GLC300 Spare Tire Options
Old Sep 6, 2023 | 07:40 AM
  #126
LenniePaz's Avatar
GLC300
I saw a few members ask about what to do if we have 19" tires, but nobody answered. Will the 18" spare work?
Old Sep 6, 2023 | 05:19 PM
  #127
BrianA.'s Avatar
2007 Mercedes SL550, 2017 GLC300, 2002 Suzuki Bandit 1200S, 2004 Ducati Monster
It would be bad to use the 18" on the rear wheel or any of the wheels on a 4Matic four wheel drive model. I got the kit from Modern Spare, but if I hadn't, I would have contacted a dealer in Canada to see if I could purchase the spare tire kit from them (Canada has a law that all new cars must have a spare tire)
You could contact a dealer there and see if they can sell you a kit for a 19" replacement.
Old Sep 7, 2023 | 04:52 AM
  #128
no_mulligan's Avatar
'12 E550, '10 ML350, '06 E350, '20 GLC300, '21 GLC300
I believe the Mercedes spare tire kit is the same whether you have factory 18" or 19" or 20". Modern Spare also offers one kit for all tire sizes. This works because the overall diameter is the same.
Old Sep 8, 2023 | 03:46 PM
  #129
DanD.'s Avatar
2018 GLC 4MATIC
Totally agreed as long as overall diameter is the same for all tires.
Check this link, it will tell you if its ok to use
Just put the tire size
https://tiresize.com/calculator/
Old Sep 9, 2023 | 01:37 PM
  #130
mikapen's Avatar
Here is another site.
It allows you to go the extra step and measure clearances between fenders and suspension parts.
https://www.wheel-size.com/calc/
Clearances will be more important with big oversized tires.
Old Oct 23, 2023 | 11:11 AM
  #131
macsp's Avatar
2018 GLC300 4Matic- White
Hello,
After using run flat for all season and winter, I am getting ready to move away from those expensive tires. Read all these posts here and watched a video as well, link below. Then went on to buy the below and put it in my trunk. Fits fine with a very little push. Had to bend some floor pockets, including the fuse box corner. See the pictures for reference.
Model: 2018 GLC 300 4MATIC
Original tire/rim: 235/55/19
OEM spare tire: A1674000300, 155/80/19 ==> I haven't installed to test it, but based on the readings, it should be fine. I will take to my mechanic when I go there to switch to winter tires and ask him to test it on front and rear.
Still to buy:
Short lug nut: A0019901607 or B66470155 ==> can someone confirm it will be the right size? It is 27mm thread.
Jack: A1645840713
Reference:
Spare tire GLC 43 fit tested - MBWorld.org Forums
Old Oct 23, 2023 | 03:17 PM
  #132
LenniePaz's Avatar
GLC300
I got my tire today from Ebay. It fits nicely in the back and it just takes a gentle push to close the hatch. As far as storing the jack, I ordered the genuine jack from here. https://www.mercedesbenz.parts/oem-p...kit-1665806900
Where are you guys storing the jack? It looks like on the left of the trunk area on my 2019 GLC300 that there's a spot for the jack but mine doesn't fit there. Are you just storing the jack down by the left side of the tire?
Old Oct 23, 2023 | 08:20 PM
  #133
macsp's Avatar
Too bad the jack won't fit into that slot on the left. I saw someone posting part number A1645840713 and not sure if that will fit there.
Anyhow, it doesn't really matter as long as you can fit somewhere there.
What is the part number of the short lug nut you bought?
Also, I am not sure if we really have to buy the MB jack. As long as the weight is considered, can we use a generic scissor jack?
Old Oct 23, 2023 | 08:38 PM
  #134
LenniePaz's Avatar
GLC300
These are the lug nuts I bought.
https://a.co/d/1MvBtAM
I got the jack and all the tools to fit in that spot on the left side. Everything has a spot in that area. There was a panel that popped out in front of the jack that allowed it to fit in there. There's a piece of Velcro that holds the jack down in that spot that I need to find. If you watch this video you can see where all the tools and Jack are supposed to be.
Old Oct 24, 2023 | 08:56 AM
  #135
macsp's Avatar
Thank you. I will check the lug nut. I am able to find OEM lug nut with p/n A0019901607 here locally. They are 27mm tread while yours is 26mm. Everything else is same. If someone can confirm the 27mm lug nut will work fine for 2018 GLC, then I can get them any time. I don't think 1mm will make any issues.
