Anyone Found An Error Free LED Reverse Lamp Bulb
As per title, anyone found a top quality LED think its W16W that doesnt kick up error messages or get too hot, Im looking to upgrade my reverse lamps to increase visibility on my 360 camera when backing up?
Theres plenty of LED’s around that say error free but reviews by the public say errors have occurred. I dont think a brighter halogen bulb exists so LED or nothing?
Ive got my tailgate hatch trims off for a small dent repair this week so thought Id do the bulb upgrade at the same time.
Carl
I had a go at removing a bulb yesterday, tight as hell so gave up, is there a technique to remove?
@carlosamg50 over a year since I installed them but do not recall difficulty removing the bulb ... if I recall they are just friction/compression fitted, push in pull out
Gutted
Carl
once home will check
pull the trim from the side and you can reach it. Will see a small grey bulb holder with no wires. Simply twist out, swap bulb and out back in
Luyed 921 that is 1550 lumens. Can’t get link to copy over on phone 🤷🏻*♂️
I think when I first did it I pulled some panels off and there is a screw hidden on the pull handle of the lift gate. My buddy from the factory will be over today and I will ask him and try to get some pics to post.
thanks will definitely give this a go
2013 GL550 LED bulb error
I have a 2014 GL450.
will probably work for the GL too
https://mbworld.org/forums/m-class-w...ml#post7612553
