Turbo lag on 350 vs 450
The thing was a dog. Very laggy and slow, when compared to my All-terrain. By the end of the day, I kind of got used to the lag and its characteristics, but I sure was glad to be back in the E450 and turn in the loaner.
The GLE is a very heavy vehicle, and putting this 255hp 4-cylinder to power it, is a pathetic move on MB’s part. BMW does not subject their X5 customers to a 4-cylinder, as far as I know, and the only reason why MB does it, is because people look to pinch a few pennies and buy it, instead of going for the FAR better 450. To add insult to injury, MB also equips many of these GLE350s with the fat 315mm wide tires on 21” wheels……the last thing the underpowered 350 needs, is MORE traction from wider tires !
My 2022 E450 All-Terrain has had zero issues till date, but it only has 30K miles…..and reliability wise, compares favorably with my 2019 Honda Fit with a stick-shift, which is my reliability benchmark. My buddy with his 2020 E450 All-Terrain, just crossed 165K miles, with zero problems, and he plans to buy the new 2025 E450 All-Terrain, once it touches 200K.
If you want to keep a Mercedes for the long haul, I would not go crazy with many of the electronic doo-dads and hyper modern things like the E-ABC etc. Aggressively edit those out of your options list. Those are ticking timebombs that will cost a LOT to fix and they WILL go wrong, sooner rather than later…..just the nature of the beast. If you are a leasor, and plan to turn in the car after the lease, go crazy with these options, but if you are a buyer, be VERY choosy in the complicated electro-mechanical bits that you add on…..the lesser the better, and the Mercedes will reward you with trouble-free long-term ownership.
Bottomline, being at the bleeding edge of technology, is asking for trouble, especially when we are talking about highly complex electro-mechanicals…..I prefer to be at the trailing edge of technology, for products that I keep for the long haul, and it has worked for me very well, thus far.
You really can't tell the performance until you're into the second tank of 92 octane.
I had a C43 AMG loaner that was Much Slower than our GLC300, until I emptied the tank and started with the resl stuff. Then I appreciated it.
M260 also had cylinder head recall, not sure if the M264 had similar recalls. The newer version used in the W206 C-Class as the form M254 is too early to tell.
So from a pure reliability standpoint, the M256 six-cylinder makes more sense if planning to keep for a while especially how the M256 six cylinder is less stressed than the 4 cylinder M264 especially on heavy accelerations. Haven't heard much about engine failure from M256.. other than this one on the forums: https://mbworld.org/forums/cls-coupe...e-failure.html
But despite that, the 4-cylinder is a drag, especially if outfitted onto a 5000lbs GLE. And even worse if they equip the GLE350 with 315mm or 325mm wide rear tires.
BMW does not insult their X5 customers (direct competitor to the GLE), by equipping it with a 4-cylinder engine, and not sure why MB feels they can get away with such an obvious cost cutting move.
Yes, they do offer 4-cylinder x5's.
No 4-cylinders for the X5, unless I am missing something. Maybe other markets offer 4-cylinders but the US starts with the 3.0L Inline-6.
