Noise from front of my GL
Old Mar 18, 2017 | 02:59 PM
Bhaxhiu's Avatar
GL450
Hi , I need help with this please. My Gl450 makes a weird noise when not pressing acelator. Doesnt mater at what speed. Press gas pedal noise is gone, release pedal noise comes back. Not sure is it transfer case or air compressor. Please help.!!!! I made a video file . It seems to me noise is like when semi brakes on downhill.
Old Mar 18, 2017 | 07:07 PM
Bhaxhiu's Avatar
GL450
Uploaded video on youtube under 2008 Mercedes Gl450 weird noise. Any help will be very appriciated .!!!!
Old Mar 18, 2017 | 10:24 PM
TX07GL450's Avatar
Mercedes Benz 2007 GL450 , 2012 BMW 528i
Is transmission shifting ok at high speeds? Does sound change at stationary, low speed and high speed ?
Old Mar 18, 2017 | 10:33 PM
Bhaxhiu's Avatar
GL450
Tranny shifts ok low/high . It is a same noise on low or high speed, as soon I move my foot from acelator noise starts . Did you had chance to check my video on youtube?
Old Mar 18, 2017 | 10:51 PM
JR-GL350's Avatar
GL 350 2010
Can't help you with the noise, but I will add the link to your video here. Terrible noise by the way, very strange.
Old Mar 18, 2017 | 10:52 PM
alx's Avatar
alx
Hm.... this sounds like front or center diff to me... I would have the diffs oil changed (especially if never done) and see what comes out of there...
Old Mar 18, 2017 | 10:58 PM
Bhaxhiu's Avatar
GL450
Thank you for doing that. I was unable to find any threads or any videos on this noise. Thanks again.!!!!!
Old Mar 18, 2017 | 11:17 PM
Bhaxhiu's Avatar
GL450
Per vehicle history fluid was changed/serviced about 10.000 miles prior. Will try changing again and see if will help. Thanks for repplying.
Old Mar 19, 2017 | 01:29 AM
gl450x164's Avatar
gl450 530i
If def check the transfer case fluid doesnt take much of a leak to have it dry
Old Mar 19, 2017 | 11:50 AM
DennisG01's Avatar
'08 GL 320 CDI
Wow, that is a really strange noise! In another circumstance, we might say it's a COOL sound
Maybe you could stop by a local garage and get it up in the air on their lift. Start the engine and put it through it's paces and, if lucky, they might be able to quickly find the culprit by following the sound or feeling for vibrations. Probably less than an hour of their time. With proper jacks, in theory, you should be able to do this at home - but I personally wouldn't feel comfortable underneath with the engine and drivetrain spinning and only having 4 jacks as my safety net.
