EQS EQS (V297) sedan
Deep Dive: Digital Vehicle Key (2022-2025 EQS)
Old Jun 11, 2025 | 04:22 AM
J_Boxer's Avatar
24 EQS 580 4matic sedan Pinnacle trim w/Exec. rear seating pkg.
** Taken from https://mbworld.org/forums/eqs/91432...ml#post9175312 **
Originally Posted by runbuh
What about Digital Vehicle Key (Smartphone is your key)? That certainly comes with the 2025's. Also, even without Digital Vehicle Key, don't the 2025's have the Smart Key profile control (your key controls what driver profile is selected).
A Deep Dive on the Digital Vehicle Key (2022-2025 EQS)
@runbuh , your recent question about the 2025 Digital Vehicle Key is an excellent one, and it touches on one of the most misunderstood and inconsistently implemented features of the past few model years. The full answer deserves a much deeper dive than a simple reply, as it gets to the heart of the frustration many of us have felt.
My own experience—not having this function on my '23 450 or my current '24 580 Sedan, despite it technically existing in the owner's manual—is a prime example of this confusion. To clear up the ambiguity once and for all, I've put together a definitive, multi-part guide on the complete evolution of this feature, including how to check what your specific vehicle actually has.
Here is a comprehensive, analysis of the Digital Vehicle Key for the EQS Sedan, from its murky beginnings in 2022 to the standardized system in 2025.
Part 1: The Pre-2025 "NFC Digital Key" — Theory vs. Reality (2022-2024 EQS Sedan)
For the first three model years of the EQS Sedan, Mercedes-Benz listed a "Digital Vehicle Key" based on NFC (Near Field Communication) technology.
The Theory: How It Was Supposed to Work
As documented in the official owner's manuals, the system was designed to allow a compatible smartphone or a dedicated credit card-style NFC key to operate the vehicle.
  • To Unlock: You had to physically hold the smartphone or tap the NFC card against a specific sensor on the driver's door handle.
  • To Start: You then had to place the phone or card in a designated spot in the center console—the rubberized tray with a key symbol on it.
This was the "on paper" functionality. The reality for owners was far different.
The Reality: Why Most Owners Never Had It
The inclusion of the NFC Digital Key was elusive and highly inconsistent. Its absence on a specific vehicle was not a defect, but a result of a variable production strategy influenced by several factors:
  1. The Semiconductor Crisis: The primary culprit. From 2022 through 2024, extreme supply chain volatility meant that the specific chips and hardware modules required for this feature were not always available. To avoid production halts, vehicles were often built without certain non-critical components.
  2. Production Date: A direct result of the supply issues. An EQS built later in a model year (e.g., Q3-Q4 2024) had a statistically higher chance of having the necessary hardware installed than one built earlier in the same model year.
  3. Market & Region: The feature's deployment was not uniform globally. It was often provisioned for the European market before being considered for North America.
  4. Packaging & Trim Level: The feature was never truly "standard." It was typically bundled within the highest-level Pinnacle trim or other optional packages, and even then, its inclusion was not guaranteed if supply chain issues arose.
  5. Software Provisioning: Even in rare cases where the hardware was present, the feature still needed to be enabled via the Mercedes me connect services, adding another layer of potential failure.
The result? A feature that existed in the manual but was absent from the vast majority of vehicles delivered to customers.
Part 2: The 2025 "Full Rollout" — A Standardized UWB Revolution
The 2025 model year marks a complete reset. It is the true, standardized launch of this concept, underpinned by far superior and more reliable technology.
  • The Technology: The new system uses a combination of Ultra-Wideband (UWB) and Bluetooth Low Energy (BLE). As a key member of the Car Connectivity Consortium (CCC) that standardized this tech, Mercedes-Benz is now implementing it fully. UWB provides precise, secure spatial awareness that NFC cannot.
  • The Experience: This enables a true passive, "phone-in-pocket" experience. The car securely detects the precise location of your phone, unlocking as you approach and allowing you to start it without ever removing the device. It's the convenience promised by "keyless" technology, finally realized.
