Noise when driving after having the car sit for five days after car wash.
I washed my car on Sunday, and I had it sit until this morning, I was using my Mustang because of the weather has been so nice. I posted about this a while back, but I know it’s normal when the brake gets caught on the car to hear that loud bang when you first drive the car, but because the car sat for so long it was really stuck this time. And I had to almost floor the gas for it to take off. After that, it was completely fine.
however, I had heard a noise when I was driving around 20 to 30 mph, like something was rotating and hitting the axle or something like that. After about two minutes, it disappeared. My guess is it something wet from the car wash, I had to get moving again? Anything to be alarmed?
I drove about 3 miles to my dermatologist, parked it for 20 minutes, came out and it was fine. Drove home with the radio off and didn't hear anything. I'll definitely keep an eye (ear) on it until I leave for vacation on Sunday. But I think it will be ok. Maybe something was stuck inside because I literally had to press down on the gas to release the brake after the car wash. It's my fault, I should've backed it out of the garage earlier this week to release the brakes from the rotors. I hate how after you wash it they get stuck. But my old S class did that too.
The car wash is not near my house, it's in the next town over, and I get on the highway to get home, about 12-13 minutes away. I bring the car home, go over it with a towel, dress the tires, do the windows, etc, then parked it from Sunday afternoon until this morning. My guess is something oxidized and got stuck and it had to be driven to make sure it rotates and everything was ok. It was like a ticking, that got faster, and then disappeared after 0.5-1.0 miles of driving, and hasn't come back. I'll be at my office for about 5 hours now, so I'll see how it is when I leave if it is ok.
The general consensus is that after washing, drive and use brakes long enough to dry the pads and rotors. If you can’t, make sure the parking brake is off when shutting the car down. And on startup, before putting the car in gear, release the parking brake, if it is engaged. These habits should prevent any of what OP is describing, from happening.
I purposely don’t drive my SL in the rain, but if I do, I ride the brakes every so often to keep the rotors hot enough to provide normal braking.
Also, if anyone has carbon brakes, and or rotors, they act like sponges when water is present, and if allowed to be wet, have significantly less than normal braking power available.
There is a specific method for those types of brakes to be warmed up to provide normal braking.
The brake rotors when wet, either driving through rain, or just washing your car at home will rust. This is perfectly normal. To remove the rust, while driving apply slight brake pressure. The brake pads will remove the rust. Again this is perfectly normal. (also very good practice when driving in the rain: regularly applying slight pressure to the brakes will keep the brakes/rotors functioning as designed)
As I posted on another thread, because I had to replace the rear discs and pads at 30K miles because of the electronic brakes on the rear, before engaging the transmission I always release the brakes by pulling the brake lever.
I was looking at a 2022 E450 CPO with 28K miles. The description noted: "Rear discs and pads replaced". So the electronic brakes not properly releasing and causing damage to the rear discs and wear of the rear pads is common.
FWIW, I am still on the original pads on the front: 2019 E450 with 55K miles.
Hope this helps!
Don't feel bad, @W205C43PFL, Voice to Text on my mobiles is always trying to make me look like a complete and utter drooling retard... in 4 different languages. Nowadays, I have my messaging apps set to a 15 second sending delay just so I can at the very least, give the text it transcribed a glance to make sure it looks half way intelligent. And yes, I know how to enunciate.
It’s a takeoff on dialogue from the movie “Treasure of the Sierra Madre”
It’s a (somewhat) famous quote, that is also a misquote.
One problem with humor is, the more you explain it, the less funny it gets.
