Glk250 oil
Old Oct 1, 2023 | 09:00 PM
Benzarebest's Avatar
Glk250
Glk250 oil
Hello all
This is my first post.Hope I am getting it right.I have a 2015 glk250 with 178000 kms on it.I decided to change the oil and filter myself for 5he first time,and avoid the dealer.Not knowing anything about 22951,I used Shell Rotella T5 15W-40 diesel engine oil.This is API CK4, CJ-4 C1-4 C1-4 or CH14.Is this OK or am I hurting the engine,and need to chang the oil again.
thanks
Grant
Old Oct 2, 2023 | 04:10 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
thats pretty wrong, wrong viscosity and it's not optimized for european diesels. i'd change it out right away
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Oct 2, 2023 | 10:01 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to X204 forum...
Old Oct 3, 2023 | 02:25 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Originally Posted by Benzarebest
Hello all
That’s a heavy duty engine oil. It was designed to meet completely different criteria than what your engine requires. While it may not cause immediate damage, it will take more time to reach critical lubricated parts on start up because of the 15W viscosity. That will increase wear. If you’re in Canada like your profile suggests, that will also create a much higher starting load on the engine in the winter, and may even result in lubrication failure.
I suggest draining and refilling with an oil from this list that is available in your location:
https://operatingfluids.mercedes-benz.com/sheet/229.51
Old Oct 3, 2023 | 10:11 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Prepare for some very strong opinions!
There are three MB oil specs that are "approved" for the OM651 engine. They are MB 228.51, MB 229.31, and MB 229.51. The only oil I have found here in the US that meets any of those specs (228.51) and also has API CK-4 approval is Chevron Delo 400 XLE, available in 10W-30, 10W-40 and 15W-40. (Some weights may not have MB approval). The issue with using an oil that is not Mercedes approved is potential damage to downstream emissions components, i.e. the DPF and SRC.
[Edit]- Found another, Shell Rotella 550046251 T6 Full Synthetic Multi-Vehicle 5W-30 CK-4 and MB 228.51
There's nothing wrong (IMHO) with using the 15W-40 oil as long as you don't have to start it in temperatures below about 15 degrees F. I can't find any information on the 10W-40 variety.
One thing to consider: the Chevron oil is not a pure synthetic; it is a synthetic blend, so maybe a 5,000 mile oil change interval...
Old Oct 3, 2023 | 12:13 PM
Odd Piggy's Avatar
There are three MB oil specs that are "approved" for the OM651 engine. The issue with using an oil that is not Mercedes approved is potential damage to downstream emissions components, i.e. the DPF.
Yes. Everyone has an opinion. Try to stick with data.
@JohnCC has a GLK250, lives in northern US (cold winters), makes valid points, and has found a suitable oil.
Availability of oils varies by location. We have found Mobil 1 ESP 5W-30 readily available a many locations. It is labeled MB Approval 229.31, 229.51 and is on the link I previously sent. We use it in our medium duty diesel trucks (7500 mile changes) and our MB GPF gasoline vehicles (10,000 mile changes).
Old Oct 3, 2023 | 12:16 PM
C300fan2's Avatar
14 GLK 250
Go to Canadian tire and get the Mobil 1 ESP 5w30 4.71L Jug
https://www.canadiantire.ca/en/pdp/m...p.0289448.html
Goes on sale all the time for 40$
This oil is specifically approved for your vehicle and easiest to get in Canada.
Old Oct 3, 2023 | 03:32 PM
andreigbs's Avatar
GLK 250
Agree with using 229.51 spec oils, regardless of brand, and there are many that fit the bill. Some you can even find at Wal-mart for pretty cheap.
One example: Pennzoil Platinum Euro L in 5w30 at $26 for 5L jug. You'd need a couple more liters for a full change, but you can't beat it for the price. (see here).
Why anyone would use non-spec oil in a complicated Benz diesel is beyond me.
Old Oct 3, 2023 | 08:32 PM
KTM530's Avatar
GLK250
I'm also using the Penzoil euro L 5w30. Living in Canada, easy to find at Canadian Tire and on sale twice a year. Changing my oil every six month (7000km). Rotella is a good heavy duty diesel engine oil but it is better to stick with MB spec.
