based on your steps we can already guess it's not ignition, perhaps injector.
> Next time...
Do buy a scanner to help you see disruptions maturing into the snowball you are facing now.
Don't pull anything out of a powered SAM.
Be proactive with misc services:
+ Engine oil +
+ Brake flush +
+ 4Matic +
+ Cooling system +
+ air/cabin filters +
EIS/EZS: keyslot module appear to be seriously disrupted, that's all. Check ESL status also.
ISM: tranny shifter can stay put for this time.
You've pulled relays and fuses that may have STORED these faults in a number of good modules.
> Next time...
buy a scanner to help you see disruptions maturing.
Don't overlook misc service: Engine oil + 4Matic + coolant + air/cabin filters.
I also agree that the misfire is of less importance as the engine does seem to run well. I’ve done my best take as good care of this vehicle as I can and stay on top of all the preventative maintenance items. Although I’ll admit, wiring and electrical is not my strong suit.
We almost never saw vehicles with this age at the dealership when I worked there, so I rarely ran into any issue like this.
Which scanner do you suggest for Mercedes actually pinpoint individual modules and not just generic codes like most?
- It has 100% comprehensive coverage
- It has fault descriptions
- It has pdf reporting
- It gas live data
There are many better scanners tablets and dongles.
The key is the coverage of W212 era, not the latest models with security tokens.
Technician is going to clear current faults to see which are first to return.
EIS' a serious gem that showcase solderless pins.
- It gas live data
it looks like the only difference between 1.0 and 2.0 is the improve improves hardware of the reader. Both seem to do the same functions.
I wanted to add that I’ve only use the keyless go button with this vehicle and never actually turned the key except when we were setting the service interval. Would my EIS still have the soldering issues?
couple screws to access the special pins of interest
Show us the circuit board if you can
Work on top of a clean newspaper the module has two board sandwiched if my memory serves me
after a short night flying over to sunny Miami.
beautiful Caribbean sashimi 😋
This module includes a couple optical sensors we are going to clean while in there.
- solder loose pins
- clean dust
- reassemble module
- reinstall module
- power up chassis batteries
- clear live faults
PLAN B... fresh genuine parts
- solder loose pins
- clean dust
- reassemble module
- reinstall module
- clear live faults
one thing to mention though… I’ve never soldered anything in my life. I’m thinking about finding someone at the shop or possibly finding a person on NextDoor that knows what they’re doing. Disassembling and cleaning shouldn’t be an issue.
I’ll report back with photos of the internals.
Open up the enclosure so we can be clear about what poor connections need 5mn job.
When I saw your picture, I thought you got a cast after working on this. Hope everything heals spot on.
show us the back side too
A + B are the troublesome pins - C are the optical sensors
this is the solder side showing solderless pins
3x sets of pins that should be soldered
Note the Power supply section shows 35Volts filtering caps near the 5V integrated regulator (where Audio amplifier is built with 16Volt caps.. lol)
Is there anything else I need to do as far as cleaning the board or anything with those caps?
I’ll get a picture of the back of the board as well that you requested. Be right back
One of my good buddies who used to be a body technician then advisor has a soldering iron and he’s going to help me tonight.
Wipe the optical sensor gently a bit so you don't create static on the plastic to attract... dust!
detail of the 3-pins used to run the dual RF coils (this don't need particular attention)
soldering assignment in 3 groups
If you want to keep it quick, don't remove the circuit board from the trst of the lock. Solder pins from the
top side... solder will fill the gap and make good connections.
Last step is to make sure, soldering pins did not create any unintended solder bidges.
Lets see an after picture...
Thats all there is to this EIS module!
Next installement : KGo module festures 3 times more loose pins.
