Anyone gone to 22 inch wheels?
What offset and tire size?
How is the ride and noise?
Would you consider using silver lug nuts? They are aluminum as you know on the OEMs and I have grown to like how they pull in the outer aluminum strip.
Great setup!
Btw... I notice very little difference except for firmness between the OEM winter 21 setup and my summer 22s.
Great setup!
Tires in 305/40/22 are fairly well available, good variety on tirerack. Funny you mentioned the silver lugs, I had already switched them out - the vendor had accidentally sent the wheels out with black lugs and sent me a replacement set in chrome. For the winter/ski/snowboard trip setup, I went with studded Nokian Hakkapeliitta 7's on the stock rims.
Your setup is quite nice as well, love the silver theme with the roof cargo box too!
Embarassingly dirty pic -makes me realize I need to paint the rotor hats:
also.. yours is a 2014? you should consider changing to the current 2015 Brembo pads.. they smoke much less.. actually went to Porterfields and they don't smoke hardly at all...
plus.. check with your dealer as a new update to the command system that was just released in December improves the rear camera!
e.g. 22x10, +30mm offset.
Great setup!
R: 22x10.5 +26
I will tell you that it is hard getting 305/35/22 sized tires from Pirelli..
You might consider using the tire sizes from the GLE coupe =285/40R22 front and 325/35R22 at the rear.... but you might have to check the offsets.
also.. I don't think that the fatter tires look as good as my 35s (probably better for potholes though....)
I'm thinking of getting 22x10's with using 305/40/22. Definitely a more aggressive rear offset, like yours so very helpful.
I did look at that setup but there is only two tire options I believe and the tread rating and reviews show they only last 10k-12k miles.
I did see the wheels and tires in person. They do look amazing (oem gle 22" wheels).
You can only tell the difference from the rear and if you're looking at the tires so not sure if it's worth it for the limited tire selection.
But that wide tire is sweet for sure.
Any reason why you went 10.5 wide, especially in the front? That seems like potential more issues for wobble, but I see Hre runs 11" fronts for some of their ml63 builds.
R: 22x10.5 +26
I use 305/40/22 on my brabus wheels right now with no issues so far and see a few other members run them too.
I do have a concern that it will mess with lane tracking, brake assist, distronic, basically anything that uses the speed/revolutions as a calculation.
It also is a big enough differences that most online tire calculators don't recommend it.
Your tires are too hard to find for me, and 285/40/22 is too narrow for my taste as I did have them on hre's before.
Maybe I stick with building out 21x10 and using the new dws continental 295/40/21 tires, which I'm a big fan of.
Or just do the 22's with the gle tire size as those are close to stock overall diameter and deal with getting new tires every 10k miles.
Any thoughts?
Any thoughts?
So you are running 305/40/22s? that is what had been recommended to me from a wheel/tire dealer in Miami.. I just felt the 40 looked a bit tall (sitting in the showroom.. not on the car... I might change my mind when I see it on the car) As long as the tires roll at the same revolutions.. everything will work fine.
I am now seeing the 305/35/22 on the Pirelli website and hoping that it is available (I always have a spare tire incase I blow one out as I did once hitting a metal curb)
MB will always go with a 40 sized tire for the GL....
as for tire wear.. remember.. the zero is a summer high performance tire and 8-12K is what you should expect for a set of rear tires (and since you can't rotate any of these combos.. it is what it is. I get 1 set of fronts for every 2 sets of rears in the wear aspect of things. I don't feel it that bad as I run my OEM 21s with winter scorpions in the off season (45 degrees and below)
I'm not sure if i iike it that tall either (40), on the 22s, on a GLS
I'm opting for the 22"s - but will change to tire to the widest I can get from pirelli; michelins would have been better but no chance of them getting that size.. 305 or 315 maybe (hope it doesnt rub) and for winter - oem 20/10.5 AMGs with 285s-- ride great on my 14'GL63 -- those will come off when that car goes and should fit on the 17'..
offset is 46 for current GL/GLS AMG rims, but the 22" AMGs I think are 45-- not too aggressive but as long as the fill the wheel well...
21" snows are fine.. I have driven in 16" snow on the roads with my car with the traction control turned off.. anything more and it becomes an issue hanging the bottom of the car up. You should just put scorpion 21" winters on your OEM... that way you don't compromise your non snow winter driving.. trust me on this. PM me directly to discuss.
though.. I did have a Pirelli 22" slip a belt and it was replaced under warranty!
and yea I agree on 21s, scorpion def better, those summer tires are crap .. the Wifes GL has the 21 scorpions on it..
true the wider - more road following, but feels more planted ..
lets see what tire they end up sending with the 22 OEMs.. i DEF do NOT want 285s for summer months, hence the slightly wider option, prolly will end up getting 305s -- prior to delivery (and swap the oem tires out for the difference)
Fronts that I've tried:
22x10 +49mm offset = too far in, zero plastic liner rub
22x10 +35mm offset = looks decent, minor plastic liner rub. Only at full turn and you don't feel it in the steering wheel. You can only see by visual inspection.
22x10 +30mm offset = looks better, but more plastic line rub, you can feel it at full turn, but nothing major. This is my preferred setup for the front.
Rear
22x10 +25mm offset = nearly flush, needs 9mm more to be flush with the AMG fender flare. So +16mm offset might be my ideal setup.
So my new wheels, might get the offset equivilant of 22x10+30mm front and 22x10+16mm rear to using a 11" wide wheel to optimize the 305/40/22 tire.
I believe that is a 22x11+(30+12.7=42.7mm) fronts and 22x11+(16+12.7=28.7mm) rears.
I hope my calculations are right, or else it could be a huge mistake...
BTW I tried 285/40/22 - I do not like the look at all. Skinner than 295/40/21 and fatter. But you have great tire choices at 285/40/22, that's about it.
