E-Class (W213) 2016 - 2023
Assistance features inoperative
Old Nov 5, 2024 | 10:08 AM
Oshguy06's Avatar
2023 E450
I have a 2023 E450 with the driver assistance package. Starting two weeks ago I started getting messages upon starting the car in the garage including "Active Steering Assist Inoperative", "Active Stop And Go Assist Inoperative, See Operator's Manual", "Active Lane Keep Assist Inoperative". If I try to turn these features on I get the message "Function Unavailable" and they can not be activated during the drive. However, if the car is parked outdoors for some period of time, upon restarting the car these functions will automatically be active. Sometimes when arriving home, with all these functions still active, upon putting the car in the garage one of the above listed messages instantly appears. Does anyone have any idea what might be causing this? Everything worked perfectly until this started. I might mention too that Live Traffic is very intermittent on this car as well, and "Hey Mercedes" very often results in "I'm sorry, I can't help you with that right now." I don't know if all this is somehow related, but it's all getting quite annoying. I suppose at some point I'll nee to get the car to a MB dealership to sort this out.
Old Nov 5, 2024 | 12:25 PM
BenzNinja's Avatar
Former Vendor
can be anything from bad, dirty sensors, cameras, and so on
only a proper diagnostics will tell
If you are not under warranty, you could get our service and safe upto 80% on repairs
if you are under warranty, who cares. just take it to the dealer
Old Nov 5, 2024 | 12:30 PM
Oshguy06's Avatar
2023 E450
It is under warranty, I’ll have to take it to the dealer I suppose.
Old Nov 5, 2024 | 01:06 PM
BenzNinja's Avatar
Former Vendor
Yes, best option
These cars have lost of modules and without proper diagnostics, not much to fix
Good luck!
Old Nov 5, 2024 | 01:18 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Why would you do otherwise?
FWIW, while driving this has happened to me as well. Usually withing 10 to 15 minutes it clears itself up. Other times, like you, it is not working, I make a stop, turn off the ignition and when I start the car everything is working fine.
Go figure!
Old Nov 5, 2024 | 01:43 PM
rivinus.stenson's Avatar
I have a 2021 E350 and can confirm these are exactly the issues I have experienced as well. They are intermittent and turning the car off for a while usually resets it. Have not been able to find a solution after taking it to the dealer multiple times over the last 3-4 years.
Old Nov 8, 2024 | 03:17 PM
Cosworth2000's Avatar
2022 E53 AMG
What do you get for $499.00USD VIP?
Old Nov 18, 2024 | 04:32 PM
Oshguy06's Avatar
2023 E450
Here today, gone tomorrow.
I made an appointment to get the problem checked out. The very next day the problem vanished and has not returned. The service manager said the problem could have been caused by any number of things, but if it comes back bring the car back in. It's been two weeks since it last occurred and the car has been driven daily without and issues, so perhaps it fixed itself..... who knows.
Old Nov 21, 2024 | 04:56 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
built-in chaos included... no extra cost
I have read this short thread and have good news....
The good news is there is a quick free fix: chassis REBOOT (*)
This is a mature problem MB has producef for over a decade. The poker face until warranty expires is can not reproduce!
This is caused by transient network disruptions. Whats involved is the combination of marginal voltage and poor connections. Under conditions high-speed modules disfunction sometimes earning an ECU/TCU "limp mode" in the fast lane.
The bad news is :
-- long term fix involves reworking VIP solderless modules.
-- the free fix temporarily sanitize the CGW swamped by rogue modules.
-- I have this survey detailed under my signature plus here as $3 fix for free because you've paid enough.
-- THIS IS NOT ANY RANDOM MYSTERY! It purpose built electronics that already runs marginally under warranty.
Easily fixed though with NEW MODULES the way the business was designed to be run:
  1. ESP!,
  2. SCM!,
  3. EIS!,
  4. ISM!,
  5. SAM/CGW,
  6. MFK,
  7. AAC,
  8. DCU,
  9. ... (ECU/TCU: ok!)
Choices are: use the parts-canon or troubleshooting labor for less than $25k.
Old Mar 21, 2025 | 01:51 PM
Oshguy06's Avatar
2023 E450
UPDATE:
After a period of no error messages following the service visit in November, the error messages returned. These messages appear every time I start the car and randomly as I'm driving, and its getting VERY annoying!! I took the car back in February and the technician reported that there were fault codes stored, (U042902) - implausible data were received from the steering column module. General signal fault U0429E1. The service manager said that they consulted with MB and were told to NOT replace the steering column module, that the fault codes in the driver assistance systems control unit are precautionary messages. He said that new coding parameters will be available second quarter for the HOSWD module and the new software will be installed when it's available.
Now the big question..... what are the chances that this will fix the problem??
Old Mar 21, 2025 | 04:12 PM
STANDARD MB ISSUES
UPDATE:
30% chances.
This is just buying time to expire warranty coverage when expensive parts can start flying on your dime.
This refined CAN chaos is far from new. Poor networking is engineered from factory with solderless peripheral modules and unstable voltage swings.
The core modules are built with reliable connections, all CAN-B the opposite and in-between networks CGW benefits simple reboots.
Hope everything does stay well.
Old Apr 10, 2025 | 02:22 PM
Oshguy06's Avatar
2023 E450
Took the car back to the dealership after literally hundreds of warning messages. Steering column module replaced, no improvement. Now waiting for a new steering wheel. What’s next after that??
Old Apr 10, 2025 | 02:42 PM
JTK44's Avatar
Lemon LAW!
Old May 16, 2025 | 07:08 AM
Oshguy06's Avatar
2023 E450
So ar sp good
It's been a month since a new steering wheel was installed and so far no error messages and all systems are working. I hope this lasts!