  • The Rollout: This is a full, intentional rollout for the 2025 EQS Sedan. It is a headline feature with standardized hardware, indicating that owners can now reliably expect to receive and use it. This system also seamlessly enables the "Smart Key profile control," where the car recognizes who is approaching and adjusts seats, mirrors, and MBUX settings automatically.
Part 3: The Owner's Guide — How to Check YOUR Car's Functionality
So, how can you determine for certain what functionality your pre-2025 EQS has? Here is a definitive, step-by-step diagnostic guide.
Step 1: The Software Check (Easiest Method)
Check the Mercedes me connect app on your smartphone. If your car is provisioned for the feature, you will see an explicit menu option for "Digital Vehicle Key." If this option is entirely absent from the app, your car is not enabled for the feature.
Step 2: The Physical Hardware Clue (The Key Symbol Tray)
Look at the rubberized tray next to your cupholders. If it has a key symbol molded into it, your car has the physical NFC reader. This pad's dual purpose is:
  1. Digital Key Reader: The designated spot to place a phone/NFC card to start the car.
  2. Emergency Key Fob Reader: A critical backup. If your traditional key fob's battery dies, placing the fob on this spot allows the car to read its passive chip and start the engine. The presence of this tray means the hardware exists; the question is whether it was ever activated.
Step 3: The Definitive Build Sheet Check (VIN Data Card)
For documented proof, pull your car's factory build sheet using its VIN. Several free online services can provide a detailed "data card" listing every option your car was built with.
  • Recommended Tools:
    • mb.vin
    • lastvin.com
  • How to Use Them: Simply enter your 17-digit VIN on their website. The service will generate a list of your vehicle's features and their corresponding 3-digit option codes.
  • What to Look For: You are looking for codes associated with this functionality. While the specific code for the full Digital Key can vary, its prerequisites often include 14U - Smartphone Integration and sometimes 899 - Multifunction telephony. The complete absence of any of these related codes is a definitive sign the feature was not included in your vehicle's final build.
Step 4: The Final Confirmation (Dealer VMI Report)
If ambiguity remains, contact a dealer's service center with your VIN and ask for the "Vehicle Master Inquiry" (VMI) report. This internal document is the most detailed history of your car's exact factory configuration and can confirm with 100% certainty whether the feature was installed and provisioned.
By understanding this evolution, from a theoretically-available NFC feature plagued by inconsistency to a fully-realized UWB system, we can better appreciate the significant leap forward the 2025 models represent.
Old Jun 11, 2025 | 08:45 AM
runbuh's Avatar
2023 X296 EQS 580 SUV / 2018 991.2 Cabriolet
Or just look at the window sticker of any Mercedes. If it states "Digital Vehicle Key", that car has it (not just EQ series).
Old Jun 11, 2025 | 08:49 AM
BenjaminKohl's Avatar
2014 Mercedes E350 4matic Wagon, 2018 Fiat 124 Spyder Lusso manual, 2005 Acura TSX manual
I believe code 896 is the key.
Old Jun 11, 2025 | 10:48 AM
J_Boxer's Avatar
@runbuh You've absolutely nailed it—for anyone starting from scratch with a brand-new car on the dealer lot, checking the Monroney is step one. This guide is designed to handle steps two through ten, which is figuring out the history and reality of the cars we already have.
Thanks, @BenjaminKohl ! That's a great pull.
SA Code 896 is indeed listed as "Pre-installation for Digital Vehicle Key" on many data cards. That's another excellent piece of the puzzle for owners to look for when decoding their VIN. I appreciate you sharing that.
Old Jun 11, 2025 | 01:35 PM
runbuh's Avatar
There is probably a very simple answer on the EQS models (Sedan and SUV) along the lines of "If your car was produced on or after this date, it has Digitiall Vehicle Key. We're overthinking this. Pretty easy guide is online.
https://www.mbusa.com/en/owners/manu...al-vehicle-key
Old Jun 11, 2025 | 11:19 PM
LarrikinAus's Avatar
E300 MY17
This is an excellent analysis and thread. Thank you. I've found it very helpful.
Old Jun 12, 2025 | 02:22 PM
runbuh's Avatar
Can you do a deep drive on coding our EQ's (tweaking things based enabling/disabling region specific settings/features)?
