Rides like a brick
Rides like a brick
Is anyone having any issues with the suspension and overall ride quality of a 2021 GLS AMG 63? I’ve tried every setting and even small bumps rattle the entire vehicle. Have 22” rims with only 5300 miles. Tire pressure at 39 psi.
Received 3,421 Likes
2012 CLS63
I laughed immediately after reading your thread title Have you considered smaller wheels?
hyperion667 (07-25-2022)
2012 CLS63
What are the current tire specs? Namely sidewall.
As noted, it's going to be stiff with the big wheels, the performance tires, and the AMG suspension stuff. One thing that probably will help a little is double check the tire pressures on the fuel door as well. 39 all around seems high. Each individual vehicle is different, but (From memory) think mine is listed for something like 37 front and 35 rear unloaded, and more like 39 all around if loaded (which is 4+ people and luggage.). Mine's at the dealer for regularly scheduled maintenance today, so can't check for sure.
Start with the tire pressure and see if that helps, and if not you can see if you want to size down a wheel or so. My winter tires (on 22's) are a good bit softer than the summers on 23s - which is part size and part the nature of winter versus high performance summer tire.
Finally, it's not impossible that something is malfunctioning in your car...but hard to say as everyone's butt is calibrated differently. I would definitely not say every small bump rattles the entire vehicle for mine. I'm actually surprised at how "livable" it is, but I have other vehicles that are certainly worse, so hard to say if mine is better than yours, or if my tolerance is different.
The following 2 users liked this post by CincyMBGuy:
hyperion667 (07-25-2022),
PhilipHanser (07-25-2022)
Thanks guys appreciate all the help. The fuel door says 39 rear and 40 front. I’m going to try and lower it to maybe 35 and see if the tpms doesn’t go bananas and see if that helps.
The TPMS will likely give you a warning at 35 if they are 39 now, but you can reset the level so 35 is "normal" so you don't get the warnings.
2012 CLS63
If you want, post the picture of your fuel door label and we can help you find the pressures recommended for you.
marchgroupinc (07-28-2022)
