E-Class (W213) 2016 - 2023
2017 E300 W213 M274 engine piston
Old Nov 12, 2021 | 01:32 PM
yc25744's Avatar
2017 E300
Angry 2017 E300 W213 M274 engine piston
Hello Guys,
Anyone having an issue with the W213 E300 engine piston?
Currently, I have a 2017 E300 RWD around 57K miles and have a piston #1 failure.
Engine oil goes directly into piston #1 due to piston issue. I did not take this car to the dealership and just went to a local shop because of the cost.
I heard that the M274 engine has an issue with its piston.
Does anyone know why this is causing it and any lawsuit regarding the M274 engine?
I don't think I can even afford to fix this one.
The local auto shop mentioned that there was a C300 around 27K that had the same issue and the dealership quote her 25K for an engine swap.
I will keep updating this post when I get quotes from a local shop. They are doing a detailed inspection of my car right now.
Thank you
Old Nov 12, 2021 | 01:37 PM
yc25744's Avatar
2017 E300
btw I just bought a used car around 52k miles and drove 5K miles.
It all happened on 57K mile
Old Nov 12, 2021 | 01:39 PM
W205C43PFL's Avatar
Sorry to hear about the issue but I am afraid that it is common for the M274 engine, hopefully something works out in your favour, sorry to hear about it : (
https://mbworld.org/forums/e-class-w...***-300-a.html
https://mbworld.org/forums/c-class-w...64-2019-a.html
https://mbworld.org/forums/c-class-w...5-k-miles.html
Edit: Re-reading your original post, it seems that you are indeed aware of the M274 having issues with piston cracking, hopefully the advises posted in the 3 threads are helpful, all I can say is good luck having it fixed. Sorry to hear about the issue. To answer your question, I am unware of any lawsuit, unfortunately. To answer your other question, the suspected cause is manufacturer defect and possibly bad gas, the former is more likely though. Early models such as the 2015 had a wrist pin recall, I don't really think that was the cause of piston failure for any subsequent model years though.
Old Nov 12, 2021 | 02:40 PM
yc25744's Avatar
2017 E300
Compression result
I have received compression test and piston #1 is having high compression I thought crack piston cause low compression.
I dont know what is going on....
Old Nov 12, 2021 | 02:51 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
No extended warranty on this car?
Anyone with an M274 engine NEEDS an extended warranty. There is a known defect with the pin wrist on piston 1, Search the forum, and you will find a few threads, some are in worse conditions than others.
I would like to see if there is correlated data between the ECO Start/Stop, the piston failures, the turbo, and the extremely compact engine package in these cars. Way too many threads with piston 1 damaged. Can it be the oil specs related, or service frequency? It could be for higher mileage, but before 70K, I just cannot take it as the owner's negligence.
Old Nov 13, 2021 | 09:01 AM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by yc25744
Hello Guys,
Thank you
Sorry to hear of the engine situation. Agree with the previous post that this is a common failure for the M274 2.0L four cylinder engine. This engine is used in the W205 C-Class, W213 E-Class and X253 GLC-Class. It might also be used in other vehicles outside the North American market. Years affected are as late as 2018, as posted on this site. Therefore there hasn't yet been established a "clean point" for engine production dates.
Old Nov 13, 2021 | 09:48 AM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
I have the V6 in my 2019 E450:
Question, if this is common why hasn't there been a recall? Replacing engines at 50,000 miles is highly uncommon.
Old Nov 13, 2021 | 10:16 AM
W205C43PFL's Avatar
It is actually pretty rare from what I can tell although most cases are reported on the forums therefore it seems to be more common than it really is.
Don't worry about your M276, it is reliable and does not suffer from such defect. As the V6 (in your case, the M276 has been out for a long time, most if not all imperfections are solved over these many years) it also doesn't have to work as hard as the i4 and the cylinder sleeve used is different. The M274 isn't young either though but the variant used in the C300 is "relatively" new.
To the op, I sincerely hope something works out in your favour.
Old Nov 13, 2021 | 10:22 AM
JCM_MB's Avatar
https://www.carproblemzoo.com/mercedesbenz/c300/engine-failure-problems.php
There are TSBs dealing with piston issues on this engine: therefore, it is not isolated to the forums only
https://www.google.com/url?sa=t&sour...Rqrkxd8MdB7DVk
Also, MB have used 3 engine models, M274, M264, and M254 in less than 10 years for its 4 cylinder lineup. Fast introduction of improvements, or fast removal of major issues? It takes a fortune to retool engine assembly lines, and minor modifications of the car assembly. Reason each model last @4/5 years for a newer model. My take at this point is not buying, perhaps leasing, 4cyl turbo MB engines until the issue is clearly addressed
Old Nov 13, 2021 | 11:54 AM
W205C43PFL's Avatar
https://www.google.com/url?sa=t&source=web&rct=j&url=https://f01.justanswer.com/73bbchevy/86007b34-e4d8-4381-bb9e-056627bd4e98_LI03.10-P-060916_Ver_16_piston_wrist_pins.pdf&ved=2ahUKEwjf5 Jyt1ZX0AhXyT98KHci1DVsQFnoECBYQAQ&usg=AOvVaw 3mDw7Jp-Rqrkxd8MdB7DVk
Thanks for sharing the links and the service bulletin. You are right that not all cases are isolated to the forums but as what I stated in my previous post, most cases are indeed on the forums.
