E-Class (W213) 2016 - 2023
Radar Sensor
Old Mar 31, 2021 | 07:04 AM
Ivanerrol's Avatar
W213 - E220d. W212 - E350 wagon
Radar Sensor
Anybody know the exact location of the radar sensor in the back bumper of the W213?
I'm not talking about the small sensors dotted around the bumper itself.
There's a main squarish histrionic unit hidden somewhere.
I've been under the car and can't find it.
I have the "Radar sensor dirty" message. Cleaned the front unit behind the grill star throughly - many times.
No cruise, no proximity sensors, no lane changing or keeping assist.
No codes.
Old Mar 31, 2021 | 10:10 AM
konigstiger's Avatar
'71 Pinto
VIN?
Old Apr 1, 2021 | 02:19 AM
Ivanerrol's Avatar
Hi KT.
VIN is Australian delivery : WDD2130042A324857 - Built Aug 2017.
bought a couple of months ago with 5000 miles. (8000 kilometres)
First job I did was swap 20 inch AMG wheels to 18inch.
Old Apr 1, 2021 | 09:50 AM
'71 Pinto
Shown on 212 same location for 213.
File Type: pdf
Old Apr 1, 2021 | 06:22 PM
Ivanerrol's Avatar
You are the Champion Konigstiger.
Old Apr 1, 2021 | 06:23 PM
Ivanerrol's Avatar
Now all I have to do is get at it.
Old Apr 7, 2021 | 05:50 AM
Ivanerrol's Avatar
Turns out.
Dealership did their scanning and found that the front sensor bracket which holds some electronics is faulty.
Cost of the new part - AUS$ 4,100 plus $ 850 for it to be fitted and the Distronic radar recalibrated.
Part failed in heavy rain. - at the time with 7000 miles only.
Lucky I'm not paying, but this begs the question.
When the car is out of warranty am I actually game enough to drive the car in a heavy tropical rainpour.
Old Apr 7, 2021 | 07:48 AM
DFWdude's Avatar
2016 E350 Sport
Originally Posted by Ivanerrol
Turns out.
Of course you are. At minimum, a car is an engine, four tires and a steering wheel that takes you from point A to point B. We lived without bumper radars for the first 100 years of the automobile. You may not like it, but you can survive without it when it fails.
The good news is that the dealer found the problem, and will fix it in warranty. Chances are that the problem may never return (out of warranty) in the future.
Old Apr 7, 2021 | 09:04 AM
ua549's Avatar
With today's complex systems, I am no longer willing to own a car that is out of warranty. I learned my lesson with an out of warranty airmatic suspension failure. The warranty on my '18 E300 is up in 4 months. It will make a nice trade-in as it is in pristine condition with 13k miles and new non-run flat tires w/spare.
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
What’s a “faulty” bracket? Like broken or loose? I don’t see how rain ruined the sensors, unless they were physically compromised and water got inside.
Old Apr 7, 2021 | 07:16 PM
Ivanerrol's Avatar
Very good question.
I'm assuming water ingressed into the electronics via wicking through the wiring.
I'll ask my service guy for a detailed explanation.
And then ask him to cover the connections in epoxy or something to prevent a repeat.
I've seen on other forums that this seems to be somewhat common - - probably bad design.
No radar sensor - no cruise control. Cruise is something I require for a physical problem.
I drove 2,000 kilometers using my left leg on the accelerator. - I'm not wanting to repeat that.
F.W.I.W. my service advisor told me to let the warranty run through, then the extended warranty. After that change up - an electronics issue could total the car after 10 years.
My W212 wagon had a 10 year warranty period - which has just run out.
Old Apr 9, 2021 | 07:00 PM
Ivanerrol's Avatar
Thanks again to Konigstiger.
I found an entry into TSB's for this problem he posted up on Benzorg.
TSB LI54.70-P-066764 - deals with this very issue.
I've printed it out and am heading off to my local dealership to see if they are aware of the TSB.
Being Australia - We don't get all the recalls and fixes which occur in ROW - scandalous.
Old Apr 10, 2021 | 08:11 PM
Ivanerrol's Avatar
Turns out to be - fault in ABA control module.
Radar sensor dirty is just an indicative message that there's an error in the control module.
Old Apr 11, 2021 | 11:20 AM
'71 Pinto
