Whistling mirror and fuel filler door
Old Dec 13, 2021 | 08:47 AM
Bryce1023's Avatar
2024 GLE, 2022 GLC , 2022 GLC
Just curious if on model year 2022 GLEs , has the whistling sound emanating from the driver’s side mirror and the poorly aligned fuel filler door problem been corrected? Thanks
Old Dec 14, 2021 | 03:35 PM
schkar's Avatar
2022 GLE 350
I don't hear any sound and the fuel door looks fine
Old Dec 14, 2021 | 06:24 PM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
Yes the whistling is a common problem that has been discussed here before. I can’t remember what it actually was or if a remedy was found but try searching.
Old Dec 15, 2021 | 06:47 AM
conditionone's Avatar
2016 E350 Wagon w/AMG, 2018 GLC300 Selinite SUV w/AMG Night(sold) 2021 GLE450 AMG Night
My 450 was bult in April of '21. No whistling and the fuel door fit is perfect.
Old Dec 15, 2021 | 01:52 PM
Dave Stough's Avatar
2021 GLS450 2020 GLE350 2005 BMW 325ci Convertible
I've had neither problem on either of my 167s
Old Dec 16, 2021 | 05:03 AM
haibieb's Avatar
2026 GLE 450 (Black on Brown Saddle)
Our 2022 GLE 450 built in mid-October does not have the issues dealing with the whistle noise nor the fuel filler door
Old Dec 17, 2021 | 01:36 PM
Don’t just trust what others say. Including me.
https://mbworld.org/forums/gle-class...ing-sound.html
Old Dec 20, 2021 | 10:50 AM
toban's Avatar
2021 GLE 450
Gas Cap not flush:
This may sound weird but my cap was flush when I received the car. But one day I noticed the bottom right corner of the cap was not flush with the side of the car. I pushed on it and it would not line up. So, I opened it up and noticed the rubber cord that connects the gas cap and the hinge seemed to be in the way of the hinge when closing. I found you need to make sure the cord is moved up around the gas cap in order to get it out of the way of the hinge when you close the lid. When I did this, the lid once again lined up.
Toban
Old Dec 21, 2021 | 11:51 PM
kruzomatic's Avatar
GLE450
Whistling mirror not fixed on 2022 GLE. Purchased a 2022 GLE450 late October, been to the dealer multiple times for the issue. They replaced the mirror cap and it got worse. They are waiting to find out if there are other options to try and repair. I’m going to send the service manager the bulletin from another thread. The service department doesn’t have any idea how to fix the issue. It’s a total no2 show. In discussions with their sales GM to take the vehicle back. What a nice vehicle to have such an annoying issue to ruin the MB experience.
if anyone else finds a solution other than the “carbon fiber cap of the mirror cap” please share.
Old Dec 22, 2021 | 07:22 AM
Bryce1023's Avatar
I believe that there’s a replacement cover from MB , that will correct the problem. Please check some related threads that just talk about whistling mirror. The part #is also posted.Your dealership will have to order the part, paint it, then install it. Good luck
Old Dec 22, 2021 | 08:37 AM
kruzomatic's Avatar
GLE450
Mirror cap replacement was already done. The service department ordered a new cover, painted and installed. The whistle got worse. The service manager is waiting on MB to furnish other options. Not likely a solution. Best solution is getting more likely to not to buy the GLE or GLS. In my case return the vehicle. Some people may only listen to music or talk radio so it doesn’t matter. But for anyone who likes to just drive, the whistle is stupidly annoying. What a terrible design.
Old Dec 22, 2021 | 10:55 AM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
Can you confirm the part number of the replacement mirror cover? Is it the new design part number?
Old Dec 22, 2021 | 06:05 PM
kruzomatic's Avatar
GLE450
This is what’s listed on the service order:
SPO 167 810 61 05 Mirror Shell
Old Dec 22, 2021 | 07:45 PM
TexAg91's Avatar
The invoice for the individual (Daso) in the other thread that had his housing replaced is copied below. Looks like a different part number. Perhaps you had same faulty design part installed?