One of the links you posted has to do with the wrist pin recall which I did mention in my previous post but OP's car is not affected by the wrist pin recall, there is actually another defect within the engine that has not been identified by MB or they just haven't admit it yet. From the same link you posted, out of the 82 cases being part of the Engine and Engine Cooling problems, the majority are from W204 therefore uses a NA V6 and not the M274, the rest were from the MY15 which is affected by the wrist pin, a few were from post MY15 vehicles but it is not the same issue nor does the service bulletin applies.
I love to be wrong because that way OP will have a much higher rate of success in getting their dealership to fix the problem based on a recall and for free.
Old Nov 13, 2021 | 11:56 AM
W205C43PFL's Avatar
Yup, I too agree that it isn't a good idea to buy any of MB's 4-cylinder vehicles right now until they sorted everything out. I am afraid that it might take a while because MB did announce they are ceasing development of most if not all ICE to focus on electric.
Old Nov 13, 2021 | 02:37 PM
chassis's Avatar
2017 GLE350 4MATIC
The M274 is becoming increasingly known for piston cracking as reported on this site. Whether one wants to believe it or not, the failure is being reported. Engine replacement at fewer than 100k miles is an example of MB's pathetic reliability. Refusal to support the customer with meaningful financial assistance on this topic is an example of MB's pathetic customer care.
The M264 is descended from the M274. The newer M264 uses many foundational parts in common with the M274, such as crankshaft and connecting rods, and many others. Pistons, however, have been updated. Reason? Only MB knows. Maybe they had a problem.............
The M264 is currently used in W205 and V167. Also W213 and X253? So far on this site no reports (yet) of piston cracking on M264.
Old Nov 13, 2021 | 10:32 PM
JCM_MB's Avatar
https://mbworld.org/forums/glc-class...ml#post7957743
The issue with 4cyl turbo continues, even with MY 20.
Old Nov 13, 2021 | 10:47 PM
chassis's Avatar
2017 GLE350 4MATIC
@juanmor40 The link you provided relates to a bearing issue, not a cracked piston, correct? Not good for anything like that to happen.
Old Nov 14, 2021 | 08:26 AM
JCM_MB's Avatar
Definitely, I should have been more explicit and just mentioned the engine overall. From the introduction articles these engines are all related, kind of cousins, and share perhaps "too much" . I recall reading a similar issue with a M274 but need to find it again, sorry.
Old Nov 16, 2021 | 11:38 AM
MBNUT1's Avatar
2010 E350 4Matic
My read is that is not a compression number but an RPM number that somehow gets translated into health of a cylinder. It's as though they are measuring some kind of pulsation and translating that into a RPM number.
Old Nov 18, 2021 | 12:31 PM
yc25744's Avatar
2017 E300
Hey guys,
I got a quote from a certified Mercedes shop.. It shows me 18K..
Should I take it to the MB dealership and negotiate?
attached image of estimate below.
any advice?
Thank you
Old Nov 18, 2021 | 12:32 PM
yc25744's Avatar
2017 E300
Old Nov 19, 2021 | 10:42 PM
chassis's Avatar
2017 GLE350 4MATIC
Reading a number of posts on this site from different vehicle platforms, there won't be much assistance on the replacement cost, but a discount on a new vehicle may be offered.
Old Nov 27, 2021 | 07:58 AM
Mercedesrwd's Avatar
W213e250
what oil do you use in the m274 engine? probably because there is too much calcium in the oil. Burning "LSPI" super knock. Oil with the ORI MB standard 229.50 or other higher?
Old Dec 13, 2021 | 03:30 PM
yc25744's Avatar
2017 E300
I have bought a used car around 52K milage and broke down on 57K. The previous owner changed the oil for me on 52K but do not know what kind of oil.
Old Dec 15, 2021 | 12:45 PM
W213e250
here I would look for the cause of the failure. These engines do not like too much Calcium. Here in Europe we use c3 API SP or API SN + oils. the use of the wrong oil may end up wrong.
Read about "LSPI"
Old Dec 15, 2021 | 06:02 PM
scvillareal1's Avatar
C300
I replaced my engine for 10,813...You guys have engine failures... I address that in my Youtube video. Check it out. I just replaced the engine on my 2015 C300 abou 3 months ago at 49k !!!
Its a known defect from Mercedes-Benz and they wont do squat to help us out.
Steve - YouTube
Old Nov 29, 2022 | 12:13 AM
a_radtke's Avatar
2017 Mercedes e300 w213
W213 engine issues
Have had my w213 and never had any issues. All of a sudden, my engine light turns on and starts flashing. Drive it home and get it towed to a certified Mercedes shop (that my buddy works at). After diagnostic, he tells me the cylinder 1 misfire is a piston issue and the vehicle may need a new engine. The car has 78,x miles and rand perfect until today. MB towed vehicle to local dealership and now waiting for them to re-diagnosis it and give me an update ... Supper worried right now ...
Old Nov 29, 2022 | 07:01 AM
chassis's Avatar
2017 GLE350 4MATIC
Sorry to hear. Hopefully it won’t be a cracked piston. Please keep us updated.
