Please help DTC P0299
Hi I’m still semi-new to the brand and forum. So I apologize if I am not up to date on the brand lingo and site functions. I am also on mobile.
Onward to my issue at hand; I have a 17 GLS550, yesterday afternoon check engine light came on, there is no difference in performance or the way it feels. No noticeable anything. I have a very basic scan, used it today to scan it, came up with code P0299 Turbocharger A under boost. From my basic understanding of turbos, I checked the air-filters they’re clean and not clogged. I checked the air inlet tube with the felt like section that likes to rip/tear. I recently replaced the driver side because of a rip in it. Today I noticed the passenger side had a tear in it. Could this be the issue? I don’t think it would be. My reasoning is under post would imply not enough air going in to turbo or it’s getting dumped at the waste gate. But I have been wrong before. Anywho just ordered a passenger side air intake hose because needs to be replaced anyway. But I am not familiar with this engine and/or turbo set up. Any help on trying to self diagnose this code would be greatly appreciated.
thank you! I will pick some new filters up and try that. I looked at mine and they seemed good but who knows? Definitely worth a try. Thanks again
Thanks for asking the question. So after my first update the car ran fine for about 2 weeks. Then the CEL came on again with the same code P0299. After more research and asking around I purchased a mityvac pump. I used this to pull vacuum on each waste gate valve actuator, I pulled enough vac on them to extend the rod all the way then held it for 15 minutes. Once I confirmed no leak on each side I was left scratching my head…but excited because that means turbos probably won’t be the issue. So after lots more research, mainly on here and YouTube to be honest. I came up on the pressure solenoid and little check valves in those lines. After inspecting the check valves for oil and finding them relatively clean I went on to the solenoid. I tried testing it but was not too confident in my execution of said test. But I don’t know, call it intuition, but I decided to replace the solenoid anyways, I found a seller on eBay with same part numbers for like $28. Thought to myself I’ll order it, if it works for 6 months then takes a crap on me I’ll at least know what I need to order. So here we are today, replaced pressure solenoid and still not codes. Hope this helps, I replaced both; engine air filters and pressure solenoid, the solenoid has been the actual fix in my case. I attached picture of exact items I purchased. For reference I have a 17” GLS550
