EQS EQS (V297) sedan
Side Mirror Problem
Old Feb 12, 2025 | 07:28 PM
mercRT's Avatar
Side Mirror Problem
Does anyone have problem with side mirror adjusting button?
It’s still normal 1 weeks ago, but when I adjust the mirror today. All the button have mess up.
Even I press down up right or left, the mirror just moving up. Folding mirror button also malfunction.
is there anyway to fix this problem? Or just go to Mercedes service?
Old Feb 12, 2025 | 07:45 PM
W205C43PFL's Avatar
Hmmm, I wonder it is an update issue, since both of yours failed: https://mbworld.org/forums/eqs/90830...placement.html
Old Feb 12, 2025 | 07:51 PM
mercRT's Avatar
i’m not really sure
does all EQS 450+ in america have the same problem as mine?
Old Feb 12, 2025 | 07:54 PM
W205C43PFL's Avatar
i’m not really sure
Will need more forum members to chime in to be sure. Updates are usually staged roll out so also possible so are not affected.
Old Feb 12, 2025 | 07:56 PM
mercRT's Avatar
do you know usually how ling will they fix the problem?
is there any I can report this problem to Mercedes?
Old Feb 12, 2025 | 08:40 PM
W205C43PFL's Avatar
no I don't sadly, I don't even know if they are aware of the problem but yes you can report it to Mercedes, I don't think that will do much though.
Old Feb 12, 2025 | 08:50 PM
mercRT's Avatar
I call mercedes and They said it’s not something about error from updates. She tells me to go to the nearest Mercedes dealership
Old Feb 12, 2025 | 09:08 PM
W205C43PFL's Avatar
Sounds like a textbook response plus I doubt they will admit fault, ya sounds like you do need to visit a dealership : (
Old Feb 12, 2025 | 09:49 PM
mercRT's Avatar
i’ll wait a fews days to see if it back to normal
then decide to go to dealer
Old Feb 13, 2025 | 12:59 PM
W205C43PFL's Avatar
Sounds like a good plan to me.
Old Feb 13, 2025 | 01:00 PM
W205C43PFL's Avatar
and if that doesn't work maybe you can reset MBUX but I am not sure it is worth going in and reconfiguring everything again, especially with the possibility the reset might not fix it.
Old Feb 15, 2025 | 05:25 AM
mapki's Avatar
I bought preowned replacement module with identical part number and replaced it myself.
It solved the problem immediately. So that, I think it is hardware issue.
Door panel disassembly is not difficult but removing decorative armrest panel was tough, mounts are very strong
Old Feb 15, 2025 | 06:33 AM
W205C43PFL's Avatar
Interesting, I see. Glad it worked out.
Looks like OP also needs to get it replaced through DIY or through warranty.
