E-Class (W213) 2016 - 2023
Humming sound coming fom dashboard when getting in car
Old Jan 14, 2024 | 11:26 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
Humming sound coming from dashboard when getting in car (before starting)
It's coming from inside the dashboard (where the buttons are)
sounds it bit like the ventilator, though that's not it.
don't know if it always did this, and that it's just more noticeable now ...?
it is rather cold at the moment with temps around freezing, though can't imagine how this would be a factor?
Old Jan 14, 2024 | 01:12 PM
ua549's Avatar
Perhaps it is an electronics vent fan being a bit noisy 'til it warms.
Old Jan 15, 2024 | 03:59 AM
Egonvdv's Avatar
thanks @ua549
can anyone confirm that such a hum indeed is present when getting in the car ( diesel hybrid)
I'm starting to believe the hum was always there, just that it's louder now for some reason ?
Old Jan 15, 2024 | 03:52 PM
TennesseeZ4's Avatar
2019 E450 wagon: 2019 BMW 430i: 2013 Chevy Traverse: (departed)2013 SL550 & 2019 E450 cab
When we get in the S213 wagon there is a noise, rather like a subdued humming sound from the cockpit area. My MB tech tells me that it is the pre-tensioners for the seat belts. Could be a deflection, but for me it makes sense, if not it may be the self-leveling suspension in our wagon. Good luck!
Old Jan 16, 2024 | 05:58 AM
Egonvdv's Avatar
i guess the hum was always there, it's just got a bit "louder" now and then ...?
Old Jan 20, 2025 | 09:55 AM
Egonvdv's Avatar
For a while the "problem" stopped, but the humming is back every now and then
Sometimes before starting, sometimes when switching off ...
Old Jan 20, 2025 | 02:37 PM
W205C43PFL's Avatar
Mercedes E-Class (W213 MBUX) humming sound coming from behind dashboard
some coil or fan?
Old Jan 22, 2025 | 09:18 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
Cold air causes things to expand which can result in noises from things that were silent in warmer conditions. Does it go away as the car warms?
Old Jan 22, 2025 | 09:30 AM
Egonvdv's Avatar
the clip is from after a 45min trip, so definitely warm.
it's pretty loud too , you can hear it even with radio on at normal level
Old Jan 22, 2025 | 11:03 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
It sounds like a fan bearing that may be going bad. They are likely a sealed unit so if it's the cause, the fan likely needs to be replaced. In any case, some disassembly is likely required to diagnosis and repair. Maybe a borescope with a mic or a stethoscope can be used to pinpoint the location of the sound.
Old Jan 22, 2025 | 11:11 AM
Egonvdv's Avatar
thanks! will have the dealer look at it on next service
Old Jan 22, 2025 | 07:10 PM
np6345's Avatar
'19 E300 w/ activated Multibeam
sounds like the headunit fan. I remember taking apart the center console and accessing it before, they can get quite hot. I've never actually heard the fan on mine when the console is installed in place.