Video in motion
Seatbelt chime
Number of flashes when you partially press the turn-signal stalk
This kind of stuff is well documented for other European cars, even some off-the-wall stuff:
https://rennlist.com/forums/991/1438...it-begins.html
Old Jun 12, 2025 | 04:15 PM
AppleFan1's Avatar
2025 EQS580
I had a devil of a time pairing my iPhone to be used as a digital vehicle key. I finally gave up after spending a couple hours yesterday and today. I ended up calling Mercedes for help. They diverted me to 3 departments before I got to the correct one. I spent an hour with the lady on the other end and finally got it to work. The trick is to go to all the apps listed in MBUX and click on digital vehicle key. Then, it’s a piece of cake to pair it into the wallet.
Old Jun 16, 2025 | 02:03 AM
MB37's Avatar
23' EQS AMG
I'm not sure if my car has it or not. I just assumed it would. At one point, my FOB's battery was completely gone (I think) since I has the low battery warning but kept ignoring it. Then at some point, the car ask that I put the key fob onto the tray you mentioned above, and all was fine with starting the car. After that I changed the battery immediately.
Old Jun 22, 2025 | 02:43 PM
knirpsmbw's Avatar
EQS 450v4 Sedan
It's fairly easy via the Mercedes app as long as you have the Digital Vehicle Key option in Digital Extras and then activate it. After that, it appears as a tile called Digital Vehicle Key. What's missing from all the instructions - and it's likely I just overlooked it since I hate reading instructions - is that you have to turn off Carplay temporarily on your phone. After that the process takes a minute and when complete, restart Carplay. You won't lose any settings.
To turn it off: Settings -> General -> Carplay -> MBUX #####
What I believe happens is that Carplay hijacks the Bluetooth connection, preventing the pairing process from completing. I wasted an hour before I had this epiphany. I currently have a 2025 EQS 450v4
Old Jul 10, 2025 | 03:24 PM
hthpr's Avatar
2024 EQS 450+
There is also a Mercedes website which allows you to check Digital Vehicle Key compatibility:
https://moba.i.mercedes-benz.com/bai..._US/index.html
For mine it says EQS sedan / Apple / iPhone 16 Pro:
This device is supported for the selected vehicle with the State of Construction starting from: CY23/2 (804+054), 09/2023.
My car has both options 804+054 in the built sheet. That means it should have the hardware. Especially it was built 05/24. The problem is due to being MY24, the code 896 was never added. I read in German forums that some users are reporting EQE's built in 03/24 are using the Digital Vehicle key without any issues.
https://www.motor-talk.de/forum/digi...-t7665810.html
Probably MBUSA could enable it, but they are probably only interested in getting 25 sales with the "new feature". I'd understand if the hardware wasn't in the vehicle, but it seems to be only a software issue. I would even pay for it like the Dashcam if the store offered it. It's such a cool feature and helpful if you go to the beach, you can keep the Apple Watch on you and swim and not have to hide or worry about someone stealing your car key.
Old Jul 12, 2025 | 03:09 PM
AppleFan1's Avatar
2025 EQS580
Here’s one for you. We are in Oak Brook, IL for a wedding. Last evening, we used valet parking so I gave the driver the second smart key which my wife uses. After we got to the hotel and turned the car off, a message on the driver’s display a message say “don’t forget your smart key.” I thought it was a fluke but I get the same message every time I start the car. Additionally, I no longer see the large Mercedes star on the ground when I open the door. Instead, there are a bunch of tiny stars on the ground the display shows the Mercedes Star for a few seconds.
It must have something to do with the fact that we used the valet driver. J_Boxer or anyone else have an idea why or a solution?
Old Jul 12, 2025 | 06:29 PM
eggyacid's Avatar
ML-350, Audi Q7, Ford Taurus
mine 2023 EQS 450 shows supported.... I think if I'm reading it correctly
This device is supported for the selected vehicle with the State of Construction starting from: CY23/2 (804+054), 09/2023. Not sure which package I have but I do have NFC symbol next to the cupholder, sometimes if I put my phone too close, I get an error the NFC is searching then stopped
Old Jul 29, 2025 | 02:09 PM
404CPE's Avatar
Our car was built during March 2025 so maybe it can be activated.
