P052E MIL anyone?
Old Apr 5, 2021 | 12:02 PM
  #51
RA032924's Avatar
I6 and V6 Diesels
Thanks Mike...that’s great to know,,,what was your price for the octupus cable?
Old Apr 6, 2021 | 08:35 PM
  #52
donkey10's Avatar
2016 c300 w205
crankcase vent
Originally Posted by vrathore
I saw this part on ebay...not sure if this is a common repair, but its reachable and replaceable with a single torx screw holding it in. I don't have the dreaded P052E, but do have an oil smell coming from this general area.
PCV Membrane on Ebay...Membrane PCV Mercedes M274 / M270 2.0L А2700180000
bro that part is the fix for the problem its a diaphragm what normally what happen in the winter months it get stuck close and prevent it from opening to vent if you have a 2015 w205 its as that set up on the line parts on ebay would solve the problem.
Old May 17, 2021 | 01:07 AM
  #53
aman preet's Avatar
mercedez cla 250
p052e on vla250 2018 model
Originally Posted by Jetfuture
Had this at about 32,000 miles. Covered under warranty. Would have been something like $1300 the dealer said. I was amazed at all of the major components they had to take out of the engine compartment to get to this part!
my car got 62000 km and 4 years warranty until august 2021. i am concerned will it cover repair under warranty or not?
Old May 18, 2021 | 12:26 PM
  #54
Srenaud's Avatar
2017 GLC 300
No it is not covered under powertrain warranty. My other warranty expired last year and I'm kicking myself for not going in for a diag. I pulled this code and had them Diag it for $150 CAD. They want $1700 CAD to do the repair and $750 CAD for the part. Though its a complete non issue, since the replacement assembly has deleted this "breather valve" entirely. Its just a plastic cap on the new part. I told them to pound sand and i'll do it myself. They did find something else wrong that was covered under warranty though.
I drive a 2017 GLC300 with 61,000km.
Old May 18, 2021 | 01:22 PM
  #55
aman preet's Avatar
mercedez cla 250
c300 2018 with 37000 km with under 4 year warranty
Originally Posted by hihahi45
Any luck? I'm currently in the same boat (42k 2015 C300 4matic)
will they repair under warranty for free???
p052e code coming pcv valve
Old May 18, 2021 | 01:25 PM
  #56
aman preet's Avatar
mercedez cla 250
Originally Posted by Takehold
My CEL came on today - 14,000 miles - I don't know what the code is and no messages but my center controller is warm to hot to the touch. Any ideas? I made an appt for tomorrow.
how much warranty for pcv valve??
p052e code??
i am driving c300 2018 with 37000 km on it
will it cover under warranty
Old May 18, 2021 | 01:26 PM
  #57
aman preet's Avatar
mercedez cla 250
so how much is powertrain warranty because my friend drive c300 2018 model with 37000km with same code coming.. will that be covered under warranty???
Old May 18, 2021 | 07:42 PM
  #58
Srenaud's Avatar
2017 GLC 300
The powertrain warranty DOES NOT cover this. This part is considered part of the emissions system and NOT the engine block. If your friends car may be covered under the "manufacturer" warranty since it is a year newer, tell them to take it to Mercedes and just pay the diagnostic fee. They will tell you if its covered under warranty or not. Just make sure they don't go ahead with any work until speaking to your friend.
Old Jun 1, 2021 | 11:34 AM
  #59
pjsr8509's Avatar
GLC300
P052E - Heavy Rain
Last week I had to drive through heavy rain for a couple hours. My check engine light came on it was again the code P052E. Twelve months ago, under warranty they replaced my crankcase breather valve... A huge disappointment. If this needs fixed every twelve months I'm getting rid of this SUV.
I tried to clear the code several times with no effect. After a couple days, the check engine light went out. I wonder if it will come back or if this was the result of water getting in somewhere to cause a sensor malfunction...
Old Jun 1, 2021 | 12:47 PM
  #60
sn202020's Avatar
2017 & 2022 GLC 300 4Matic
Hi Srenaud,
Very interesting. my 2017 GLC300 w/120Kkm has P052e codes at every hour driving.
Which valve part is deleted on the updated part? 1? or 2?
I might make my current part modified.
Old Jun 29, 2021 | 01:44 PM
  #61
sn202020's Avatar
I received the part from online seller and noticed the yellow marked PCV is gone at the latest improved part.
part number is
A274090560084
made in Germany on May 2021.
Old Jun 29, 2021 | 02:24 PM
  #62
pjsr8509's Avatar
GLC300
So what is that, just a nipple/tube joining the two sections together? Are you doing this installation yourself?
My indicator light is going on and off intermittently. This is happening after having the dealer fix this issue 14 months ago. Same code.
part number is
A274090560084
Old Jun 29, 2021 | 03:03 PM
  #63
sn202020's Avatar
Yes, that is now just a joint and screw hole. and I will try to install myself.
It might be challenging thing because the engine mount need to be removed, but I usually do many repair jobs such as control arms, spark plugs, brakes rotors, ATF pan etc.
My 2017 100k miles vehicle, used to get P052e code on average every 50km driving.
then I added a cup of break cleaner, WD40 etc into the PCV valve hole.
(to access the PCV and to open the cap, I needed to detach battery plus power, remove ECU and slide the intercooler)
after 3 times of doing this, still I am getting P052e code on average 500km driving now.
Erasing the code is hassle. so I will replace this part if things get worse in a few months.
Old Aug 5, 2021 | 12:03 AM
  #64
RinaMatt2020's Avatar
c300 and glc 300
The new part has omitted the diaphragm all together. Im wondering is it possible to take out the existing diaphragm by inserting a hard plastic tube and hose clamps on both ends to make the line uninterrupted only without the diaphragm?