Old Dec 22, 2021 | 09:32 PM
pcsgrp's Avatar
E350 4-Matic, GLE350, Harley Davidson Electra Glide
I have a fall 2020 build GLE and I don't have the problem. I did find that I get a wind noise above 60mph but it seemed to be coming from the rear driver side door. I had a similar problem several years ago on another car, wind noise when the outside temp started to get cold. A friend of mine suggested that I spray some dry silicone on the rubber gaskets around the door and that seemed to work. I wonder if the mirror issue is related to the slit in the plastic where the two parts of the cover come together. I put so much wax on my car after I got it, I think the seam is filled. Considering some had the part changed, perhaps taking it apart and putting a new one on made a change in the seam making it worse. Worth a shot
Old Dec 26, 2021 | 05:44 AM
bkushner's Avatar
2024 GLE 580
I had the fuel door issue. It was completely replaced at my first service and looks exactly like the original. Not aligning.
Old Dec 26, 2021 | 06:37 AM
Bryce1023's Avatar
I really don’t understand how a Mercedes Certified Technician can completely change the fuel filler door and return the car to you looking as if nothing was done. I hope that they offered you an explanation and a remedy…..
Old Dec 26, 2021 | 07:55 AM
places's Avatar
No more MB:(
All part of the GLE experience. They will get I right.
Old Dec 26, 2021 | 01:53 PM
bkushner's Avatar
2024 GLE 580
It looked ok until it was opened and closed a couple of times.
Old Dec 26, 2021 | 02:35 PM
mikapen's Avatar
It should be pretty easy to do. Just remove the filler door assembly, swap the painted part onto the new assembly and stick it in there!
Old Dec 27, 2021 | 02:40 PM
nextmilenium's Avatar
2021 GLE450
Strange I just started noticing the whistling noise during our recent trip. I was driving at around 80 MPH and heard this high pitch whistling noise from the drive's mirror area. I haven't heard this before during our many extended drives so I thought it was strange. Maybe it's because we normally play music while driving so that masked the noise.
It's not loud enough to bother me now so I'll wait till the 10K service and get it fixed then.
Old Jan 29, 2022 | 05:20 PM
blak's Avatar
Mercedes 2020 GLE
Exact same experience. 2020 GLE. Drivers side mirror housing has been replace FOUR times over my two years of ownership...and it still sounds like a whistling tea pot...occurs in cold weather (under 35 to 40 degrees F) and at speeds above 60 to 65MPH. Just got the vehicle back yesterday after the FOURTH attempt and still as bad as ever. Service advisor said no point in bringing it back again...which means they have no solution. I am in contact with an attorney who has accepted my case with no out of pocket and will sue Mercedes on breach of warranty. Like you, I don't always listen to music...even when I do, you hear the tea-pot boiling! Have written Mercedes USA, asked them to take the vehicle back and reimburse me...the simply said "NO". This is truly the worse vehicle experience I have ever had. Have owned everything from Honda, Toyota to Audi, BMW, Lexus, Porsche...and NEVER been through such a bad experience. Will NEVER buy another MB. Good luck to all others with this same issue.
Old Feb 18, 2022 | 09:26 AM
blak's Avatar
Mercedes 2020 GLE
Would recommend you buy a GLE and apparently the GLS has the same issue. I have had my 2020 GLE in over 8 times for this issue...and they have replaced the mirror housing 4 or 5 times...the whistling tea pot noise can't be fixed. Filing a breach of warranty claim. Worst car ownership experience I have ever had...and I have owned practically all major brands! First and last MB I will have...
Old Feb 18, 2022 | 09:30 AM
blak's Avatar
Mercedes 2020 GLE
Simply no solution! My GLE has been in a 8 to 10 times for this...multiple attempts to replace mirror housing....never improves...suing MB for breach of warranty.
Old Feb 18, 2022 | 10:12 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Tested my GLE last night at +80mph and no whistling in my car. Maybe it is not the actual mirror guys.