As for jack, I will keep looking.
Old Oct 25, 2023 | 08:30 AM
  #136
macsp's Avatar
A quick question...I have located the 27mm OEM lug nuts, but it seems to have only 4 lugs and one key. I believe we need 5 lugs in total. Can you please confirm what you got? I don't really think we need a key for this spare tire. Thanks.
Old Oct 25, 2023 | 10:55 PM
  #137
LenniePaz's Avatar
GLC300
Hi All,
Thank you all who provide feedback, because of all of you, I was able to get all and its does look good, so now is my turn to provide the feedback.
It does fit under the lid with other junk no issues.
Here is my setup,
Spare tire
Attachment 425716
MB Vehicle Tool Kit
Part #1665806900
GSPSCN Portable Air Compressor Pump Dual Cylinder Heavy Duty Tire Inflator with LED Light,150 PSI 12V Air Pump with Tire Repair Kit and Toolbox for Auto,SUV,Truck Tires etc https://
http://www.amazon.com/dp/B07GJND1PX/..._Ke4-EbTTG2C3M
Some pictures
Attachment 1
Attachment 425720
Attachment 425722
Attachment 425718
Attachment 425719
Attachment 425726
Attachment 425724
Attachment 425723
Attachment 425725
What was your reason for buying the tire inflator?
Old Oct 26, 2023 | 12:53 AM
  #138
DanD.'s Avatar
2018 GLC 4MATIC
if its a small hole, you can pump it and keep going, larger holes hopefully can be patched, pumped and move on.
i would rather driving on patched tire vs spare. For me, spare is the last option.
Old Oct 26, 2023 | 07:31 AM
  #139
LenniePaz's Avatar
GLC300
Ah, gotcha.
Old Oct 26, 2023 | 08:48 AM
  #140
macsp's Avatar
What lug nuts did you buy? The jack and the lugs are the outstanding items for me to buy. Since I have a roadside assistance from CAA here in Canada, I am less worries about the jack; however, needs to have the right lug nuts in the trunk. Please let me know if non-OEM nuts will be fine as well. Thanks.
Old Oct 26, 2023 | 11:11 AM
  #141
DanD.'s Avatar
2018 GLC 4MATIC
See my pic. They just right. Hope it helps.
I have 2018 4matic
Old Oct 26, 2023 | 11:31 AM
  #142
macsp's Avatar
I have 2018 4matic
Attachment 452311
Nice, this is what I want to buy. What is the OEM part number for these 5 lugs? Or, did they come with the jack kit?
Old Oct 26, 2023 | 12:05 PM
  #143
DanD.'s Avatar
2018 GLC 4MATIC
Sorry don't know the part #. Spare tire's seller added them. Im pretty sure any short lug nuts with right threads would work.
Try any store, worst case just return them.
Old Oct 26, 2023 | 12:26 PM
  #144
macsp's Avatar
OK, in that case, I think the closed match would be this from Amazon and I can order them.
Wheel Lug Bolts, 5Pcs A0009908307 0009908307 M14x1.5mm Wheel Lug Nuts, Stainless Steel Tire Lug Nuts Fit for A180 A200 W176 : Amazon.ca: Automotive Wheel Lug Bolts, 5Pcs A0009908307 0009908307 M14x1.5mm Wheel Lug Nuts, Stainless Steel Tire Lug Nuts Fit for A180 A200 W176 : Amazon.ca: Automotive
Old Oct 26, 2023 | 04:32 PM
  #145
LenniePaz's Avatar
GLC300
You asked me before and I posted a link to the lug nuts I bought. You even thanked me for posting the link. 🤦‍♂️
Old Oct 26, 2023 | 08:10 PM
  #146
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Old Oct 29, 2023 | 11:49 AM
  #147
macsp's Avatar
Hi,
I ordered the same and received the delivery. But the orange caps on the nuts are missing. How important is to have those caps/sleeves? I think they do protect the thread. How did you receive yours, with or without the caps?
Old Oct 29, 2023 | 03:06 PM
  #148
LenniePaz's Avatar
GLC300
Hi,
No caps either, no big deal.
Old Oct 29, 2023 | 06:22 PM
  #149
macsp's Avatar
Thank you, appreciate the quick reply.
Old Oct 30, 2023 | 12:40 PM
  #150
mikapen's Avatar
Those plastic caps are only for thread protection. Just inspect the threads.