Old Aug 5, 2021 | 12:59 AM
  #65
sn202020's Avatar
Improved part probably has new designs in the rectangular box. Removing the diaphragm with the old part will make another problem I guess.
Old Aug 14, 2021 | 06:40 AM
  #66
sn202020's Avatar
I replaced the intake assembly. Took many hours.
You need some experience and tools to do this. Also small ratchet, various length extensions, mirror, magnet etc..
To remove the engine mount braket, I needed to support the oil pan, then lift 1 cm after remove bolts.
braket 4 bolts removed. Remove lower 2 bolts and 1 a/c bolt from under
Oil seperator is removed
Old & new part
Old Aug 15, 2021 | 02:19 PM
  #67
mikapen's Avatar
Old & new part
Good post.
Make sure you use ALL NEW gaskets when re-assembling. Old gaskets sometimes get crunched or otherwise don't seal correctly, and after all that work it's a shame to go back in there just to replace a leaky seal.
Old Aug 15, 2021 | 03:08 PM
  #68
sn202020's Avatar
Originally Posted by mikapen
Good post.
Good point. check and compare the old and new parts, always.
Old Sep 8, 2021 | 01:00 PM
  #69
harryk30's Avatar
GLC 300 4matic
Learning a lot... my 2017 GLC 300 4matic (36k miles) check engine light came on yesterday, Sept 7th.. 2021 .. 2 1/2 months after warranty expired .. Fault code is P052E71 . does anyone know: 1) how long can one postpone replacing the valve assembly.., 2) if I wait to replace, what type of problems can occur? and 3) what is the significance of the "71" after the P052E (or where I can find the list of GLC fault codes).
Any info/guidance is appreciated.
Old Sep 8, 2021 | 02:58 PM
  #70
sn202020's Avatar
(1.2)
I drove 22,000 km after the first p052e at 110,000km. I reset the code more than 30 times.
No noticeable problem to me.
I saw the higher crankcase pressure might make oil pan oil leak. Mine was okay.
3) 71 or other 2 numbers look no meaning. Only P052e is important I guess.
Old Nov 4, 2021 | 06:55 AM
  #71
gaby10026's Avatar
GLC300
Which service did you do? The dealer inspected this?
Just a poorly designed part and design, not related to the octane as far as I know. Not many use 87 octane (as Mercedes specifically states not to use less than 91), yet thousands have had this issue. Expect a $1300 to $1700 repair bill for this, based upon dealer hourly shop rate. Perhaps one could save a couple hundred dollars taking it to an independent garage if that is your thing.
It's an all-day repair. It requires the following procedures: remove air filter housing, remove tubing to intake line, remove engine control unit and bracket, remove intercooler from bracket, remove intercooler bracket, disconnect battery, remove belly pans, remove belt, remove AC compressor from block, support engine with hoist, remove left engine mount and bracket, and finally replace intake line with integrated vent valve....then put it all back together and clear all faults.
My service was done in December 2018 with 32,400 miles (roughly 50,000 kilometers) and I was told that by then the part had been revised.
I did the service B in the dealership on June which is still under CA federal warranty, but now the engine light is on because of the PCV valve. But dealer didn’t check the PCV for me when they did service B for me. Is this a part of Service B?
Old Nov 4, 2021 | 10:25 AM
  #72
Jetfuture's Avatar
2016 GLC300
It's not part of Service B. Service B is nothing but preventative maintenance items and checks. They will not tear your engine apart to check the breather valve during the Service B. Just hope that you have the revised part when they built your car (I don't know your model year). If not, just always have $1700 sitting in savings, waiting for this problem if you are out of warranty.
This was one of the few design flaws (every car has them) on the earlier GLC models along with the squealing brake problem. Both of these problems have been resolved with parts updates/redesigns.
Old Apr 1, 2022 | 12:10 PM
  #73
fire1808's Avatar
2018 C300 Cabriolet
Wow! I purchased my 2018 C300 Cabriolet off lease back in July 2021. I got a really good deal on it and I love it. The car literally turned 50k miles and almost instantly that code appeared. (P052E). I ma an experienced mechanic unfortunately never worked on Mercedes in my last 40 years. I have the tools and the know how, but the only concern I have is did Mercedes in it's infinite wisdom atleast make a running change and repair this defect? Or will I be looking at doing this again in another 50k?
Thanks for the great info here guys and gals!
Old Apr 2, 2022 | 01:43 AM
  #74
sn202020's Avatar
My part for GLC must be improved 2~3 times based on the replacement part number history.
Hope it lasts longer between the code occupancy.
Old May 10, 2022 | 06:34 PM
  #75
WPP's Avatar
WPP
2016 GLC300
Brutal...2016 GLC300 P052E
Hello Mercedes 2016 GLC300 owners...you would think Mercedes would do something about this issue because of it happening in so many models consistently!!!
Quote we received at Mercedes dealer in Saskatchewan, CANADA is $950 for the part and $750 for labour.
Wish I was a lawyer and CLASS ACTION them on this!!!
Faulty engineering that has caused us to need to repair our third one (original, warranty replacement and now out of our own pocket...SAME ISSUE!!!)
Sorry needed, to "CRANKCASE VENT"!!!
And for fun, -40C and happens when my wife is driving and she thinks blown engine because of the smoke coming out of the exhaust!!!
Such a great make and model of Mercedes but with an issue as prevalent as this that MERCEDES CANADA should be doing something other than dealer charging us $1,700CDN!!!
