Turning off car with AC/climate control left on?
Tried searching but haven't found a definitive answer. Have my 2024 e350 for 3 weeks now (love it), and I was always taught to turn off climate control before turning the car off, like with older cars. However, I hear that it no longer matters if you leave it on when you turn off the car, and the car doesn't require more energy to start with your climate control turned on.
What is the best thing to do? My guess is leave it on so when the car is remote started, the temperature will reach the ideal result.
https://www.carcomplaints.com/news/2...nt-final.shtml
https://www.lieffcabraser.com/defect...-benz-ac-mold/
Last edited by W205C43PFL; Aug 17, 2024 at 02:55 PM. Reason: Attached links of the lawsuit
But consider the starting process. AC compressors usually have a 30 amp circuit breaker on them. 30 amps isn’t nothing, and is an unnecessary stress being put on the starter and battery. Also, compressors can consume 30 horsepower when running. 30 horsepower isn’t nothing when starting.
I make it a habit to turn off the AC before I switch off the engine. Also, I like for at least 2 minutes to elapse, with the circulation fan running to help clear out any condensation in the ductwork.
That way I don’t have to remember to turn the AC off prior to starting. On startup, I try to let at least 2 minutes to elapse before turning on the AC, allowing thorough engine lubrication before putting an additional load on it, and letting any hot air(hotter than ambient) pass through the ventilation system to ease the load going through the condenser.
In the long run, it doesn’t probably make a big difference, but it adds to my peace of mind that I am treating my car right, so it will never treat me wrong.
This however has nothing to do with the OPs question of turning the AC off before shutting down the car. It's only relevant when the vehicle is on and the engine stops from the start/stop system. When you shut off the car, the AC turns off with it. You still have accessory power for the entertainment system but all AC functions are off on both models. When you open the door the entertainment system shuts down. When starting the car, the AC does not immediately come on. It takes a few seconds for everything to initialize. Leaving the AC on when shutting down the car does nothing to harm the car and there is no benefit to turn it off before hand. Running the car without the AC for long periods can cause mold, but that also has nothing to do with the OPs question.
Sorry for veering off topic.
